Thread Tools Display Modes
Old 27th April 2003, 08:46   #1  |  Link
neuron2
_
neuron2's Avatar
Experimental Declick( ) filter
I've made a proof of concept for a declicker. I'd like to get some feedback as well as request any clips suffering from dust and/or scratches, as I want to generalize this filter into a general-purpose dust, scratch, and click filter.
The clip can be obtained from:
[EDIT: Get later version below]
See the next post for a sample before and after frame.
Declick Filter for Avisynth (Version 0.05)
This is a proof of concept for a new declicking
algorithm. Typical clicks are generated by motor
noise and other interference.
Currently, the filter handles light horizontal clicks.
I want to add handling of dark clicks and vertical
features. That would turn it into a general dust and
scratch filter as well as a declicker.
This filter currently requires YUY2 input.
Usage:
Declick([named parameters])
lthresh (int, default 35): Luma threshold for click detection.
cthresh (int, default 15): Chroma threshold for click detection.
map (bool, default false): Show detected clicks.
Example:
The distribution contains a sample clip with clicks (real-world
example) that is cleaned up nicely by the default parameters. I
received this clip from a user about 2 years ago asking me to make
a declicker for it. As they say, better late than never.
neuron2 is offline   Reply With Quote
Old 27th April 2003, 08:55   #2  |  Link
neuron2
_
neuron2's Avatar
Here is a sample frame. It's not perfect (what is?), but it's a great improvement. Playing the clip before and after Declick() gives the best impression.
Old 27th April 2003, 11:57   #3  |  Link
Le Furet
Le Furet's Avatar
Seems very interesting.
Can I ask how you reconstruct the images below the clicks ? Temporal or spacial interpolation ? Or something else ?
Le Furet is offline   Reply With Quote
Old 27th April 2003, 15:22   #4  |  Link
neuron2
_
neuron2's Avatar
I'm still working on that. Right now it's a simple spatial vertical gradient fill using the nearest good pixels. But that produces artifacts when the fill pixel(s) used to define the gradient differs greatly from the average color of the (lost) area to be filled. I plan to detect that case and use temporal interpolation there. What do you think?
Old 27th April 2003, 17:52   #5  |  Link
Le Furet
Le Furet's Avatar
Didn't make any attempts with temporal interpolation. Interpolation must not be the true word, it's rather a problem of copy, with move detection before.
I suppose it would give good results for you, since the corrupted zones occur only on one frame (I suppose).
Moreover, since these zone are thin, maybe a better spatial interpolation can help (bilinear may suffice).
I'm working on a way to remove hardcoded subtitles, and it gives me similar problems : I must 1) detect text on the picture (almost done) and 2) reconstruct the picture below. I'm studying several methods. But since I have to reconstruct areas on more than one frame, I'm more interested in spatial interpolation algorithms. I found one based on "Radial Basis Functions" that seems not too hard to implement, not too slow and that gives among best results I've seen on the subject (but the nec plus ultra in Image reconstruction seems to be algorithms based on Navier Stokes equations).
Old 27th April 2003, 18:03   #6  |  Link
neuron2
_
neuron2's Avatar
It could be interpolation, if you use the average of the previous and following frames.
Please post links to relevant information if you can. I am very interested in this.
Old 27th April 2003, 18:23   #7  |  Link
Le Furet
Le Furet's Avatar
A readable site on RBF and image processing applications (have a look on the section on scratch removal) : http://www.doc.ic.ac.uk/~hz3/m4rproject/
Old 27th April 2003, 20:14   #8  |  Link
Si
Simply me
Si's Avatar
A nice bit of light reading for bedtime tonight
regards
Simon
Si is offline   Reply With Quote
Old 28th April 2003, 04:49   #9  |  Link
neuron2
_
neuron2's Avatar
I've improved the click detection a bit so there are less false positives and they are smaller. Get it here:
http://shelob.mordor.net/dgraft/declick/declick006.zip
@Le Furet
Thank you for the link.
Old 28th April 2003, 04:58   #10  |  Link
jorel
Posts: n/a
@ neuron2,
please...
it's only for avisynth 2.5x?
thanks in advance.
Old 28th April 2003, 05:09   #11  |  Link
neuron2
_
neuron2's Avatar
@jorel
It is for Avisynth 2.5. I do not program for obsolete software versions.
Old 28th April 2003, 19:28   #12  |  Link
HarryM
Combination temporal-spatial (matrix 3x3) is best.
HarryM is offline   Reply With Quote
Old 28th April 2003, 20:30   #13  |  Link
neuron2
_
neuron2's Avatar
@HarryM
Best for what?
You can't do a 3x3 spatial when your lost area is (much) bigger than a single pixel! Methinks you are considering general noise reduction, which is quite a different problem. Or perhaps I've misunderstood your point.
Old 29th April 2003, 01:57   #14  |  Link
morsa
the dumbest
Guys.Look at Restoreinpaint source code.
See the examples at its home page.
It removes any kind of text from an image recreating the lost parts of the original image.
It is really excellent.
www.sourceforge.net
morsa is offline   Reply With Quote
Old 30th April 2003, 09:16   #15  |  Link
jorel
Posts: n/a
@jorel
ok but 2.5 is beta, and we got some problems
using this beta a few days ago.
is stable now?
Old 30th April 2003, 13:26   #16  |  Link
neuron2
_
neuron2's Avatar
Please keep the focus. That is not an issue for this thread. I am not making any more filters for pre 2.5 Avisynth versions.
Old 30th April 2003, 21:06   #17  |  Link
HarryM
@HarryM
Best for what?
You must expendable any pixels potentially. I think 3x3 matrix over temporal, e.g.
f f f
r r r
a a a
m m m
e e e
1 2 3
x x x
x o x
x x x
x - substitute pixel
o - bad pixel
Old 1st May 2003, 01:09   #18  |  Link
^^-+I4004+-^^
Banned
^^-+I4004+-^^'s Avatar
can it cure this
http://i4004.bizhosting.com/cgi-bin/i/030501-005140.jpg
(or images from same series (030501) on
http://i4004.bizhosting.com/ ?
temp smoothing doesn't help in this case os analog satv "sparklies"
these are black and white dots noise........
why don't i try instead?
well no real use for 2.5 here as i only do capturing...
but if it can resolve such noise i might give it a try on win98 partition....(and i go for win98 oly in case of emergency..)
or in other words;will it spot and remove black dots too(the black dot is visible at http://i4004.bizhosting.com/cgi-bin/i/030501-005201.jpg ),or only white ones?
(don't worry for that noise induced combing which is present too)
^^-+I4004+-^^ is offline   Reply With Quote
Old 1st May 2003, 01:53   #19  |  Link
neuron2
_
neuron2's Avatar
@I4004
It can remove black or white. Can you make available some clips so that I can perfect the filter on your real-world material. As a reward I can make an Avisynth 2.0x version for you.
Old 1st May 2003, 09:55   #20  |  Link
jorel
Posts: n/a
@I4004
i don't know what i do reading:
"As a reward I can make an Avisynth 2.0x version for you."
cry or laugh?
Thread Tools
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
