9th November 2011, 03:19 | #6861 | Link | |
Try to adjust the settings from your sound to do so or configure Reclock to make 24bit PCM. I assume you not downmixing to stereo in FFDshow , are you ?. First go to configure Reclock and set it to "24 padded in 32"' (first tab,look at PCM output) You could also uncheck 32bit and 32bit float in Lavaudio, depending on your config, that could solve your problem already. If you still get an error, your sound doesn't support 96kHz : configure reclock to output only 48 kHz sample rate. Last edited by Pat357; 9th November 2011 at 03:36. Reason: This is a better way to do it |
9th November 2011, 03:25 | #6862 | Link | |
Windows 7 x64 i7 870 16GB RAM AMD 6870 |
9th November 2011, 03:51 | #6863 | Link |
Nev, when I use the installer, I do not get a chance to give a directory for installation. It just overwrites the existing install.
This makes it more cumbersome to go back to a previous version to test something... IIRC, Lavfilters have asked for a installation directory in the past, like 2 or 3 versions back (like 0.36 and before) Could you re-implement this in the installer ? |
9th November 2011, 10:09 | #6864 | Link | |
Please, don't. |
9th November 2011, 10:40 | #6865 | Link | |
9th November 2011, 11:36 | #6866 | Link |
Should be fixed for the next version. Raw PCM was not getting the appropriate media type in some cases.
9th November 2011, 11:46 | #6867 | Link | |
Additional note: If you select "waveout" option instead of "wasapi", Lav Splitter directly connected to ReClock but this time it's not bitexact, it falls to wasapi shared mode sure. Please try with my sample file. Last edited by rica; 9th November 2011 at 11:54. |
10th November 2011, 00:13 | #6868 | Link |
Nev,
I've been doing some testing on madVR's deinterlacing and I discovered that when I use CUVID Acceleration and I set Deinterlacing to "None (Weave)" I don't get deinterlacing in madVR - it says "deinterlacing off (says upstream)". It also doesn't work with EVR. It seams like using this option doesn't pass the interlaced flags to the renderer. Is this by design? How can I get hardware acceleration for the decoding and EVR/madVR deinterlacing at the same time? I'm performing some GPU/VPU Load testing and I'd like to compare CUVID to the MS DTV-DVD Video Decoder and also madVR to EVR deinterlacing.
Z370M Pro4 | i3-8100 | 16GB RAM | 256GB SSD + 40TB NAS NVIDIA GTX 1060 6GB (385.28) | LG OLED65B7V Win 10 64bit 1803 + Zoom Player v14 |
10th November 2011, 01:10 | #6869 | Link | |
10th November 2011, 01:32 | #6870 | Link |
I'm currently testing LAV Filter 0.39 with KMPlayer 3.0.0.1442 R2 and it shows a black screen with any 720p/1080p h.264 video if CUVID acceleration is enabled. No black screen at all with standalone LAV CUVID 0.13
10th November 2011, 02:24 | #6872 | Link |
Hi, just a feature request. If possible can you add "Select All" and "Select None" buttons to the installer on the part where you select which codecs/splitters to checkmark during the install process? That would make installation much faster and easier as some of us use LAV Filters for only one codec and/or splitter. In my case, just your excellent H264 Cuvid.
Thanks for your kind attention... Last edited by andybkma; 10th November 2011 at 03:46. |
10th November 2011, 03:11 | #6874 | Link |
Yes, I know I can force madVR to do deinterlacing and I've done it already but AFAIK there is no way to do it with EVR, right?
Also you'll have to agree with me that it's not something that can be used on a daily bases. The question is why LAV Decoder in software mode is setting the correct interlaced flags and not in CUVID mode. ... or am I misunderstanding what "None (Weave)" should mean?
10th November 2011, 06:53 | #6877 | Link | |
10th November 2011, 09:22 | #6878 | Link |
Firefox User
new nightly:
http://roy.orz.hm/lavf-w32-nightlies...ame-6bfdb44.7z diff (RV30/RV40 seek to key frame): http://roy.orz.hm/lavf-w32-nightlies...e-6bfdb44.diff |
10th November 2011, 09:32 | #6879 | Link | |
