Old 4th October 2008, 20:36   #6481  |  Link
rica
Originally Posted by Jaja1 View Post
Use the command "eac3to" without any options from anywhere in the blu-ray folder and you'll get what you want.
Hey, thanks. Easy.
G:\>eac3to\eac3to.exe G:\HDBACKUPS\CETK   (enter)
1) 00056.mpls, 2:17:14
   [0+2+6+8+9+12+13+15+16+19+20+21+24+25+26+28+118+119+32+33+34+37+39+40+42+43+45+46+49].m2ts
   - h264/AVC, 1080p24 /1.001 (16:9)
   - TrueHD, English, multi-channel, 48khz
   - DTS Master Audio, English, multi-channel, 48khz
2) 00054.mpls, 2:14:45
   [0+1+6+7+9+10+13+14+16+17+20+22+24+25+26+27+118+117+32+33+34+37+38+40+41+43+44+46+47].m2ts
3) 00055.mpls, 2:12:30
   [0+2+6+8+9+11+13+15+16+18+20+21+24+26+28+118+119+32+36+37+39+40+42+43+45+46+48].m2ts
And it confirms that eac3to and bdinfo are agree:
__ _ __ _
rica is offline   Reply With Quote
Old 4th October 2008, 21:14   #6482  |  Link
rica
But the question is where these other three mpls files are?
eac3to just shows:
00056
00054 and
00055
while bdinfo shows:
00056
00054
00055
00225
00226
00101
Then where are the remainings ?
What title numbers do they have?
_ _ _ _ _
Old 4th October 2008, 21:28   #6483  |  Link
nautilus7
nautilus7's Avatar
You can easily find what is the content of each playlist file by playing the corresponding m2ts files in a media player.
eac3to doesn't show any playlist shorter than 15 minutes. That applies to HD DVDs and Blu-ray Discs as well.
nautilus7 is offline   Reply With Quote
Old 4th October 2008, 21:33   #6484  |  Link
rica
OK, thanks a lot; i've been about to get lost between 300 pages.
EDIT: Everyday i learn a new tip/trick; that is why i love eac3to as well.
Old 4th October 2008, 22:15   #6485  |  Link
rica
OK guys,
another history of mine:
today i loaded 00056.mpls to TSMuxer and i got an m2ts which including true hd and dts-hd ma.
I left true hd since eac3to doesn't correct the gaps and i got dts-hd ma corrected in second-pass; no problem.
Then as advised i directly tried to transmit true HD to PCM.
This is what i got:
:\>eac3to\eac3to.exe C:\Users\rica\Desktop\CETK.m2ts 2: C:\HD\audio.pcm
M2TS, 1 video track, 2 audio tracks, 2 subtitle tracks, 2:17:14
1: h264/AVC, 1080p24 /1.001 (16:9)
2: TrueHD/AC3, English, 5.1 channels, 48khz, -41ms
3: DTS Master Audio, English, 5.1 channels, 24 bits, 48khz, -41ms
4: Subtitle (PGS), English
5: Subtitle (PGS), Turkish
[a02] Extracting audio track number 2...
[a02] Extracting TrueHD stream...
[a02] Decoding with libav/ffmpeg...
[a02] Applying RAW/PCM delay...
[a02] Swapping endian...
[a02] Remapping channels...
[a02] Creating file "C:\HD\audio.24bit.pcm"...
[a02] This audio track contains more than 16 bits of information.
[libav] Lossless check failed - expected f9, calculated b2
[libav] Lossless check failed - expected a8, calculated d9
[libav] Lossless check failed - expected 2e, calculated a7
[libav] Lossless check failed - expected fb, calculated 35
[libav] Lossless check failed - expected 9d, calculated e
[libav] Lossless check failed - expected b7, calculated aa
[libav] Lossless check failed - expected 3e, calculated 4c
[libav] Lossless check failed - expected a7, calculated a6
[libav] Lossless check failed - expected 61, calculated 5e
[libav] Lossless check failed - expected 77, calculated 78
[libav] Lossless check failed - expected 94, calculated 9e
[libav] Lossless check failed - expected 38, calculated a1
[a02] This audio track has a constant bit depth of 24 bits.
[a02] Audio overlaps for 5ms at playtime 1:03:58.
[a02] Audio overlaps for 5ms at playtime 2:11:04.
[a02] The audio file was demuxed without making use of the gap/overlap informati
on.
[a02] Please rerun the same eac3to command line. That will correct the gaps/over
laps.
Video track 1 contains 197424 frames.
eac3to processing took 20 minutes, 17 seconds.
Done.
C:\>eac3to\eac3to.exe C:\Users\rica\Desktop\CETK.m2ts 2: C:\HD\audio.pcm
Audio gap description file detected, will be used for processing...
[a02] Realizing RAW/PCM gaps...
eac3to processing took 33 minutes, 20 seconds.
Done.
EDIT:And this time i've been trying to correct (remove overlaps/gaps) pcm from the main source (restarted the application)
C:\>eac3to\eac3to.exe G:\HDBACKUPS\CETK\ 1) 3: G:\HDBACKUPS\audio.pcm
M2TS, 1 video track, 2 audio tracks, 20 subtitle tracks, 2:17:13
1: Chapters, 20 chapters
2: h264/AVC, 1080p24 /1.001 (16:9)
3: TrueHD/AC3, English, 5.1 channels, 48khz
4: DTS Master Audio, English, 5.1 channels, 24 bits, 48khz
5: Subtitle (PGS), English
6: Subtitle (PGS), English
[a03] Extracting audio track number 3...
[a03] Extracting TrueHD stream...
[a03] Decoding with libav/ffmpeg...
[a03] Swapping endian...
[a03] Remapping channels...
[a03] Creating file "G:\HDBACKUPS\audio.24bit.pcm"...
[a03] This audio track contains more than 16 bits of information.
[a03] This audio track has a constant bit depth of 24 bits.
[a03] Audio overlaps for 5ms at playtime 0:58:47.
[a03] Audio overlaps for 5ms at playtime 1:34:34.
[a03] The audio file was demuxed without making use of the gap/overlap informati
on.
[a03] Please rerun the same eac3to command line. That will correct the gaps/over
laps.
Video track 2 contains 197424 frames.
eac3to processing took 29 minutes, 32 seconds.
Done.
[a03] Realizing RAW/PCM gaps...
eac3to processing took 39 minutes, 33 seconds.
Done.
Sure, those pcm files have to be re-processed by Pcm2Tsmu (by tebasuna51) so as to be recognized by TSMuxer:
C:\>Pcm2TSmu13\Pcm2Tsmu C:\HD\audio.pcm C:\HD\audio_out.pcm -i 24
_ _ ___
Old 5th October 2008, 01:16   #6486  |  Link
rica
All those experiences teach us again:
Remuxing of BDs including multiple m2ts files with TSMuxer doesn't correct or remove the gaps/overlaps; so they have to be re-processed by eac3to,
eac3to can not correct gaps/overlaps of True HD files on those BDs, so they have to be transmitted to any other uncompressed or lossless files like pcm or wav or flac.
Created re-encoded files as pcm have to be re-processed with pcm2tsmu again so as to be recognized by TSMuxer.
Old 5th October 2008, 06:42   #6487  |  Link
Greif
@madshi: what programming language is eac3to written in? I'm also curious as to the available hooks into the code. Is everything done via StdIn/StdOut?
Greif is offline   Reply With Quote
Old 5th October 2008, 18:32   #6488  |  Link
madshi
There's a problem with AGM files.
DTS Pro Encoder will accept all AGM files made from DTS-HD Master Audio tracks, but will reject every single AGM file made from TrueHD tracks
Originally Posted by xkodi View Post
if the decoded TrueHD track is less than 4GB the problem is not there.
Thanks, will check that out.
Originally Posted by Mercury_22 View Post
Can you add MKV to "Supported source formats" ? PLEASE !
Maybe some day. But probably not anytime soon.
Originally Posted by zyrill View Post
Did anybody ever experience the following error and has found a workaround?
[a05] Removing TrueHD dialog normalization...
[a05] Decoding with libav/ffmpeg...
[libav] Substream 0 checksum failed
[libav] No restart header present in substream 1.
[a05] The libav decoder reported an error while decoding.
Aborted at file position 81920.
Apparently the sourcefile has some errors and the decoder crashes over it.
Correct. And your best bet is to rerip the disc. Should be no problem if you actually own the disc. Which you should...
eac3to Shoot.'Em.Up.2007.Blu-ray.flac" shoot.em.up.aac
FLAC, 7.1 channels, 1:26:32, 24 bits, 5095kbps, 48khz
NeroAacEnc only supports 6 channels. Will mix the surround channels.
Nero supports 7.1 encoding.
Yes, the new version (which is just a few days old) does. The old version did not.
madshi, it would be nice if eac3to displays the profile of the AAC file (LC, HE, HEv2), runtime and the bitrate even in vbr tracks, like it's done in flac.
I don't know how to get this information. For FLAC it's easy cause all the info is in the header. But raw AAC streams don't have a header like that (AFAIK).
Originally Posted by ACrowley View Post
WOW ! Nero 9 Decoders are working outside Showtime!
Nice! Can you create an XML graph (GraphEdit) and post the XML text here, please?
Nope Sometimes video contains gaps as well
That's the first Blu-Ray I've seen which has video overlaps in it! Do you see any difference in the video playback smoothness when you let eac3to fix vs. not fix the overlaps?
Originally Posted by Joniii View Post
Which Blu-ray tracks needed channel remapping, was it only PCM?
If you let eac3to do the demuxing/transcoding you don't need to worry about things like that.
Originally Posted by baudi View Post
How can I convert a 25fps audio track to exactly 24fps.
Currently not with eac3to. It's on my to do list.
Originally Posted by jwdaigle View Post
Hi, sorry if this question has already been asked
It has. Please search for "seekToIFrames".
eac3to is written in Delphi. What do you mean with "hooks into the code"?
Old 5th October 2008, 19:11   #6489  |  Link
madshi
eac3to v2.66 released
http://madshi.net/eac3to.zip
* fixed AGM creation for files bigger than 4GB
* changed eac3to to allow AAC encoding with 7.1 channels (for new Nero encoder)
* added support for Nero's new AAC Encoder download URL
* lowered volume of error/success sounds
* when there are 2 similar playlists the one with less chapters is ignored now
Old 5th October 2008, 19:30   #6490  |  Link
nautilus7
nautilus7's Avatar
Thanks madshi.
btw any fix for the mkvtoolnix update check?
Old 5th October 2008, 19:42   #6491  |  Link
madshi
What's wrong with it? Seems to work fine for me.
Old 5th October 2008, 19:58   #6492  |  Link
nautilus7
nautilus7's Avatar
Well, it always says there's a new beta available even if i have the newest version already installed. This happens with all versions of eac3to.
And i just saw that the date of the mkvtoolnix version is not displayed correctly with v2.66, while it did with older versions.
eac3to -test
Nero Audio Decoder (Nero 7 or older) works fine
ArcSoft DTS Decoder (1.1.0.0) works fine
Sonic Audio Decoder (4.3.0.169) works fine
Haali Matroska Muxer (2008-03-29) is up to date
Nero AAC Encoder (1.3.3.0) is up to date
Surcode DTS Encoder (1.0.29.0) is installed
MkvToolnix (2.3.0.0, 2008--04) is up to date
  There's a new beta version (2.3.0.0, 2008-10-05) available
  http://www.bunkus.org/videotools/mkvtoolnix/win32/pre
Old 5th October 2008, 22:08   #6493  |  Link
madshi
eac3to does not OCR the message box of the GUI, obviously, to get the version number. Instead eac3to captures what "mkvmerge --version" says. Sometimes that information is not correct or sometimes mkvmerge is simply older than the GUI. If that is the case there's nothing I can do about it. I won't add OCR to eac3to just to get the version number/date of the GUI!! It can happen that Mosu recompiled only the GUI or only mkvmerge in a new beta build. Since eac3to can only get the version number of mkvmerge, there is potential for incorrect reports. Can't do anything about that, unless Mosu adds programatically readable version information to the GUI, too.
That's a bug in eac3to. It doesn't understand "Oct" as a month. Will be fixed in the next build.
Old 5th October 2008, 22:10   #6494  |  Link
rebkell
Madshi, would it be possible on the discontinuities to also print the frame number in the message, in addition to the file pos?
rebkell is offline   Reply With Quote
Old 5th October 2008, 22:21   #6495  |  Link
madshi
That'd be hard to do because the layer of processing which detects the discontinuities doesn't know anything about audio/video frames...
Old 5th October 2008, 22:27   #6496  |  Link
rebkell
Ok, just thought I'd ask, I have them sometimes on the Hauppauge HD-PVR caps and it's difficult to figure out where the discontinuities are happening. I suspect most happen during commercials, but you never know.
Old 5th October 2008, 22:30   #6497  |  Link
madshi
If you ask eac3to to ignore the discontinuities, does demuxing/transcoding succeed then? And do you then get any audio or video corruptions during playback? Just wondering whether these discontinuities are the result of a buggy broadcasting setup. Or whether there is real corruption in the data?
Old 5th October 2008, 22:35   #6498  |  Link
Jaja1
Hi Madshi,
You probably missed my post, so here is my question again. What does the message "Lossless check failed" mean? And is the resulting DTS track in someway influenced by this?
eac3to v2.65
command line: eac3to 1) 2:i:\M.mkv 3:i:\M.dts 8:i:\M.1.sup 9:i:\M.2.sup
M2TS, 1 video track, 5 audio tracks, 10 subtitle tracks, 1:25:55
3: TrueHD/AC3, English, 5.1 channels, 48khz, dialnorm: -27dB
4: AC3, French, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB
5: AC3, Spanish, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB
6: AC3, Portuguese, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB
7: AC3, English, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB
8: Subtitle (PGS), English
9: Subtitle (PGS), English
10: Subtitle (PGS), French
11: Subtitle (PGS), Spanish
12: Subtitle (PGS), Portuguese
13: Subtitle (PGS), English
14: Subtitle (PGS), French
15: Subtitle (PGS), Spanish
16: Subtitle (PGS), Portuguese
17: Subtitle (PGS), English
[v02] Extracting video track number 2...
[s08] Extracting subtitle track number 8...
[s09] Extracting subtitle track number 9...
[a03] Removing TrueHD dialog normalization...
[a03] Writing WAVs...
[v02] Muxing video to Matroska...
[a03] Creating file "i:\M.R.wav"...
[a03] Creating file "i:\M.L.wav"...
[a03] Creating file "i:\M.C.wav"...
[a03] Creating file "i:\M.SR.wav"...
[a03] Creating file "i:\M.SL.wav"...
[a03] Creating file "i:\M.LFE.wav"...
[s09] Creating file "i:\M.2.sup"...
[s08] Creating file "i:\M.1.sup"...
[libav] End of stream indicated
[libav] Lossless check failed - expected 0, calculated 8b
Encoding DTS <1536kbps> with Surcode...
Found Surcode DTS Encoder version 1.0.21.0.
Surcode encoding successfully started. Please wait...
Closing Surcode...
Added fps value to MKV header.
Video track 2 contains 123591 frames.
eac3to processing took 27 minutes, 38 seconds.
Surcode encoding took 13 minutes, 18 seconds.
Done.
Jaja1 is offline   Reply With Quote
Old 5th October 2008, 22:48   #6499  |  Link
rebkell
They seem to vary, I recorded Sanctuary the other night on SciFi and eac3to reported 2 discons one at
3518061672
3518061860
and another at
7045026084
7045025896
on the rerun the first set at 3518061572 were the same and thethe ones around the 7GB mark it reported them in reverse order:
7045025895
7045026084
I muxed the audio you repaired back in and the first one which I'm assuming was the same as an audio gap of 750ms reported at 54:39 didn't appear to have any problems and the audio went out of sync.
You also reported an audio gap of 745ms at 1:49:07, which would probably coincide with the discon at the 7GB mark, there was definitely a problem in that area in the original, because that was where muxing originally caused the audio/video to go out of sync, and 745ms seems probably about right.
Old 5th October 2008, 22:50   #6500  |  Link
nautilus7
nautilus7's Avatar
That explains. OCR is not needed of course, it's not important at all. Thanks!
eac3to
