17th February 2014, 03:11 | #17061 | Link | ||
Hi nevcairiel,
I have an issue which may be occurring because I'm not really aware of the requirements for LAV about it, but here it goes: When I setup the filtergraph and tell LAV to use video acceleration it simply does not do it. I can see that the settings have been accepted if I open the tray icon, but the acceleration is not there (avcodec): The weird things I'm doing that are not really standard are: - LAV is not installed and regged on the PC but it is loaded from the ax with: Quote:
Can you plase help in enabling video accel? If you need to run the app you can download a zip from this page (yellow button): http://msimic.github.io/MediaPoint/ Thanks! Last edited by marsovac; 17th February 2014 at 03:15. |
17th February 2014, 07:35 | #17063 | Link | |
I don't use Media Center software, I read that JRiver is one of the best, if not the best. But 50$ is a lot. Anyway, I think Nevcairiel is committed to open-source development but a job is a job. I see almost everyday nightly builds, so someone is writing code for LAV filters. If not Nevcairiel, then who ?
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all |
17th February 2014, 08:15 | #17065 | Link | |
DXVA2 Native only works if the decoder is directly connected to a compatible renderer (EVR), if there is anything in between, DXVA2 Native no longer functions. If you need anything in between, you can use DXVA2 Copy-Back or any of the other modes, only DXVA2 Native has this restriction (because it keeps the image on the GPU, while all others copy it back to system memory once, which costs a bit of CPU time)
17th February 2014, 17:52 | #17067 | Link |
Why wouldn't you be able to use it?
17th February 2014, 18:29 | #17069 | Link |
That doesn't mean its the only compatible renderer.
17th February 2014, 19:13 | #17071 | Link |
I know that ffmpeg does not support MVC and as such, you can not support it for software decoding, but have you considered supporting MVC via DXVA?
According to the specs, it should be pretty straightforward to implement. See here for details. I know that no free renderers or players currently support it, but that is most likely due to no free decoders have been able to decode it, so if you can get this to work in LAVFilters, I am sure, that we will soon see free players/renderers that will support it too |
18th February 2014, 11:26 | #17072 | Link |
Speex Audio : Is this something new? All of a sudden I have been seeing many cam vids coded with AVC for video and Speex for audio. Only PotPlayer can play it for me... could this speex be added to LAV Audio if possible please?
18th February 2014, 11:38 | #17073 | Link |
It is not exactly "new", another development by the Xiph team, a low frequency range codec for human speech (suitable for digital telephony).
Speex project website — obsolete since it is included in the Opus codec. Other formats on RareWares I wonder if your audio is really Speex, or rather a mis-identified Opus stream. |
18th February 2014, 11:41 | #17074 | Link |
LAV already supports both Speex and Opus.
18th February 2014, 14:20 | #17075 | Link | ||
I tried with copyback and it works only if I set that in the LAV configuration dialog. The following line seems to do nothing: Quote:
(EDIT: wrong - I'm doing it already before adding to the graph)Or do I need to set that before adding the filter to the filter graph? And I'm also wondering how does MPC-HC use DXVA with subtitles then? Last edited by marsovac; 18th February 2014 at 15:22. |
18th February 2014, 16:22 | #17076 | Link | |
@nevcairiel The audio switcher in MPC-HC now supports mediatype re-negotiation, so there are no more obstacles for implementing a bitstreaming fallback
MPC-HC 2.2.1 |
18th February 2014, 18:01 | #17078 | Link |
Yes.
You can't use subtitles with EVR. If you want DXVA and subtitles you need EVR-CP, the default renderer of MPC-HC.
18th February 2014, 18:35 | #17080 | Link | |
Is is even worth the hassle of development to attach my custom presenter to VSFilter? Especially since the presenter is not a filter at all... Is there much difference between DXVA native and copyback? |
