1st September 2010, 18:22 | #14382 | Link |
MPC-HC Project Manager
So ffdshow and or avisynth depend on the exploit to work, they need to fixed then.
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC |
1st September 2010, 18:23 | #14383 | Link | |
The latest revision (also 2436) in your web page still has the problem. |
1st September 2010, 18:38 | #14384 | Link |
Petit, the builds on the site don't have the security disabled like the test build, thats why they obviously still crash.
I'm fairly sure the problem is that avisynth tries to load dll's from the working dir, this is no longer allowed due to the exploit and causes a crash. Avisynth will have to be adjusted so it's not exposed to this security leak anymore. (or maybe ffdshow is trying to load something from working dir when avisynth is used, in any case, it has to be fixed on their side)
1st September 2010, 18:39 | #14385 | Link | |||
I have to rename the exe, cause i used Girder to control the MPC via remote. But since changing the file name of the MPC-HC i had two options: creating a new Girder profile pointing to the new file, or renaming the exe to "it's old" name. I was simply too lazy to do the first one . Last edited by Tom Keller; 1st September 2010 at 18:45. |
2nd September 2010, 14:29 | #14387 | Link |
A new problem with DXVA on ATI cards.
Maybe Nvidia, too. I don't have one to check it out. An H.264 clip L4.1 - 1080p30fps, when I try to play it in DXVA mode I get artifacts by every player I tried. What is so special with this clip? Sample here: http://rapidshare.com/files/41658614...7Mbps.mov.html Last edited by NikosD; 2nd September 2010 at 15:14. |
2nd September 2010, 16:56 | #14389 | Link |
I didn't stuck the dll, ffs. MediaInfoLib is statically linked. You can either build mpc-hc without MediaInfoLib (find it how in the source code) or upx the executable; it's an open source project after all. Everyone who distributes mpc-hc inlcuded the MediaInfo.dll already. Also I have a little change which will cut down 0.4MB so it will be almost like before adding MediaInfoLib (since we have already saved 0.5MB).
2nd September 2010, 19:25 | #14390 | Link | |
this is what i get from the "view details" of windows when the app. (msvc2010 2420 both x86 and x64)crashes.. " Problem Event Name: APPCRASH Application Name: mpc-hc.exe Application Version: 1.3.2420.0 Application Timestamp: 4c7d179f Fault Module Name: KERNELBASE.dll Fault Module Version: 6.1.7600.16385 Fault Module Timestamp: 4a5bdbdf Exception Code: e06d7363 Exception Offset: 0000b727 OS Version: 6.1.7600.2.0.0.256.1 Locale ID: 1032 Additional Information 1: 0a9e Additional Information 2: 0a9e372d3b4ad19135b953a78882e789 Additional Information 3: 0a9e Additional Information 4: 0a9e372d3b4ad19135b953a78882e789" Any help? |
2nd September 2010, 20:06 | #14391 | Link |
Google says you are running a debugger on mpc-hc http://www.codeguru.com/forum/archiv.../t-333591.html
You did install the msvc2010 redist??
2nd September 2010, 20:08 | #14392 | Link | |
Hi soulkeeper,
since the error message Windows is giving equals the one I qouted below from PetitDragon, your problem is probably caused by AviSynth (definetly not MPC-HC). If you would rename the AviSynth Plugin folder like Tom Keller did, you should not get the error anymore. The problem you experience is based on an DLL-Vulnerability which was fixed with Rev2374: "Remove the current working directory from the DLL search path in order to avoid the DLL preloading vulnerability (Ticket #694)" Quote:
Last edited by MPC-HTPC; 2nd September 2010 at 20:13. Reason: Link added to post of Tom Keller |
2nd September 2010, 20:23 | #14393 | Link |
@tetsuo55
yes it's installed @MPC-HTPC you're right! it seems avisynth problem.. tried 2436 (posted by @xhmikosr in #14415) and everything is fine... so i'll stick with that revision... is there also a x64 revision of mpc-hc msvc2010 so i can use now with avisynth? edit: ok..the last working is 2372... |
2nd September 2010, 20:24 | #14394 | Link | ||
2nd September 2010, 20:27 | #14395 | Link |
You can find all the old MSVC 2010 on XhmikosR FTP-Space. I give you the direct link to the old MSVC 2010 builds were you can also find Rev2372:
http://xhmikosr.1f0.de/index.php?fol...EwL29sZC94NjQ= or the direct link to it: http://xhmikosr.1f0.de/mpc-hc_msvc20...4.MSVC2010.exe |
2nd September 2010, 23:20 | #14396 | Link |
OK... i took a closer look into the avisynth depending crash problem. Seems like (for me!) the problem was simply related to the old restore24.avsi script, which was in my avisynth plugin folder. Seems like it has some LoadPlugin lines in the beginning (which were trying to load some plugins after the avsi is auto-loaded by avisynth) - and this caused the MPC-HC crash. Removing the avsi (or those lines in the beginning of the avsi) prevents the MPC-HC from crashing. So i suggest (for everyone with the same problem) to take a look into the avisynth plugin folder and it's avsi scripts...
3rd September 2010, 14:35 | #14398 | Link |
In my understanding color space (what is "Output Range" in MPC-HC) and color management are two totally different things, that also serve a different purpose. Please somebody correct me if I am wrong!
Anyhow, for further information please refer to the respective Wikipedia-Articles: Color space Color Management |
3rd September 2010, 14:46 | #14399 | Link |
Some poeple have reported crashing or hang problems with mpc-hc, especially when seeking and more often with files that go through the mpeg splitter.
You can help solve this problem if you are a Windows XP user. Download and unzip this program http://drmemory.googlecode.com/files...ws-1.3.0-1.zip The binary will be in the bin directory, unzip this debug build of mpc-hc with the pdb into that bin directory http://www.mediafire.com/file/4p0jt2...c_x86_Debug.7z Then use the commandprompt to open mpc-hc like this drmemory.exe -- mpc-hc.exe Try opening the problematic file and making a lot of seeks, if you get a result put it in pastebin.com and paste the link here. (This fails on windows 7 and possibly vista due to their security models blocking drmemory from injecting its code into mpc-hc)
3rd September 2010, 20:32 | #14400 | Link |
I found out a third issue with DXVA.
When I try to play the sample below an H.264 L4.2 - 1080p60fps file in DXVA mode, I can't go over 35fps. Latest MPC-HC x86, latest FFDShow DXVA I have the same problem to every 1080p60fps H.264 file (L4.1-L4.2-L5.1) I try. In WMP12, I get 58-60fps Sample here: http://rapidshare.com/files/41577731...sRef4.mts.html Last edited by NikosD; 3rd September 2010 at 21:32. |
