19th October 2005, 14:29 | #761 | Link |
Unregistered User
@Kurt: You should again look at the files list processing, cause it is broken again in the last daily build.
Example: 1. File - Open - 1.mp3 - View BeSweet Command BeSweet.exe -core( -input "C:\Temp\2\1.mp3" -output "C:\Temp\2\1.aac" -logfile "C:\Temp\2\1.log" ) -dimzon( -dllname bse_WinampAacPlusV2.dll -cbr 32 -mode 1 -v 2 ) -ota( -hybridgain ) 2. Popup menu - Clear List 3. File - Open - 2.mp3 - View BeSweet Command BeSweet.exe -core( -input "C:\Temp\2\1.mp3" -output "C:\Temp\2\1.aac" -logfile "C:\Temp\2\1.log" ) -dimzon( -dllname bse_WinampAacPlusV2.dll -cbr 32 -mode 1 -v 2 ) -ota( -hybridgain ) See - in the list is 2.mp3, but in BeSweet CMD - 1.mp3
my subtitle site |
19th October 2005, 20:44 | #763 | Link | |
20th October 2005, 11:24 | #766 | Link |
Hi
Definitly doesnt work queue encoding . And is the Quit Button gone ?? I cant find a button to stop encoding Encoding stops not . It is at 1 second rest and the watch runs and runs I made two Pictures. First where the clock runs and runs and second that after 1 second beelight says after one second first job is done . second job makes he then. I am using Beelight 19.10 Build and Besweet 1.5b31 EDIT : If i only make 1 job to do - abort Buton is available and encoding works fine See on Picture 3. cu PLZ Approval my Attachements !! THX Last edited by humax; 20th October 2005 at 11:34. |
21st October 2005, 02:56 | #767 | Link |
Software Developer
Hi.
The latest Build (BeLight-0.22beta_20051019) makes the GUI look this way: // EDIT If I move the bitrate-slider in the AAC Tab (Winamp) the combobox below switches .style between csDropDownList and csDropDown. IMO there seems to be a problem, or is there a reason for this? Last edited by LoRd_MuldeR; 21st October 2005 at 03:02. |
23rd October 2005, 20:15 | #772 | Link |
DVD Magistrate
3 bugs, all after you hit start and GET TO THE TRANSCODE WINDOW.
1. The time elapsed and left have 12 in from of them...representing a clock, this is wrong....also AM is listed there. 2. If you try to resize the transcode log big dialog box the red cancel button does not move to the right place...it ends up over the time left bars. 3. Again in the transocde window area if you try to move over the information components so you can see them (the box above the progress bars) they will bounce back thanks!!!! |
28th October 2005, 12:43 | #776 | Link |
digitally remastered
we are currently working on a better german translation at Doom9 | Gleitz DVD-Forum. A few issues:
You can find the latest translation in this thread (German forum).
May The FourCC Be With You |
29th October 2005, 10:11 | #780 | Link | |
Newly discovered issue: In AAC Encoding Tab the descriptions aren't sourced out to the .ini, is that right? This concerns FAAC and Winamp encoder. You (all) can find almost every day an updated version of Deutsch.ini in the thread mentioned above.
