30th July 2008, 05:45 | #281 | Link |
He never criticized x264. You're criticizing his options, yet --no-fast-pskip / --no-dct-decimate / --filter -2:-2 were still advised by Dark_Shikari. He didn't use subme 7 / b-rdo / umh (he stopped at subme 6 / hex ) but it's still a coherent choice.
In the end, though the number of bframes / vbv-bufsize seem off, they may probably have been set to match those used in Sonic CineVision, in order to make a fair comparison. And, on a side note, if 7 years ago I had received such a welcome on doom9, I would never have bothered.
30th July 2008, 05:47 | #282 | Link | |
x264 developer
If you used such inflammatory and loaded language, you wouldn't have been welcomed here either. Fortunately, you're much more mature than that and I would never expect anything of that sort from you. I do agree that most people here were far too sharp in their reaction; there seems to be a tendency for people to see others overreact, and interpret that as a signal that they can overreact too. It generally is a good idea to assume good faith at least initially, which most people seem to forget...
Follow x264 development progress | akupenguin quotes | x264 git status ffmpeg and x264-related consulting/coding contracts | Doom10 Last edited by Dark Shikari; 30th July 2008 at 05:57. |
30th July 2008, 05:50 | #283 | Link |
Angel of Night
Sharktooth: Calm down. You get way too riled up when anyone posts something provocative, and start flinging insults, instead of putting them in their place by calmly pointing out what's wrong. You'll end up suspended for rule 4 if you don't stop reacting angrily.
30th July 2008, 08:12 | #284 | Link |
Testeur de codecs
Well just my 2 cents.
1) BR and AVCHD specifications - HP@4.1 specification with limitation - Buffer max for 1080p24: 30 000 bits - Max bitrate at 40 Mbps for BR and 30 Mbps for AVCHD - 4,3 for p,b frame reference, 3 pyramidal bframe imply 3,2 ref for p,b. Use 2 bframes with 4,3 ref is better for software compatibility. - Max gop at 24 with IDR - WPred - FGM is not supported 2) At 15 Mbps you have not transparence with 42" and higher screen. From my experience x264 with good patch is by far better than Mainconcept SDK (cinevision) but only at low/medium bitrate. x264 produce really impressive result in [6-8] MBps interval for 1080p24 content. Code:
@REM ----------------------------------------------------------- @REM @REM Profil BluRay 1080p23.976 extra high quality @REM @REM ----------------------------------------------------------- @REM Source file name (suffit de mettre la source ici) set E_SRC=Lossless.avs @REM Set of quality (ici la qualité 1-50) set E_BR=21.3 @REM Set of max bitrate (ici le bitrate max) set MAX_BR=40000 @REM Set of Buffer (ici le buffer) set BUF_BR=30000 @REM Set credit (frame de début du générique) set CRE_FR=201560 @REM Set end credit (frame de fin du générique) set END_FR=207442 @REM Profil x264.exe --threads auto --thread-input --keyint 24 --min-keyint 1 --crf %E_BR% --vbv-maxrate %MAX_BR% --vbv-bufsize %BUF_BR% --mvrange 511 --level 4.1 --bframe 3 --b-pyramid --b-rdo --bime --weightb --ref 3 --mixed-refs --direct auto --deblock -2:-2 --ipratio 1.10 --pbratio 1.10 --partitions "all" --8x8dct --me "umh" --subme 7 --trellis 2 --no-fast-pskip --no-dct-decimate --aud --nal-hrd --sar 1:1 --cqmfile Sagittaire.cfg --psy-rd 1.0 --zone %CRE_FR%,%END_FR%,b=0.33 --progress --pass 1 --stats "stat.log" -o 1080p_Q1.264 %E_SRC% pause
Le Sagittaire ... ;-) 1- Ateme AVC or x264 2- VP7 or RV10 only for anime 3- XviD, DivX or WMV9 |
30th July 2008, 12:55 | #286 | Link | |
Mr. Sandman
what may sound an offence is a mere constatation of facts. btw trust me, you dont want to see me angry.
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 30th July 2008 at 12:59. |
30th July 2008, 16:22 | #288 | Link | |
Testeur de codecs
x264 produce simply 12 Mbps at 21.3 for this encoding. In this test x264 with psyrdo patch is a real killer.
30th July 2008, 20:52 | #289 | Link | |
So, for a person using build 920, psyRDO on (default), trellis 2 (don't care about speed loss), and using CRF; what is the correct application of these settings? I've now seen Sharktooth say --no-fast-pskip and --no-dct-decimate are bad. I've seen Dark_Shikari say to just go with default filter values (0:0). Now, there's conflicting info in what I've quoted from Manao. Any help? BTW, here's my commandline as it stands now. Code:
--crf 20.0 --ref 5 --mixed-refs --no-fast-pskip --bframes 3 --b-pyramid --b-rdo --bime --weightb --subme 7 --trellis 2 --partitions p8x8,b8x8,i8x8 --8x8dct --me umh --threads auto --thread-input --progress --no-dct-decimate --no-psnr --no-ssim --output "output" "input" |
30th July 2008, 20:59 | #290 | Link | |
x264 developer
30th July 2008, 21:05 | #291 | Link |
I never given any settings on this thread. I just compared Vit's initial settings from those advised by Dark_Shikari and pointed out settings that were present in both, yet subject to polemic : no-fast-pskip, no-dct-decimate, filter -2:-2.
I don't know whether no-fast-pskip and no-dct-decimate ought to be used or not (instinctively, i'd say the first is good, and so is the second if trellis 1/2 is used). As for filter, between -3:-3 and 1:1, it's imho a subjective matter.
31st July 2008, 17:33 | #292 | Link | |
Hi Manao,
Thank you for the reply! I wasn't meaning to imply YOU were giving the settings, per se, but just quoting what you were in turn quoting. Quote:
31st July 2008, 19:48 | #293 | Link | |
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 |
31st July 2008, 19:51 | #294 | Link |
Mr. Sandman
he used wrong settings for x264. you cant compare speed and quality of 2 different encoders if you cant set up them (or at least one of them).
31st July 2008, 19:54 | #295 | Link |
it's only important that the G4 Encoder settings where of the same nature then the X264 settings, tough we dont know what the Cinevision 2.6 settings where if they where equal you could very well compare it especialy the decission side of things b-frame decission, partition decission, scenecut and b-pyramid decission is very important here. Compression/Complexity wise i agree Vit his settings aren't as effective as Sagittaire but to call them wrong hmm sure in terms of BD profile there way of too to what you normaly would use but it doesnt matter in his comparision he did with Cinevision 2.6 in this case for this very special Film source.
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 31st July 2008 at 20:11. |
31st July 2008, 20:02 | #296 | Link |
Mr. Sandman
he said cinevision was constantly better (subjective, without pics or clips) so probably he used much different settings and we also dont know anything about the source and cinevision settings.
he just came here, trolled and gone away. he just didnt contributed in any way to the discussion, so, for what concerns me, he could even not post at all.
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 4th August 2008 at 01:51. |
31st July 2008, 20:15 | #297 | Link | |
@Sagittaire I hope we gonna see a Cinevision 2.6 vs latest X264 GIT and X264 GIT + Psy RD Blu-Ray restricted Film Source comparission from you in the future
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 31st July 2008 at 20:33. |
31st July 2008, 22:06 | #298 | Link | |
Testeur de codecs
http://forum.doom9.org/showthread.ph...67#post1149767 2) Moreover you can't use all the insane SDK setting in cinevision 2.5 and certainely not in cinevision 2.6 too. Cinevision is pro gui for high bitrate encoding. Certainely better here to use Reference or Converter for have the insane setting. 3) Psy RD patch for x264 is a real killer. Certainely the best patch that I have ever seen for x264. RDO for bframe decision don't make very higher quality like I expected but some small optimisation produce big improuvement at the end.
Le Sagittaire ... ;-) 1- Ateme AVC or x264 2- VP7 or RV10 only for anime 3- XviD, DivX or WMV9 Last edited by Sagittaire; 31st July 2008 at 22:19. |
1st August 2008, 00:31 | #299 | Link | |
And no it wasn't my intention to compare Insane settings vs cinevision non setable settings it was my intention to compare the decissions and the speed/quality difference if the're any for a Blu-Ray Framework @ exactly those High Bitrates and gop restrictions
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 1st August 2008 at 00:42. |
1st August 2008, 00:35 | #300 | Link | |
x264 developer
psy-rd, psyrdo |
