26th December 2012, 15:39 | #13541 | Link |
Some files simply have the wrong field order, there is an option to switch it exactly for that reason.
Its possible cuvid and ffmpeg have different defaults when no field order can be determined, who knows.
26th December 2012, 16:05 | #13543 | Link |
I'm looking into it.
26th December 2012, 16:55 | #13544 | Link |
27th December 2012, 07:02 | #13546 | Link |
Nev,
There's some glitches (no audio output at the L channel, the audio is stereo) with the audio when playing with a 720p rmvb file with raac audio after seeking for several times. This problem only appear when I use LAV Splitter, no problem with the splitter with mpc-hc 1.6.5 stable. There's quite a few splitter problems with different containers with LAV Splitter, is there something you can do to improve it? Anything that may help you tracing the bug, please don't hesitate to ask. Regards, |
27th December 2012, 10:27 | #13547 | Link | ||
For the record, RMVB is just a horrible format. Quote:
Accurate problem descriptions, with sample files, or nothing can be done. For the record, it works just perfectly for me.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 27th December 2012 at 10:54. |
27th December 2012, 10:55 | #13548 | Link | |
Intel UHD Graphics 750; Win 10 22H2 Last edited by Mercury_22; 27th December 2012 at 10:59. |
27th December 2012, 11:04 | #13549 | Link |
The file has a "odd" FourCC used by one specific authoring tool, apparently.
There is two ways to fix such a file, either you overwrite the type in the splitter, or you make the decoder recognize the FourCC, i decided to do the second.
27th December 2012, 12:32 | #13551 | Link |
Why can the ffmpeg parser only be used for the following formats resp. subtypes inside LAV Video?
if(codec == AV_CODEC_ID_MPEG1VIDEO || codec == AV_CODEC_ID_MPEG2VIDEO || pmt->subtype == FOURCCMap(MKTAG('H','2','6','4')) || pmt->subtype == FOURCCMap(MKTAG('h','2','6','4'))) { m_pParser = av_parser_init(codec); }
Bye Last edited by CiNcH; 27th December 2012 at 13:07. |
28th December 2012, 01:03 | #13552 | Link | |
Try with this version, it should resolve the issue i hope, my own tests seem positive. http://files.1f0.de/lavf/LAVFilters-...8-ge480b02.zip
28th December 2012, 09:59 | #13553 | Link | |
I have it somewhere on my list to try to support splitters which don't deliver VC-1 in Microsofts spec, but it will be a while.
28th December 2012, 10:14 | #13554 | Link | |
BTW, something I did not have a look at yet... how does the QuickSync path work with the fixed size ES chunks that the DVBSource sends in case of MPEG-2 and H.264? Does QuickSync itself perform a NALU/frame parsing for those formats?
Bye |
28th December 2012, 10:35 | #13555 | Link | |
I believe Eric has code for this in the IntelQuickSyncDecoder. Not sure if for VC-1 as well.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 28th December 2012 at 10:56. |
28th December 2012, 14:55 | #13556 | Link |
QuickSync Decoder author
All I do is a basic parse of H264 streams and make sure they are HW compatible (remove AnnexB style info). The Intel Media SDK underneath my decoder does the rest (split or join packets). HW works one frame at time.
Eric Gur, Processor Application Engineer for Overclocking and CPU technologies Intel QuickSync Decoder author Intel Corp. |
28th December 2012, 16:55 | #13557 | Link | |
LAV video decoder can not recognize the FourCC, MPC-HC/BE is fine. |
28th December 2012, 22:29 | #13558 | Link |
If you add "3IV2" for the file above, then you could add "3IV1" as well while you're at it. Both are from 3ivX MPEG-4 encoder.
The rm fix is working great btw.
MPC-HC 2.2.1 |
28th December 2012, 22:30 | #13559 | Link | ||
Great!
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 28th December 2012 at 22:34. |
29th December 2012, 01:34 | #13560 | Link |
Nevcairiel,
Thanks a lot for the fix. I know rm container sucks, however I have plenty of videos in this format. As I can recall, Kostya said somewhere that he may intended to write a new rm splitter. I hope that he can find some time to do that in the end. Regards, |
