21st December 2018, 14:23 | #101 | Link | |
Groucho's Avisynth Stuff |
21st December 2018, 19:08 | #104 | Link |
I build with a pretty generic MSYS2 / MinGW environment which is kept up-to-date by the media-autobuild_suite. If OpenCL is enabled for ffmpeg, I suppose it is enabled for x264 as well.
And my H is capital. |
21st March 2019, 20:17 | #109 | Link |
I'm also working, nice and slow, to implement almost all the t_mod patches to the real r2969 version, not the "special" version i'm using for now.
Almost, because there is two patches i'll not implement : the avi output and the audio support. These patches are big and very difficult, but the most critical issue, is that they are using deprecated ffmpeg functions, needing a too old version of ffmpeg not compatible anymore with actual real r2969 version. And i have no idea/skill/knowledge for updating these patches which need to be rewritten with actual ffmpeg functions.
My github. |
21st March 2019, 20:56 | #110 | Link | |
10th April 2019, 20:34 | #111 | Link |
I've finsihed implemening all the patches (even the "audio" and "avi ouput") of the tmod version on the last real r2970 version, avaible on my github on t_mod_New, builds are in progress, release soon.
Quick test seems ok, but i'm not using all the tmod features (the "audio" part for exemple, i'm not using it, so not tested...).
My github. |
4th May 2019, 10:23 | #114 | Link |
I don't know what vanilla has, you'll have to compare the patch applied.
About the new AQ, i think you refers to the TriAQ patch, wich add aq2 and aq3 mode. The original author of this patch made it most for anime purpose. Even if nothing prevent you to use them on something else than anime, for the few i've understood from aq3 mode, its purpose is mostly for anime "kind" video. After, aq2 mode may be a more generic use. Unfortunately, there was almost no information on this patch... But my real advise would be to try.
My github. |
14th May 2019, 16:53 | #115 | Link | |
15th May 2019, 08:51 | #116 | Link |
Don't mix aq-mode (2 or 3) with aq2-mode or aq3-mode ! They are absolutely not the same thing.
aq2-mode and aq3-mode are others aq modes added by the TriAQ patch, as i've said.
My github. |
15th May 2019, 23:34 | #117 | Link | |
I think some renaming is in order! |
4th August 2019, 10:15 | #119 | Link | |
FWIW:
https://artifacts.videolan.org/x264/ Quote:
