Old 14th August 2010, 16:39   #10421  |  Link
nurbs
Originally Posted by [)370|\|470!2 View Post
Let me get this straight you're claiming that extension is a problem there?
No, I'm thinking something went wrong during demuxing the .m2ts files, which is why I asked what software you used to demux the audio. If it was eac3to you'd end up with a .thd extension, so you either renamed it or you used something else. I'd be interested in how you ended up with the file so I'll know how to avoid such problems.
So, have you found time to try if reencoding the audio straight from the .m2ts without demuxing it first works?
Old 15th August 2010, 08:43   #10422  |  Link
xkodi
Originally Posted by AnryV View Post
Will be anything made with the decoding of "strange setup" 7.1?
solution for that problem was finally found:
http://forum.doom9.org/showthread.php?t=156168
actually, that approach could be used for every DTS-HD (MA) file that Arcsoft can't decode correctly and respectively eac3to can't.
i wish eac3to be able to write such 140 bytes headers for easier decoding of DTS-HD (MA) file outside eac3to in case that is necessary.
xkodi is offline   Reply With Quote
Old 15th August 2010, 08:47   #10423  |  Link
sub24ox7
Audiophile
sub24ox7's Avatar
yes PLEASE!!! that would be so awesome I can't decode a DTS-HD mono track at this very moment
never give up or at least die trying
sub24ox7 is offline   Reply With Quote
Old 15th August 2010, 12:12   #10424  |  Link
madshi
Originally Posted by tvjunky View Post
Maybe this is a bug in eac3to:
I always rip my BRs directly with eac3to like this:
eac3to d: 1) -demux
This was functioning for 100% of my BRs the last years. With the new version 3.22 i get the following error on ~50% of my discs
That's weird. I have a hard time believing that the new eac3to is responsible for the problems. Maybe something else changed on your PC? It seems nobody else has this problem.
Originally Posted by lintran View Post
I just tried extract DTS-ES Discrete 6.1 to wav(input.dts output.wavs) with Arcsoft Decoder (version 3.0.160) and it produced 7 individual WAV files, but there was something wrong with them. Too much high-frequency and noise.
Arcsoft decoder cannot properly decode 6.1 dts. I had the same problem.
Newer versions (e.g. 1.1.0.7) of the dtsdecoder.dll seem to have this problem. Older versions (e.g. 1.1.0.0) work just fine.
Originally Posted by deathlord View Post
Could you allow for longer -edits, in particular silence? At the moment the maximum possible (positive) edit seems to be 4999ms.
Yes, will change that.
WARNING:
- When the language field of a track (in mkv) is empty this mean the language is the default: eng (from MkvMerge v4.0.0)
- eac3to don't manage audio tracks (MP2/MP3/DTS/AC3?) from mkv's generated with MkvMerge v4.1.0 defaults (header compression).
- eac3to crash (without messages) with video track H264 from mkv's generated with MkvMerge v4.2.0 defaults (header compression).
@madshi
Do you have any plan to support these new defaults?
Yes.
Originally Posted by mastrandrea View Post
Hi, is there a way to stretching an audio file to a given time?
In my case I would like to stretch a track by adding 400ms to it, is it possible with eac3to?
It is not possible with eac3to because the resampling library is limited to specific stretching factors.
An audio file (dts, ac3, ...) don't have tags about the video fps, only have a duration. And aply a -24.000 -changeTo23.974 means only modify the duration with a coefficient of 1.001
With audio files -slowdown means modify the duration with a coefficient of (1001/960) always.
FWIW, "-slowdown" always defines a target FPS value of 23.976. You can do "-24.000 -slowdown" and it will do a 24.000 -> 23.976 slowdown.
Originally Posted by dbone1026 View Post
I have a Blu Ray disc of a tv show (Supernatural Season 1, Disc 1). The disc has the first 6 episodes of the tv show. When I run the disc through eac3to (using Clown_BD and/or Ripbot) eac3to only picks up 3 playlists (the 1st playlist is of all episodes, the 2nd playlist is of episode 1, and the 3rd playlist is of episode 2). Episode 3-6 don't show anywhere. If I use MakeMKV I can see all episodes listed out individually to select. Is there anything you can think of that would be causing this issue?
I've seen this before and just thought that there were not any playlists for the other episodes. But maybe there are and there's a bug in eac3to. Can you please zip up the playlist and clipinf folders for me?
The decoding by libav under XP failed too.
What this can be?
Broken TrueHD track.
Originally Posted by mr.duck View Post
eac3to cannot fully demux my TS files (from DVB-T, UK).
Unlike other programs like tsMuxeR, eac3to at least recognizes that there are subtitles there. But -demux only extracts the video and audio.
I don't know how to demux DVB subtitles in any format that can be used by other applications.
Also when I -demux some <path>\video.ts, it extracts the audio and video to the same folder as eac3to.exe, not the video file folder and no other way of setting the output to another folder. Pretty annoying.
Just use "eac3to source c:\whatever\movie.*" that will demux all tracks to any desired target path.
How do I see which episode is which?
Often there's a "play all" playlist. It usually lists the episodes in the right order.
Originally Posted by crl2007 View Post
Sometimes, when I join multiple m2ts files and demux the streams, the end result shows 13 hours as duration.
Simply joining multiple m2ts files makes problems because after joining it is not possible for eac3to (or any other program) to quickly see that the file was joined from multiple smaller files and that the timestamps do not match and where each smaller file starts and ends in the joined file. This is the way it is. If you manually join m2ts files, you'll have to live with this effect.
Originally Posted by nibus View Post
Can eac3to demux DTS Express audio tracks?
Yes.
Originally Posted by Laurent View Post
I come back to this problem with more explanations and tests. In fact, the problem is not new, I just verified and I have the same strange behaviour with eac3to v3.21 and eac3to v3.18.
Here is my scenario:
1 - eac3to to demux video in MKV container and convert audio to AC3
2 - TsMuxer to mux audio and video in a M2TS container
3 - playback of the M2TS file with the PS3
Video is H.264. When the file is decoded by the PS3, I have many macroblocks, and the result is the same whatever the version of eac3to (3.18, 3.21 and 3.22).
If at step 1, instead of demuxing video in MKV container, I demux the video in a H.264 file, then the playback with the PS3 is fine without macroblocks.
Note that all these files (M2TS and MKV) are played correctly on the PC.
So the problem is relative to the usage of MKV container, either when produced by eac3to, or when used as input by TsMuxer. And the problem is noticeable only when the final file is played with the PS3.
If you do this:
(1) demux blu-ray directly, by using eac3to
(2) mux video to MKV by using eac3to, then demux again by using eac3to
The demuxed raw h264 video file produced by both methods is identical. So the problem must obviously be caused by tsMuxeR not handling MKV input correctly.
Old 15th August 2010, 14:58   #10425  |  Link
madshi
eac3to don't remove the dialog normalization with Arcsoft decoder (1.1.0.1)
Test .dtshd
http://multi-up.com/295013
DNorm.rar - center before and after decoding.
I've checked this and all decoders output the same volume - even libav which definitely doesn't do dialnorm processing for DTS when eac3to removes it from the headers. I believe that the volume was already changed (hard coded) by the DTS encoder. And I believe that ArcSoft totally ignores the dialnorm when decoding.
One key information is that decoding the track with ArcSoft and Sonic decoders output bit perfect identically results. Which means that decoding should be lossless which would not be the case if dialnorm processing was active.
Old 15th August 2010, 15:04   #10426  |  Link
madshi
Originally Posted by Momber View Post
I just noticed that a bug which I had reported months ago is still present.
The mapping of 3.0 soundtracks converted to flac is incorrect. The center channel ends up in the left surround.
This time the source was DTS MA 3.0 (last time: PCM 3.0), as found on the Criterion BluRays of Yojimbo and Sanjuro, so I don't think it's a decoder problem.
When creating Mono-Wavs instead of flac, the three tracks are correctly titled L, R and C.
The FLAC is correct. The latest madFlac v1.9 now also outputs the correct channelmask (0x7). The previous version used channelmask 0xffffffff. If you still get incorrect channel assignments then it's the fault of some other filter, maybe even the audio renderer. eac3to and madFlac definitely handle 3.0 correctly now.
Old 15th August 2010, 15:22   #10427  |  Link
madshi
I've checked. There's no specific limitation for the "-edit" command. You cannot edit in such a way, though, that looping wouldn't work. E.g. "-edit=0:00:01,+2000ms" is not allowed, but "-edit=0:00:05,+2000ms" works just fine.
Old 15th August 2010, 20:19   #10428  |  Link
madshi
Originally Posted by Snowknight26 View Post
Was able to find a small enough sample to be able to reproduce the issue:
http://stfcc.org/misc/eac3to.aac.issue.zip
Run the bat, wait for eac3to to stop outputting. Might be a while, but it will. Either put the two files in the folder eac3to is in or modify the bat.
I think I got a fix for this one. Could you please try with the next eac3to build and report back?
Old 15th August 2010, 20:58   #10429  |  Link
madshi
Originally Posted by Blue_MiSfit View Post
I'm seeing odd behavior with Battleship Potemkin, a newly restored BluRay release from Kino.
Thanks for the upload, the problem will be fixed in the next build.
Old 15th August 2010, 21:06   #10430  |  Link
madshi
@madshi
can you add option to automatically ignore .m2ts in playlist if number of audio channels is not constant. In this example also frame rate is different in first file.
Movie Downfall
eac3to v3.22
1) 00014.mpls, 00034.m2ts+00014.m2ts, 2:35:21
   - Chapters, 35 chapters
   - VC-1, 1080p24 /1.001 (16:9)
   - AC3, German, stereo, 48kHz
00034.m2ts
M2TS, 1 video track, 1 audio track, 0:00:37, 29.766p
1: Chapters, 35 chapters
2: VC-1, 1080p24 /1.001 (16:9)
3: AC3, German, 2.0 channels, 192kbps, 48kHz, dialnorm: -27dB
00014.m2ts
M2TS, 1 video track, 1 audio track, 0:00:29, 24p /1.001
1: VC-1, 1080p24 /1.001 (16:9)
2: AC3, German, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB
Hmmmmm... This is a difficult one. Sometimes there might be a small intro with different channels before the real movie which I could easily ignore without doing any damage. But then there might be movies where actually different parts have different audio tracks (e.g. seamless branching theatrical cut vs. director's cut). How can eac3to know? E.g. if the first m2ts file is 10 minutes long, shall I still cut it away? For an intelligent human it's not so difficult to find out whether an m2ts file can be dropped or not, but for a computer program it's much more difficult. I fear that if I simply drop the first m2ts file if it has different audio track properties, then I might damage some real movies.
Thoughts?
(BTW, the frame rate is not different, eac3to is more or less "guessing" the m2ts framerate, it's sometimes wrong. The video track framerate is reliable and it's identical.)
Old 15th August 2010, 21:11   #10431  |  Link
madshi
eac3to v3.23 released
http://madshi.net/eac3to.zip
* fixed: handling of MKV files with header compression didn't work
* fixed: track listing of some Blu-Rays failed silently
* added support for decoding mono tracks with ArcSoft DTS decoder
* added reading support for DTS tracks with additional DTS-HD header
* improved m2ts framerate detection
* video bitdepth is displayed now, if different than 8 bits
* chroma format is displayed now, if different than 4:2:0
Old 15th August 2010, 21:17   #10432  |  Link
b66pak
b66pak's Avatar
thanks a lot...
Thoughts?
keep it as it is...or you will open a pandora box!..
_
if you ask a question and somebody give you the correct answer don't forget to leave a "thank you" note...
Visit The Land Of Dracula (Romania - EU)!
Old 15th August 2010, 21:20   #10433  |  Link
Thunderbolt8
thanks for the new version again
a few questions: what would be the problem if you left all those small .m2ts files listed? a overly long amount of different playlists? is there maybe any way to say that eac3to should list, and not cut away, all small .m2ts files of certain playlists only, e.g. such playlists which contain the 2-3 biggest .m2ts files? (sometimes, there are extras on a BD which are bigger than the actual movie)
regarding audio, so dtsma mono tracks should work now. so whats still left that doesnt work properly? what about those 6.1 dtsma/truehd/lpcm tracks? 2.0 dtsma? anything with "strange setup"? dts express afaik was a problem of non-existing mkvmerge support.
what are those dts-hd tracks with additional header, what does it mean? again, do we have to do any re-demuxing of our dtsma track collection to have compability with hardware receivers when just bitstreaming the file?
thanks!
Old 15th August 2010, 21:29   #10434  |  Link
madshi
There are many Blu-Rays with literally hundreds of playlists. You'd be burried by useless information.
No.
The only problem I'm aware of are those 7.1 tracks listed as "strange setup". Everything else, including mono, stereo and 6.1 should work perfectly, if you use the right ArcSoft decoder version (e.g. 1.1.0.0 works fine).
If you don't know what it means that you don't need it. No need to re-demux anything.
Old 15th August 2010, 21:48   #10435  |  Link
Thunderbolt8
If you don't know what it means that you don't need to do it. No need to re-demux anything.
well, I dont have a HD receiver yet, so I wouldnt know if I needed it but if I had to redo something then I'd like to have done that by the time I have that kind of receiver, thats why I ask.
No.
would it be possible that eac3to leaves a message when it cuts away some small parts of those playlists it displays? then you dont have to check the playlist of the main movie manually each time for those files, but only if they are really included in the list for that movie.
Old 15th August 2010, 21:48   #10436  |  Link
mrr19121970
Thoughts?
The answer would be 'depends' on what you want to do ultimately (have all streams separetly demuxed, have 1 .ts/.m2ts/.mkv file, or the full BD structure).
Are you (Atak_Snajpera) looking to simply demux the playlist, or recode the audio? There are a few options available currently:
Use 00014.m2ts instead of 00014.mpls for example
Use another tool (eg tsMuxeR) on each .m2ts and then correct the playlist.
mrr19121970 is offline   Reply With Quote
Old 15th August 2010, 21:52   #10437  |  Link
Snowknight26
Seems to be working beautifully, thanks.
Snowknight26 is offline   Reply With Quote
Old 15th August 2010, 22:19   #10438  |  Link
madshi
eac3to v3.24 released
* fixed: m2ts framerate detection for h264 tracks was half of what it should be
Oooooops.
Old 16th August 2010, 03:39   #10439  |  Link
jj666
Hello Madshi,
I tested the new processing .DTSHD functionality, it seems to be working with all the files I threw at it so far.
However, I found that demuxing a .DTSHD file introduced a 21ms delay to the file.
I verified by demuxing the original WAV, demuxing the encoded WAV with DTS Stream Player (both matched perfectly) and demuxing with EAC3TO (+21ms added). Waveforms were checked with Adobe Audition.
FYI, before EAC3TO added this functionality, I was demuxing the .DTSHD files with TSMUXER, TSMUXER mentioned "bad frame found, resycning stream" - this also introduced the same +21ms delay.
Cheers,
-jj-
jj666 is offline   Reply With Quote
Old 16th August 2010, 05:17   #10440  |  Link
Thunderbolt8
when you demux it from what? you also get a delay now when demuxing it from the original blu-ray source?
eac3to
