Old 27th September 2009, 07:03   #1  |  Link
OverFienD
Probs with Clint Eastwood HD-DVDs!!
Hi Guys and Gals...
First off, great forums... Ive been lurking around them for a while now, getting great info!
I've encountered a problem trying rip and re-encode 2 of my HD-DVDs (so I can watch them through VMC):
They are 'The Unforgiven' & 'Letters from Iwo Jima'
I've done all of my others without trouble (about 25 of them!) with the following process:
1. Remove protection with AnyDVD HD
2. Extract feature streams with Eac3to's HdBrStreamExtractor GUI (Video - MKV, Audio - AC3\FLAC & Chapters - TXT)
3. Remux with either MKV Merge - MKV or TsmuxeR - M2TS
When I point Eac3to to the main movie feature files, it crashes, or comes up with nothing at all. The additional features show up when I select them, just not the movie... It's got me beat!!
Other HD-DVD's work fine both before and after, and the movies play with PowerDVD fine from disk!
If anyone can give me some help I'd really appreciate it!!
OverFienD is offline   Reply With Quote
Old 27th September 2009, 16:07   #2  |  Link
setarip_old
setarip_old's Avatar
Hi!
Try the following slightly different procedure at:
http://forum.doom9.org/showpost.php?...83&postcount=1
Scroll about halfway down the page to the BOLD heading "HD-DVD"...
setarip_old is offline   Reply With Quote
Old 28th September 2009, 00:00   #3  |  Link
OverFienD
Thanks a bunch for that... I'll give it a go when I get home.
Although I've found yesterday that I cannot even rip the disks to HDD with AnyDVD HD. It gets to about 50% and then errors.
I'll try that process from the disk.
Old 28th September 2009, 00:29   #4  |  Link
setarip_old
Odd thought, if I may:
If I remember correctly, both are dual format (HD-DVD and standard DVD) discs. Are you sure you're trying to read the right format?
Old 28th September 2009, 00:35   #5  |  Link
OverFienD
Heehehe... No problems!!!
Only the Letters from Iwo Jima is dual format, Unforgiven is straight HD-DVD.
I had had the same thought myself with 'letters', but when I direct HdBrStreamExtractor to find the files they are in the /HDDVD_TS/ folder, the same as the other HD-DVDs.
Then it shows all the different streams: Main Movie, and the extras, and when I hold the mouse over the main movie stream it shows 1080p vid and audio (whatever it is, can't remember!), but when I try to retrieve the individual streams from the main movie, it doesn't work at all, it also does not work directly from Eac3to (with the Eac3tomoreGUI).
Cheers.
Old 9th October 2009, 00:35   #6  |  Link
OverFienD
Okie Dokie, sorry about the delay, but I've been away and unable to muck around with this Rip!
I've tried a few different things, including the alternate method described in the post linked above, and still no joy!!
I have narrowed the issue down though!
If I demux and mux the first of the EVO's (PEVOB_1, if I recall) then I get half the movie done right. This is no matter whether I do it with EVOdemux, or via the methods I described in my first post.
It's only when I try and Include the 2nd EVO (PEVOB_2) that the programs crash. EVOdemux and eac3to both straight crash, and tsMuxeR just says it cannot detect the stream type.
I have alternately tried to Join the EVO's, without success.
It has now really got me stumped, as these are the only 2 I've had trouble with, and the movies play fine from the Disk!
If anyone can offer me any idea's I'd would be very grateful. Thanks
Old 9th October 2009, 01:26   #7  |  Link
setarip_old
1) Is the "PEVOB_2" filesize somewhyere near comparable to that of "PEVOB_1" (as it should be)? If not, look for another file of that approximate size.
2) And of course you're picking up "PEVOB_2.EVO" and not "PEVOB_2.MAP" (if any), right? ;>}
Old 9th October 2009, 01:44   #8  |  Link
OverFienD
Yeah, the 2 EVO's are about 9 and 7 Gigs respectively.
And yeah, I'm picking up the EVO's... the MAP files wouldn't be of comparable size, would they?
Old 9th October 2009, 19:22   #9  |  Link
setarip_old
Absolutely not! Just exploring any and all possibilities...
Old 12th October 2009, 05:41   #10  |  Link
OverFienD
Yeah, it's definitely the 2nd EVO file, it sounds like the drive is having trouble accessing when I direct any of the programs listed above to it. The first EVO is no problem.
I have the LG combo BR/HD-DVD drive (not burner), if that makes any difference.
Once again, I'm not sure why it's only these 2 disks that I have a problem with. I've ripped all my other HD-DVD's without problem.
Would appreciate any help anyone can offer!!
Thanks, OFD
Old 12th October 2009, 07:27   #11  |  Link
setarip_old
I don't know if the following is pertinent to your problem but, the following review of "The Unforgiven" HD-DVD included an interesting observation:
"The Unforgiven"
http://www.dvdreview.com/reviews/pages/2281.shtml
(Note: have some serious problems running chapter 17-19 of the disc as the film would continuallly lock up the HD-A1 Toshiba HD-DVD player. I do suspect however that this is a problem with Toshiba's shoddy player and has nothing to do with the actual HD-DVD disc.)
Old 12th October 2009, 07:37   #12  |  Link
OverFienD
Hmmm... I wonder if I set up my Xbox 360 HD-DVD drive on my HTPC and try and rip it, whether that would make a difference?
Old 12th October 2009, 07:53   #13  |  Link
setarip_old
Trying an alternative piece of hardware is certainly worth the effort...
Old 12th October 2009, 10:41   #14  |  Link
OverFienD
OK PEOPLES!!!!!!
Just got home and plugged in my xbox 360 hd-dvd drive. Vista detected it and set it up no probs... I directed HdBrStreamextractor (eac3to GUI) to the HDDVD_TS folder and as we speak it is working it's magic!!!
Now, why this won't work on my LG Combo drive, I've got no idea? It's the GGC-H20L model.
Anyway setarip_old: thanks a bunch for your assistance! massive in the mail!!!
Cheers, OFD
Old 12th October 2009, 21:10   #15  |  Link
setarip_old
You're quite welcome ;>}
BTW - Sounds like your LG Combo drive either needs a cleaning or is slowly beginning to fail. You might try running a DVD/CD cleaning disc on it. Maxell makes one that sells for about $10US...
Old 15th October 2009, 00:22   #16  |  Link
OverFienD
Yeah, I'll give it a clean, and see what happens.
Interesting point though, is that these were not the last 2 I've tried to rip. I tried and failed, and then moved on to others, which ended up making these two the last two. So other disks have been successfully ripped on my LG drive...
I'm a little curious as to why that would be... I'm looking at buying 'Million Dollar Baby', so it'll be intersting to see if I encounter the same problem!!!
Cheers, OFD
Old 15th October 2009, 04:01   #17  |  Link
setarip_old
Unless you're getting the HD-DVD version at an extremely low price, I'd suggest you purchase the BluRay version...
Old 15th October 2009, 05:53   #18  |  Link
OverFienD
Is any other reason to buy HD-DVD?
Yeah, I really should start looking at Bluray disks now, but I seem to still be able to find great value HD-DVD's around the place (and there haven't been that many new movies i'd fork out $45 bucks for!).
Old 15th October 2009, 07:36   #19  |  Link
setarip_old
That's not in U.S. currency. At Amazon.com:
http://www.amazon.com/Million-Dollar...5588397&sr=1-1
BTW - JUst curious - Did you purchase the two Eastwood HD-DVDs as new or used?
Old 19th October 2009, 01:25   #20  |  Link
OverFienD
Australian $!!
Unforgiven was purchased 2nd hand from e-bay. Letters from Iwo Jima was purchased new from inet video (with a bunch of others).
