27th May 2023, 12:16 | #4701 | Link |
Version 2.19.0 is released.
https://github.com/staxrip/staxrip/releases/tag/v2.19.0 |
27th May 2023, 18:49 | #4702 | Link |
I just used 2.19. I noticed a huge performance improvement with Neo_FFT3D.
I don't know where it comes but it is almost the same speed as without it. - Without it 27.35 fps - Neo_FFT3D(bt=3, y=3, u=2, v=2, sigma=2) 24.88 fps I don't remember exactly but I think in the past it was around 5 fps. |
29th May 2023, 22:08 | #4703 | Link |
I'm sure this is news to almost no one here, but I just switched to StaxRip after using both ffmpeg cli and Handbrake and just wish I moved over sooner. StaxRip fits my needs extremely well and makes using AviSynth substantially easier.
One thing, I'm curious about though... is it possible to have StaxRip extract a Dolby Vision RPU from a source file and inject it into the destination file? |
30th May 2023, 01:14 | #4704 | Link | |
Formally known as .......
As for DV rpu's, you have spent a fair bit of time on the DDVT thread, it's a pretty easy process to do after your encoding, but it might be a little complicated to do within another app (I could be wrong). And I think -QfG- is only going to make it easier to do... |
1st June 2023, 15:40 | #4705 | Link | |
For extraction I use the neat, yet quite unknown: HDR-Multi-Tool-GUI from github. The insert location in Staxrip depends on the selected encoding method. With NVENC(H265) it's in the VUI Options |
1st June 2023, 20:32 | #4706 | Link |
Big Bit Savings Now !
2.17 and 2.18 and 2.19 on Win10P64: Drag-and drop of a .avs onto Source drop region, or loading an .avs script via file manager collapses StaxRip.
2.16 works. Can anybody repeat that ? A different system Win7U64SP1: 2.19 throws CLR20r3 Error, 2.16 works. .net Incompatibilties ?
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 1st June 2023 at 21:30. |
4th June 2023, 01:28 | #4707 | Link |
Hi. I'm using Staxrip to convert HDR into SDR format with this DGTonemap method https://github.com/staxrip/staxrip/w...eview-possible
My goal is replicate same color output to this https://caps-a-holic.com/c.php?d1=16...90&i=9&l=0&a=1 But instead it went like this, horribly overexposed Then I set DGHable(exposure=1.0) and resulted like this. Better but color sightly washed another comparison https://caps-a-holic.com/c.php?d1=16...82&i=2&l=0&a=1 Any help to get video converted like the caps-a-holic site? Last edited by Arkana; 4th June 2023 at 01:49. |
7th June 2023, 16:07 | #4708 | Link |
Version 2.20.0 is released.
https://github.com/staxrip/staxrip/releases/tag/v2.20.0 |
12th June 2023, 17:22 | #4709 | Link |
Hi, I'm using Staxrip 2.6 to get ride off some noise in a video. I'm using temporal degrain 2 for that purpose but I notice that works incredible slow (0.6 fps) because it's using only un cpu core and apparently none of the cudas of my gpu. I'm wondering if I could take some advantage of the hardware with this filter or any other in Staxrip that works the same in order to speed up the process.
System Ryzen 7 5700x (8core 16 threads) Nvidia RTX 3060 ti 32 GB ram Windows 10 64bit Thanks in advance for any help. |
13th June 2023, 02:01 | #4710 | Link | |
You might want to see what SMDegrain filters do for you, I'm sure there are a few more options in the newer builds. Good luck. |
14th June 2023, 21:19 | #4712 | Link |
Hello, i switched from bdrebuilder to staxrip because bdrebuilder doesn't support VCEEncC h265 (AMD) and QSVEncC h265 (Intel).
I don't have much experience in encoding. However, I have a problem with VCEEncC h265 where my HDR information is lost. MediaInfo shows: Source: Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : SMPTE ST 2086, HDR10 compatible Codec ID : V_MPEGH/ISO/HEVC After encode with StaxRip VCEEncC h265: Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L5@High Codec ID : V_MPEGH/ISO/HEVC Why the HDR information are missing? And why it change the format profile? Can anyone help me? What i have to change in the settings? If I encode with QSVEnc h265 (Intel), then the information remains the same as in the source. however, it takes longer, so I would like to encode via AMD. Thank you Regards from germany |
3rd July 2023, 08:16 | #4714 | Link |
Version 2.21.0 is released.
https://github.com/staxrip/staxrip/releases/tag/v2.21.0 |
6th July 2023, 02:28 | #4719 | Link | |
It's NOT v2.22.0 yet !!! rav1e is an AV1 encoder... |
