31st July 2008, 15:45 | #5641 | Link | |
Do I designate RAW or PCM or LPCM as the output format in eac3to? Literally, what should I type in? |
31st July 2008, 17:05 | #5643 | Link | |
b4k3d
http://forum.doom9.org/showthread.php?t=137354 |
31st July 2008, 21:41 | #5644 | Link |
The Interpreter: -seekToIFrames not working?
Remuxing The Interpreter yields:
Unfortunately the Haali Muxer cannot handle this source file. It doesn't contain enough seek/recovery points. Code:
eac3to v2.56 command line: eac3to I:\ 1) 3: "C:\The Interpreter (2005).mkv" 4: "C:\The Interpreter (2005).eac3" -seekToIFrames ------------------------------------------------------------------------------ EVO, 1 video track, 5 audio tracks, 5 subtitle tracks, 2:08:25 "Main Movie" 1: Joined EVO file 2: Chapters, 20 chapters with names 3: h264/AVC, 1080p24 /1.001 (16:9) with pulldown flags 4: E-AC3, English, 5.1 channels, 1536kbit/s, 48khz, dialnorm: -27dB 5: DTS, English, 5.1 channels, 24 bits, 1536kbit/s, 48khz, dialnorm: -4dB 6: E-AC3, Spanish, 5.1 channels, 768kbit/s, 48khz, dialnorm: -27dB 7: E-AC3, French, 5.1 channels, 768kbit/s, 48khz, dialnorm: -27dB 8: E-AC3, English, 2.0 channels, 192kbit/s, 48khz, dialnorm: -27dB "Feature Commentary" 9: Subtitle, English, "SDH" 10: Subtitle, Spanish 11: Subtitle, French 12: Subtitle, Spanish, "Forced" 13: Subtitle, French, "Forced" [v03] Extracting video track number 3... [a04] Extracting audio track number 4... [v03] Muxing video to Matroska... [a04] Removing dialog normalization... [a04] Creating file "C:\The Interpreter (2005).eac3"... Unfortunately the Haali Muxer cannot handle this source file. It doesn't contain enough seek/recovery points. Aborted at file position 352305152. |
1st August 2008, 08:59 | #5646 | Link |
@Madshi
We can't demux files to another location like - eac3to.exe C:\00001.m2ts D:\ -demux or eac3to.exe C:\00001.m2ts -demux D:\ & can you tell me how to get back exact raw VC1 stream after merging into mkv. Actually i accidently deleted backup file. Now i want exact raw VC1 stream demuxed from mkv. Last edited by sehgal.v7; 1st August 2008 at 14:42. |
1st August 2008, 12:34 | #5648 | Link |
Feature Request: BluRay -> MKV : Mux Audio
@madshi
It would be great if using the bluray (or HDDVD) to mkv muxing ability would also mux an or all audio tracks into the mkv with the video. Is this already possible and I just am missing how? I want to use eac3to l:\ j:\out.mkv and have audio in that output as well as the video track, but I do not see a way to do it. Thanks for creating the best HD audio conversion tool available! Keep it up. |
1st August 2008, 20:36 | #5649 | Link | ||
Aging Video Hobbyist
1st August 2008, 20:40 | #5650 | Link | |
However, you should be able to do everything in one go already. Just use the eac3toandmore GUI. |
1st August 2008, 20:53 | #5651 | Link |
too much lurking
When you right click on my computer you get a drop down menu. There are no tabs let alone one called "extended". I don't understand these instructions. If you select any of the options you see on the drop down menu there is still no extended tab anywhere.
1st August 2008, 21:08 | #5652 | Link | |
See if that sequence works for you. |
2nd August 2008, 00:36 | #5653 | Link | |
;C:\Program Files\eac3to Don't forget the semicolon delimiter and make sure that you use YOUR path to eac3to. Once this is done you go to a command prompt and the cd to the drive letter & directory you want your file to END UP in. For me, I always go to D: and process files from E: or vice-versa, to get a speed advantage from using different hard drives. |
2nd August 2008, 00:56 | #5654 | Link | |
On my Vista Premium it's: Right Click Computer -> Advanced system settings -> Advanced Tab -> Environment Variables |
3rd August 2008, 01:38 | #5656 | Link |
Hey, has anyone successfully used eac3to with the region a BR of Mr & Mrs Smith?
The reason I ask is that when I use eac3to to look at the BR directory, and then choose option 1 (the only option) I get this message... C:\EAC3to\eac3to d:\hidef\mrmrssmith 1) The program channel mapping changes in the middle of the stream. The program channel mapping changes in the middle of the stream. The program channel mapping changes in the middle of the stream. The program channel mapping changes in the middle of the stream. The program channel mapping changes in the middle of the stream. The program channel mapping changes in the middle of the stream. The program channel mapping changes in the middle of the stream. The program channel mapping changes in the middle of the stream. The program channel mapping changes in the middle of the stream. The program channel mapping changes in the middle of the stream. The program channel mapping changes in the middle of the stream. The program channel mapping changes in the middle of the stream. The program channel mapping changes in the middle of the stream. The program channel mapping changes in the middle of the stream. The program channel mapping changes in the middle of the stream. The program channel mapping changes in the middle of the stream. The program channel mapping changes in the middle of the stream. The program channel mapping changes in the middle of the stream. The program channel mapping changes in the middle of the stream. The program channel mapping changes in the middle of the stream. The program channel mapping changes in the middle of the stream. The program channel mapping changes in the middle of the stream. The program channel mapping changes in the middle of the stream. The program channel mapping changes in the middle of the stream. The program channel mapping changes in the middle of the stream. The program channel mapping changes in the middle of the stream. The program channel mapping changes in the middle of the stream. The program channel mapping changes in the middle of the stream. The program channel mapping changes in the middle of the stream. The program channel mapping changes in the middle of the stream. The program channel mapping changes in the middle of the stream. The program channel mapping changes in the middle of the stream. The program channel mapping changes in the middle of the stream. M2TS, 1 video track, 6 audio tracks, 6 subtitle tracks, 1:59:59 1: Chapters, 33 Chapters 2: h264/AVC, 1080p24 /1.001 (16:9) 3: DTS Master Audio, English, 5.1 channels, 24 bits, 48khz, -9ms 4: AC3, French, 5.1 channels, 448kbit/s, 48khz, dialnorm: -27db, -24ms 5: AC3, Spanish, 5.1 channels, 448kbit/s, 48khz, dialnorm: -27db, -24ms 6: AC3, English, 2.0 channels, 224kbit/s, 48khz, dialnorm: -27db, -24ms 7: AC3, English, 2.0 channels, 224kbit/s, 48khz, dialnorm: -27db, -24ms 8: AC3, English, 2.0 channels, 224kbit/s, 48khz, dialnorm: -27db, -24ms 9: Subtitle (PGS), English 10: Subtitle (PGS), Spanish 11: Subtitle (PGS), Chinese 12: Subtitle (PGS), Korean 13: Subtitle (PGS), French 14: Subtitle (PGS), Spanish I did a search on this thread, but couldn't find any answers. |
3rd August 2008, 08:54 | #5658 | Link | |||||||||
http://madshi.net/madTraceProcess.zip That will output a report of where eac3to is stuck. Can you please upload that report somewhere? Or you can also mail it to dear (at) madshi (dot) net. Thanks! Quote:
eac3to doesn't output m2ts. It only supports m2ts as an input format. Check out TsRemux and TsMuxer. I think both of them do what you're looking for. |
3rd August 2008, 11:26 | #5659 | Link | |
When I want to remove dialogue normalisation with your wonderfull application, then I am 'forced' to detach the TrueHD stream from the core. Is there maybe an undocumented option to still remove the dialogue normalisation, but maintain the full track? If not, maybe this can be a future request for your excellent application. |
3rd August 2008, 11:34 | #5660 | Link | |
EDIT: correction; dtscore only accepts dts and wav files; so there should be a standalone filter Last edited by rica; 3rd August 2008 at 11:47. |
eac3to |
