20th August 2012, 18:52 | #12022 | Link | |
On the other hand you're sure this movie is interfaced.... Humm....strange ...why do you think it's interlaced at all ? Did you have the same problem with NVidia cards ? Was deinterlacing ON are OFF in MadVR ? |
20th August 2012, 21:03 | #12023 | Link | |
All indicate interlaced in MadVR, also in MediaInfo. All other file formats are good (all MKV container tests) UPDATE: 99% of material is actually progressive, there is an "interlaced" blip at the beginning that signals "interlaced" with MadVR even though most of the material is progressive. Force MadVR deinterlacing off and results are good. Problem is seen with AMD Radeon and NVIDIA GeForce GPU's
MPC-HC and MPC-BE (latest), MadVR 0.92.17, LAV 0.73.1 Intel NUC w_650 internal, Roku Ultra, Nvidia Shield, Apple TV 4K PLEX Server with QUADRO 2000 Windows 10 Pro (all latest updates) Last edited by blackjack12; 21st August 2012 at 01:51. |
21st August 2012, 01:43 | #12024 | Link | |
Madshi, The final MPEG2 “interlaced” (but not really) material issues. - DVD material rips direct with MakeMKV ver 1.7.6 or 1.7.7 Radeon 6570 GPU, ver. 12.8 drivers (Now see same on NVidia 560Ti and GT525M systems) MadVR is “BAD” Reports deinterlacing on : force off and is “GOOD” … (2) EVR/EVR-CP is “GOOD” Can actually see the FPS jump a little at beginning that looks like interlaced then goes to 24fps. An interlaced beginning blip that triggers MadVR and MediaInfo reads but EVR ignores or plays through. MediaInfo shows material as interlaced but the reason that I did not include samples is because when I used MKVMerge to create clip of credits where easy to see, the clip now indicates progressive. I can’t link or upload the entire rip for you to see and test. But this happens on almost all the files. They indicate interlaced, but break them up and now have a “progressive” clip that plays fine. Even tried re-ripping with absolute newest MakeMKV to see if that was issue but all show same result. So the interlaced flag that looks like is a quick blip in the beginning is being seen and responded to by MadVR but EVR “ignores”? and plays correctly. Did not upload samples but here some DVD’s that I had that easily showed the issues: (ripped with MakeMKV ver 1.7.7)
I then used the latest MKVMerge and clipped the first 30 seconds off the ripped material to see if could get rid of the “interlaced” blip and it did! Now the files play as progressive without issue. The “interlaced” blip at the beginning causes the entire video to be seen as “interlaced” by MadVR when in fact it is not. ... I think may be in the beginning logo, quick check and I found a lot of problem DVD's were from Columbia Pictures. With more thorough searching probably can find more connections. A similar issue with the “Good Year” clip that switches to “interlaced” after 10 seconds, but all of these have an interlaced blip at the very beginning of the video. Note: See the exact same behavior with NVidia/CUVID with 560Ti and GT525M systems. UPDATE NOTE: Clipping off 1.0-20 sec at the beginning of the MKV file got rid of the "interlace blip" on most files and they indicated deinterlacing off with MadVR and progressive in MediaInfo in MPC-HC - and played without issue. Columbia logo had interlace blip in the "middle" of intro on some files and had to clip out entirely. The "old" intro logos are crappy and cause most of the problems ... Not practical but it worked ... Really need MadVR to address this. EVR/EVR-CP allows these files to play correctly.
MPC-HC and MPC-BE (latest), MadVR 0.92.17, LAV 0.73.1 Intel NUC w_650 internal, Roku Ultra, Nvidia Shield, Apple TV 4K PLEX Server with QUADRO 2000 Windows 10 Pro (all latest updates) Last edited by blackjack12; 21st August 2012 at 03:42. |
21st August 2012, 16:33 | #12026 | Link | |
Let me know if you want/need some sample material to test but for this if you have a number of ripped DVD's using MakeMKV which contain the original MPEG2 material it shouldn't be hard to find some with problems. Especially older DVD's. I also wanted you to know that on the very few files/DVD's that are actually interlaced material, the MadVR deinterlacing quality was just phenomenal in comparison to anything else tested.
MPC-HC and MPC-BE (latest), MadVR 0.92.17, LAV 0.73.1 Intel NUC w_650 internal, Roku Ultra, Nvidia Shield, Apple TV 4K PLEX Server with QUADRO 2000 Windows 10 Pro (all latest updates) |
21st August 2012, 17:07 | #12027 | Link | |
If Cuvid is de-interlacing, MadVR should not detect.
4gb DDR3/AMD Fx6300 Windows 8.1, GT750ti, Auzentech Meridian 7.1, LG 42LN5400 4:4:4 1080P LCD TV |
21st August 2012, 18:22 | #12028 | Link | |
If you turn on with "adaptive" then MadVR will/should see "progessive" and not turn on deinterlacing. If you do this I strongly recommend turning off or unchecking deinterlacing with MadVR. If you don't I have seen many times conflicts and very bad results. My experience is that you really have to choose ... MadVR for deinterlacing or LAV/CUVID only. When I have time will post all settings for both AMD and NVIDIA setups and hopefully others can avoid some of the hit and miss struggles I have had over the past months ... Note: I have seen quite large differences between the 560Ti and GT525M in some fundamental decoding with LAV/CUVID and am not sure why. Because I have 2 systems in HTPC setups with the Radeon 6570 cards I have not focused a lot on the NVIDIA setups yet as they are in computers not being used as HTPC's.
22nd August 2012, 13:19 | #12029 | Link |
Hello everyone,
I'm looking for a h264 sample video file, preferbly TS, with very high bitrate (above 40.000Mbit/s). I would really appreciate it if somebody could post one, I already searched the internet for some time without finding anything usefull best regards Sebastian |
22nd August 2012, 15:33 | #12030 | Link | |
http://tinyurl.com/KillaSampla http://rapidshare.com/files/82525583/killa.sampla.x264.mkv.html |
22nd August 2012, 15:47 | #12031 | Link | |
There are some bluray movies that have a video bitrate slightly higher than 40mbit/sec; which the m2ts files can be remuxed to ts such as "28 Days Later...". Just remux the movie .m2ts file to .ts. However, I haven't found anything readily downloadable.
Since you didn't mention video resolution, below, is a 2160p roasted duck H.264 (50mbit/s) video in ts container. Plays back fine on my PC (Nvidia GT640). http://www.sendspace.com/file/a1b8ty Quote:
24th August 2012, 02:31 | #12034 | Link |
nevcairiel,
Feature request: When DTS bitstreaming is enabled (and DTS-HD MA is not) and DTS-HD MA is the source input for LAV Audio Decoder, would it be possible to send the DTS Core to bitstream instead of simply sending PCM and bypassing the bitstream option? Te reasons for this is I have an ASUS EN9500GT and unfortunately it doesn't support 8 channel LPCM OR DTS-HD MA so the only other choices in this case are DTS bitstream or 2 channel LPCM and 2 channel LPCM is not acceptable obviously. I plan to upgrade to something much better soon but until then I'm hoping that LAV Audio Decoder can perform this workaround instead of me having to disable LAV Audio and bitstream the DTS Core through ffdshow audio decoder. Thanks for LAV! Last edited by dansrfe; 24th August 2012 at 02:35. |
24th August 2012, 07:01 | #12035 | Link | |
I'm quite positive it should.
24th August 2012, 16:59 | #12037 | Link | |
FFdshow supports both, while LAV supports only DSHOW. So if Goldwave uses these acm's instead of DShow, you're out of luck and only FFDshow can work. Last edited by Pat357; 24th August 2012 at 23:25. Reason: Correction to audio |
24th August 2012, 17:19 | #12039 | Link | |
EDIT: Yeah LAV Audio bitstreams the DTS Core when I select "DirectSound ... S/PDIF Front..." and when I select ReClock with bitstream passthrough over WASAPI excl. |
