Old 9th August 2005, 16:51   #221  |  Link
TNM
CG Movies Freak
TNM's Avatar
Umm... the link to YAMB alpha version no longer works... can any1 host it again pls?
TNM is offline
Old 9th August 2005, 17:07   #222  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Here you go: -
YAMB v1.3 alpha1 v1 and YAMB v1.3 alpha1 v2
Cheers
SeeMoreDigital is offline
Old 16th August 2005, 22:14   #223  |  Link
Peter1234
I am getting audio synch problem when muxing. I want to convert avi container to mp4 container. This is what I did:
1. Generated x264 video with mp3 audio in avi container. This file plays fine in WMP, MPC, WinDVD, and VLC players.
2. Used YAMB v1.3 alpha1 v2 to extract video and audio into separate MP3 and H264 files.
3. Used BeLight to convert MP3 to ACC (new file has MP4 extention)
4. Used YAMB v1.3 alpha1 v2 to mux H264 and MP4 files into single new MP4 file with audio and video. Tried with and without interleavig (0 ms).
5. Resulting file plays in MPC but audio and video are not in synch.
What am I doing wrong?
Peter1234 is offline
Old 16th August 2005, 23:17   #224  |  Link
bond
i assume you didnt set the correct framerate (by default 25fps is used)
also there is no need to reencode from mp3 to aac, as you can place mp3 in mp4 too (best would be to encode from your original source to aac directly of course)
Ogg Theora | Ogg Vorbis
bond is offline
Old 17th August 2005, 00:16   #225  |  Link
Peter1234
bond:
Thanks. You are correct, I did not set the frame rate. Where do I set it? I do not see any options in the YAMB GUI so I assume I need to edit the command line. What do I need to add to the command line to set fps to 29.97? I did a search for mp4box commands, and it looks like I should add "-fps 29.970". But that did not work when I added it to the end of the command line.
EDIT: I found the option for setting frame rate in YAMN GUI, on Import button settings. But it audio is still not in synch.
Old 17th August 2005, 01:56   #226  |  Link
jellysandwich
Originally Posted by Peter1234
bond:
Changing the frame rate through the import
button does not change the cmd line at all.
Your file should still be 25fps.
On the other hand, adding "-fps 23.976" works
fine for me.
On a side note, it'd be nice if you could post
Yamb revisions along with known working
Mp4box revisions. For example, Yamb v1.3
alpha1 v2 doesn't work with Mp4box 0.4.0.
That took me a good hour to figure out.
js
jellysandwich is offline
Old 17th August 2005, 02:50   #227  |  Link
Peter1234
jellysandwich:
Thanks for the feedback. I generated a 25fps file and split it and muxed as per steps above and it worked fine. I will try a 23.976 fps file and see what happens. For some reason, the 29.97 fps file does not work.
EDIT:
I generated a 23.976 fps file and split it and muxed as per steps above and added -fps 23.976 to end of command line and the muxed file was OK. I will retry 29.97 file again and see what happens. Thanks for your help.
EDIT:
I generted a 29.97 fps file and it worked also. I must have made a typing error when I edited the command line before. It would be nice to have a Frame Rate box whose value was saved in an ini so that it was not necessary to modify the command line each time. I am using the MP4Box version that came with YAMB 1.2.1 installer version (I am not sure which version that is) and YAMB v1.3 alpha1 v2.
Old 17th August 2005, 21:23   #228  |  Link
jellysandwich
Weird. I had problems using the version that came with 1.2.1. Oh well, at least it works now.
And congrats on your working files.
js
Old 18th August 2005, 17:04   #229  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
It's for a good reason if I decided to break this link...
Alpha versions are only useful for people who have troubles with the YAMB borders. Otherwise, use the 1.2.1 or wait the next update.
Kurtnoise is offline
Old 18th August 2005, 17:31   #230  |  Link
SeeMoreDigital
Hi Kurt... welcome back
Do you have a link to version 1.2.1... or would you like me to host it for you?
Cheers
Old 18th August 2005, 18:04   #231  |  Link
Doom9
clueless n00b
It's in my download archive.. and there's a guide for it.
Doom9 is offline
Old 18th August 2005, 18:30   #232  |  Link
SeeMoreDigital
Thanks Doom9......And for all those who are unable (or can't be bothered) to search....
For YAMB 1.2.1, click here. And for the YAMB guide, click here.
Cheers
Old 18th August 2005, 21:16   #233  |  Link
Kurtnoise
Kurtnoise's Avatar
Hi SMD...I'm not back. Tomorrow, I'm going to travel in Irlande for 2 weeks.
http://kurtnoise.free.fr/Yamb/ or Doom9 dl area, yes.
...there's a guide for it.
Sounds great...Thanks again.
well...I must confess that I need to update my first post in this thread.
Old 18th August 2005, 21:32   #234  |  Link
Doom9
clueless n00b
we have rule1 for that
Doom9 is offline
Old 18th August 2005, 21:45   #235  |  Link
SeeMoreDigital
Indeed,
Originally I was thinking of writing
And for all those who are unable, or can't be bothered to search (for which you should be flogged)....
But thought better of it...
Cheers
Old 26th August 2005, 09:08   #236  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
Can I make a couple of suggestions for when you get back from vacation?
The main one is that it'd be awesome if YAMB would remember what was typed in the command line pane when you flip back and forth (including the automatic flip to mux). That way I don't have to keep reentering fps. (I just noticed that your alpha has a method of selecting frame rate, cool.)
Also, when started with multiple monitors side-by-side, it always starts in the middle of the two, ie, half on one and half on the other.
It's a really cool frontend though, I really like it. =D
foxyshadis is offline
Old 30th August 2005, 12:29   #237  |  Link
Kurtnoise
Kurtnoise's Avatar
Sure...I'm back now.
mmh...If I understand correctly, you would like to have your previous command line as soon as you reload Yamb ?
Funny... Can I have a snapshot ?
Old 30th August 2005, 16:32   #238  |  Link
Koti
Always trying
Koti's Avatar
here ya go
Koti is offline
Old 31st August 2005, 00:04   #239  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
Actually just from tab to tab. Like, change the command in mux, click on splitting & joining, and the command line changes to reflect the split, then click back to mux and any customizations made before are lost. It'd probably be a little easier if the command part only reset when something was changed or loaded in the GUI portion.
Old 31st August 2005, 08:12   #240  |  Link
Kurtnoise
Kurtnoise's Avatar
Ok...I see.
For Joining, there are no options, so it's easy.
For Splitting : no problem. I can save the settings choosen.
For Muxing : it might be too hard. Especially with the Import Options applied to different streams.
All in all, I can add also a line to save the last Tab viewing. Thus, as soon as you reload Yamb, you will be directly in this Tab.
