Old 5th September 2008, 15:19   #1  |  Link
PrayForMojo
BD-P1400 + tsmuxer = some issues i'm having
I'm having problems with the playback on this Samsung player. I followed the guide religiously. The problem is all the movies will skip and jump to the point it's unwatchable. The audio is smooth but video sucks. I have changed it to the 4.1 profile as mentioned in the guide.
I'm out of ideas.
PrayForMojo is offline   Reply With Quote
Old 6th September 2008, 10:16   #2  |  Link
emufan
tsmuxer can'tget the key frame.....
emufan is offline   Reply With Quote
Old 6th September 2008, 20:25   #3  |  Link
G_M_C
This:
Is because of this;
[...]I have changed it to the 4.1 profile as mentioned in the guide.
Just changing the reported profile does not make the video-stream level 4.1 compliant in reality; You're actually faking that for your player.
You need to make shure your stream is actually level 4.1 compliant AND is blu-ray compliant (keyint / GOP size mainly). So you need to reencode. There are several topics on that subject floating around this board, and between them they contain all the info you need.
G_M_C is offline   Reply With Quote
jumps, mkv, stutter, tsmuxer
