Old 9th February 2019, 14:36   #961  |  Link
Ch3vr0n
Originally Posted by FREEDONOR View Post
Hello!
Tell me how to disable the German subtitles by default in the menu in the jar file?
Disc Title: The.Kings.Choice.2016.GERMAN.DUAL.COMPLETE.BLURAY-ROOR
Disc Size: 24,985,032,830 bytes
No we can't. That's a pirated download/source and against forum rules. You're on your own.
Verstuurd vanaf mijn Nexus 6P met Tapatalk
Ch3vr0n is offline   Reply With Quote
Old 1st September 2019, 06:27   #962  |  Link
UHD 4 Everyone
I see a screenshot on the website that says v.0.42b with UHD support... Any idea of when the executable will be available?
UHD 4 Everyone is offline   Reply With Quote
Old 1st September 2019, 11:34   #963  |  Link
outgoing
I also saw that detail, now it's left for Pelican to say something, he seems lost a long time ago.
outgoing is offline   Reply With Quote
Old 2nd September 2019, 20:15   #964  |  Link
UHD 4 Everyone
For those wondering where outgoing and I saw it...
https://pel.hu/bdedit/ then go to the section titled "2. PLAYLIST"
You'll see the following screenshot.
So this has to have been at least mid July when the site was edited since that's when Alita came out on UHD.
Old 3rd September 2019, 00:46   #965  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
As I donated back then I got access to 0.40 while 0.39 was on the website for free.
"Data reduction ? Yep, Sir. We're working on that issue. Synce invntoin uf lingöage..."
Old 3rd September 2019, 08:23   #966  |  Link
outgoing
Does this latest paid version offer anything different from v039b? Are the errors of previous versions fixed? Does it support UHD?
Old 4th September 2019, 03:33   #967  |  Link
UHD 4 Everyone
Does pelican even take donations anymore?
Old 9th September 2019, 02:59   #968  |  Link
UHD 4 Everyone
So got an update from Pelican. 0.42 can read 4K titles. However he's still figuring out HDR and DV.
Old 9th September 2019, 13:37   #969  |  Link
UHD 4 Everyone
To clarify I do not have a software update from Pelican. He told me what progress he has made. I do not have version 0.42.
Old 10th September 2019, 00:07   #970  |  Link
outgoing
Will he go back to the forum?
Old 10th September 2019, 19:03   #971  |  Link
Emulgator
Emulgator's Avatar
I haven't used 0.40 since, I just donated to acknowledge Pelican's efforts.
But here comes the List of changes from 0.39 to 0.40 anyway:
12/22/2012 Changes for 0.40
-New controls (button, checkbox, radio, dropdown, edit)
-Load palette from file to Menu/Objects (Adobe .act format)
-Lot of bug fix
Old 10th September 2019, 19:34   #972  |  Link
Sharc
I have my doubts. I donated some time ago but never got access to an upgrade or removal of the initial waiting period (splash screen).
Old 10th September 2019, 23:28   #973  |  Link
outgoing
Thank you guys for the information. Apart from valuing Pelican's good work, it is assumed that if you donate you will also be able to access the latest uhd version. It's weird that he's been absent so long here and yet now put screenshots of recent versions.
Old 2nd October 2019, 13:43   #974  |  Link
Arrasa_340
Arrasa_340's Avatar
Donation made, I am waiting for you to send me a new version, and registration number of the software.
Greetings and thank you very much for these advances.
Arrasa_340 is offline   Reply With Quote
Old 19th October 2019, 15:11   #975  |  Link
COOLak
Hi. How do I add my own buttons to IG menus using this program? I only figured how to edit existing buttons graphically... But that's not what I need. I need to add another language to the menu and associate with the respective audio/subtitles.
COOLak is offline   Reply With Quote
Old 21st October 2019, 20:55   #976  |  Link
DenisRodman
Hello to all. I talked with the developer Pelican, he said that his account was deleted for unknown reasons. He can not log in. He also tried to create a new account but nothing came of it.
If it is possible to manually restore the account to someone from the forum administration, then please respond.
DenisRodman is offline   Reply With Quote
Old 22nd October 2019, 10:53   #977  |  Link
tebasuna51
tebasuna51's Avatar
The Pelican9 Last Activity: 9th November 2013 15:53
But the user account is not deleted, remain like Registered_Active
Old 27th October 2019, 11:59   #978  |  Link
outgoing
Even if the account nominally exists, it's probably disabled, could you check this out?
Old 10th November 2019, 13:46   #979  |  Link
malimuc
Hi to all!
Does anyone know how can buy BDEdit 0.44?
If i donate, do i receive a key or link to dovnload BDedit v0.44?
Can anyone help me?
best regards
malimuc is offline   Reply With Quote
Old 11th November 2019, 19:54   #980  |  Link
malimuc
I donated. Now i am waiting for answer.
bd menu, bdedit, blu-ray
