14th January 2006, 22:33 | #121 | Link | |
14th January 2006, 23:16 | #122 | Link | |
15th January 2006, 00:42 | #124 | Link | |
There are some basic tactics to adopt in diagnosing any fault, and the first is to isolate it. Remove anything that might be contributing to the problem until you have the most basic configuration possible that still fails. Obviously fft3dgpu won't survive user-switching (!!!!) - the status of the GPU is not preserved across user-states. The miracle of fft3dgpu is that it works at all, as it's running on such a wide range of different hardware while interfacing through DirectX while the host processor and bus is running flat-out. If it works, great, if it doesn't just use the original host version. |
15th January 2006, 00:51 | #125 | Link |
clueless n00b
@Pasqui: as soon as I upload my latest sources, the FPS indication will be back for those locales not using a dot as decimal separator.
15th January 2006, 01:05 | #126 | Link |
clueless n00b
hot damn.. CVS is screwing me again.. tortoise crashes when I try to run an update and pretty much anything.. how the heck am I suppose to add my changes now?
15th January 2006, 01:11 | #128 | Link |
clueless n00b
based on the build I last checked in.. so that's 2012. I'm not quite sure what I'm supposed to do now.. I have 28 changes files.. I managed to add the new ones, and that doesn't break anything, but I'm scared as hell to do anything else and break everything.
15th January 2006, 01:39 | #129 | Link |
Gee, 2012 is quite a long time ago...
One thing you could do, but I know you're not going to like it, is start a new folder with the latest source, and individually merge each file (assuming you have WinMerge, it's not TOO hard a job). Alternatively, I've just generated a patch from version 2012 to 2023, so perhaps that could be applied to your version. Maybe that would be slightly less work |
15th January 2006, 01:40 | #130 | Link |
clueless n00b
@berrinam: please have a look here: http://forum.doom9.org/showthread.php?t=95863&page=63 . And do you have MSN?
15th January 2006, 12:42 | #133 | Link | |
I should copy that Decomb.dll somewhere. EDIT: Okay, now I know what's going wrong. It's not the decomb.dll, but it seems that AviSynth doesn't support Unicode characters in directory names. Look, I'm using a spanish Windows system, and the 11th line in the temporary autodeinttemp-avs.avs fails: <snip> file="C:\Documents and Settings\AgentX\Configuración local\Temp\interlace.log" <snip> c = WriteFile(c, file, "a", "sep", "b") <snip> Being a spanish system, there's a "ó" and a several spaces in the filename. One of these make trouble. BTW, I'm using AviSynth 2.56 (sep 4 2005). Temporary solution, use file="%SystemDrive%\interlace.log". Last edited by AgentX; 15th January 2006 at 13:22. |
15th January 2006, 12:56 | #134 | Link | |
clueless n00b
15th January 2006, 13:24 | #136 | Link |
clueless n00b
btw, here are two known and already fixed (not yet in the CVS) bugs:
1) FPS indication for xvid_encraw is completely wrong in the queue 2) elapsed and projected end time can go out of whack in video encoding and muxing.
15th January 2006, 14:02 | #137 | Link | |
I've put a lot of error catching around, because no AviSynth bug should cause MeGUI to crash. |
15th January 2006, 21:12 | #138 | Link | |
16th January 2006, 06:32 | #139 | Link |
In the Audio Encoding section setting a encoding profile then switching to Audio Radio button 2 will set the same profile. Changing the profile will then also change it for radio button 1.
In the MP4 muxer Audio section setting a name then switching to radio button 2 will keep the same name. Changing the name will then also change it for radio button 1. This happens in 2.3.2024 as well. |
16th January 2006, 07:58 | #140 | Link |
meGUI finishes the job in 1-2 seconds...
I hope I've posted in the correct thread...
I'm using all the latest versions: meGUI 14th Jan Version, DGIndex 1.4.6b4, x264 13th Jan Version. Here is the script created using AviSynth script generator : LoadPlugin("N:\Softwares\Audio-Video-related\Video related\DVD_related\XviD_Encoding_Tools\dgmpgdec146b4\dgdecode.dll") mpeg2source("M:\DVDs\Indiana Jones & The Last Crusade\Indi_3.d2v") tfm(d2v="M:\DVDs\Indiana Jones & The Last Crusade\Indi_3.d2v").tdecimate() #crop LanczosResize(720,320) #denoise Here is what MeGui says after doing Deinterlacing Analysis: Source type: Source is declared telecined. Source is declared tff by a margin of 234 to 15. & then it automatically chooses TIVTC option... When i press preview...there is nothing in it...just a thin black stripe... Then I saved the script, queued it, clicked Srart...it finished in 1-2 seconds giving me this error: avis [error]: unsupported input format (DIB ) could not open input file 'M:\DVDs\Indiana Jones & The Last Crusade\Indi_3.avs' desired video bitrate of this job: 1298 kbit/s - obtained video bitrate: 0 kbit/s Here is a complete log from meGUI: Next job job2 is a video job. encoder commandline: --bitrate 1298 --ref 3 --no-fast-pskip --bframes 3 --b-pyramid --b-rdo --bime --weightb --subme 6 --trellis 1 --analyse all --8x8dct --me umh --progress --no-psnr --output "M:\DVDs\Indiana Jones & The Last Crusade\Indi_3.mkv" "M:\DVDs\Indiana Jones & The Last Crusade\Indi_3.avs" successfully started encoding of job job2 job commandline: --bitrate 1298 --ref 3 --no-fast-pskip --bframes 3 --b-pyramid --b-rdo --bime --weightb --subme 6 --trellis 1 --analyse all --8x8dct --me umh --progress --no-psnr --output "M:\DVDs\Indiana Jones & The Last Crusade\Indi_3.mkv" "M:\DVDs\Indiana Jones & The Last Crusade\Indi_3.avs" ---------------------------------------------------------------------------------------------------------- Log for job job2 avis [error]: unsupported input format (DIB ) could not open input file 'M:\DVDs\Indiana Jones & The Last Crusade\Indi_3.avs' desired video bitrate of this job: 1298 kbit/s - obtained video bitrate: 0 kbit/s ---------------------------------------------------------------------------------------------------------- I searched what is TIVTC in the forum, downloaed it & put the dll in avisynth plugin folder & also in the meGUI folder...but still the same thing...same error... Just 2 days back I successfully encoded War of the Worlds using the meGUI ...but this time its not working... am I doing somthing wrong guys ?? pls Help me... Last edited by Avish; 16th January 2006 at 08:05. Reason: doubtfull about the correct thread... |
