28th November 2007, 17:54 | #2582 | Link | |
ffdshow/AviSynth wrangler
VirtualDub was passing me an RGB image with a negative pitch (i.e. the image was stored vertically flipped in memory) and my code then happily allocated a negative amount of memory for the buffers - guess I never tested that case... Anyway, it'll work now, but buffering ahead in VDub will introduce a delay in the video since it'll return an empty frame until all buffers are filled, and of course the same amount of frames will be missing at the end. But, once again, there's nothing I can do about that... np: Bola - W.i.K (Soup)
now playing: [artist] - [track] ([album]) |
29th November 2007, 12:47 | #2585 | Link |
A bug in audio decoder?
@haruhiko_yamagata: RealAAC decoder and the LFE Crossover filter is not working together in r1625 , libfaad2 is OK. (Older version is OK, eg: r1523 .)
Tried with Nero AAC LC 5.1 in an mkv container. Btw: what is the difference between the 2 (libfaad2 and reelaac) ? The latter sounds better to me ... Am I right ? Thanks |
29th November 2007, 13:08 | #2586 | Link |
They are two different decoding libraries. Afaik, libfaad2 is the best one of the two.
MPC-HC 2.2.1 |
29th November 2007, 13:32 | #2587 | Link | |
29th November 2007, 15:52 | #2588 | Link |
Testing beta4 on Win9x
I've just tried to test ffdshow_prebeta4_rev1656_20071029_clsid.exe on Windows 98, but unfortunately my old PC seems to be broken.
Any volunteers, would you test it on Win9x? |
29th November 2007, 19:18 | #2591 | Link |
Turkey Machine
I'm in the process of installing 98SE on my desktop computer. I should have a response by the end of the weekend, if not, next weekend.
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld |
29th November 2007, 21:14 | #2592 | Link | ||
It's only present with 5.1 ch AAC source: - when you use realaac the output channel config is 7 ch instead of 6 !!!!!! (see at the Info & CPU section) - I'm getting destortion sound because AC3 filter (v1.46) is connetced at the end of the chain to ffdshow, and -as it seems- it doesn't like "7 ch - LFE crossovered" input ! And -as always- thanks again for investigating/fixing the problem ... Quote:
29th November 2007, 21:33 | #2593 | Link | |
I have one machine running win98. Just PM me or do whatever you like... |
29th November 2007, 23:58 | #2594 | Link | |
Just opening one file using ffdshow would help much. Further important testing may be ...
30th November 2007, 00:02 | #2595 | Link | |
30th November 2007, 10:05 | #2596 | Link | |
[*]Launching VFW configuration dialog | ok [*]Launching makeAVIS.exe | ok [*]preset loading | ok Pretty much I tested on the fly seems stable. Subtitles in ANSI works on former releases. |
30th November 2007, 11:06 | #2598 | Link |
A Question ?
I'm New In Here .. May I Ask A Question : Is The Ffdshow H264 Encoder Updated To The Latest x264 Edition, I Mean, On Which x264 Library Build Is It Based ?
I Have Noticed Also That When Decoding With Ffdshow, The Decoder Usualy Fails In Autodetecting The ColorSpace I'm Using .. This Occurs Frequently With RGB32 Encoded Files, He's Decoding Them As If They Were In YV12 Color Space, Is It A Bug Or Is This Normal ? By The Way, In Case The Above Question Has Been Asked Before Please Forgive Me, I'm Just A Newbie.
MhX Digital - An Old Fan Of x264 |
30th November 2007, 11:33 | #2599 | Link | |
This sample would help testing subtitles. It has UTF-8 SSA subtitles, which may be a bit difficult task for Win98. |
