3rd December 2011, 17:24 | #7541 | Link |
I've uploaded one file to a more reliable hoster. The other one is impossible to download:
http://www.mediafire.com/?vp7lg2182d4fqag |
3rd December 2011, 17:30 | #7542 | Link |
Can it be solved by manually overriding the (incorrect) flags?
A future tray icon could harbor such an option, shown only for content that is known for possibly having incorrect flags (like MPEG-2). For example submenu called "Interlacing" with entries like Auto-detect/Assume Progressive/Assume Interlaced/Assume IVTC. The override naturally only applies to current playback session and resets to default audio-detect for next file. Changing the setting should give on-the-fly effect, or auto perform a seek to make it apply.
MPC-HC 2.2.1 |
3rd December 2011, 17:54 | #7543 | Link |
Here's the other sample:
https://rapidshare.com/files/1326861...ofOmission.zip |
3rd December 2011, 18:01 | #7544 | Link |
What could be done to make them play better would be to just apply the soft-telecine if its flagged properly, resulting in a hard-telecined fluid 30fps stream. If someone wanted, they could probably IVTC that back then with AviSynth or such.
This is however a post-processing task IMHO. I set the repeat flags on the output samples, so a post-processor could handle it completely.
3rd December 2011, 22:39 | #7545 | Link | |
quack quack
nevcairiel, do you know much about DVB-T subtitle support in LAV splitter/MPC HC ?
4th December 2011, 00:55 | #7546 | Link | |
Hi NevCariel (and others), sorry for the previous unreliable file hoster. I posted on two new file hosting sites below; which should hopefully be better. I really would like some smart people to personally try to play these files.
Maybe I might have given the wrong idea... These videos aren't just a couple of unique video encodings that I'm trying to playback. Regardless of how bad of an encoding these files are, millions of people play this exact video encoding format every day 24/7 (for the last several years...and for many more); as this is the native format that the largest cable TV provider in the United States uses... Comcast. At least, this is EXACTLY how they encode all their "Premium HD" channels (not local channels). Various types of cableboxes and hardware "HD" media players have no problems decoding these files at full quality (using ALL frames). Hardware based mpeg2 decoding on modern Nvidia display adapters may need some help (not sure about ATI or Intel). I'm hoping someone here can find a clever way to find an automatic directshow playback solution that playback these files and other files completely automatic (system-built filtergraghs and respective filter settings) without compromising picture quality; just like standalone HD media players. Ideally, having LAV Video decoder handle these types of encodings properly/automatically without quality loss. Here they are... http://hotfile.com/dl/136663686/0a58c79/Dext.zip.html http://hotfile.com/dl/136662412/0ddc...sible.zip.html http://www.megaupload.com/?d=8D8Q1Q5G http://www.megaupload.com/?d=D8X708QK Thanks so much! I would be forever grateful if there's a full quality automated directshow solution for these and other more standard files in hopefully a single video decoder. -MKANET Quote:
4th December 2011, 04:42 | #7548 | Link |
Both LAV and the dtsdecoderdll.dll do regular DTS-ES just fine, but not ES matrix. That disc has a dts-es matrix core, but the DTS-HD MA audio appears to be 5.1. I never saw the point of DTS-ES matrix, and luckily neither did most disc producers, cause there's very few discs with that audio.
MSI MAG X570 TOMAHAWK WIFI, Ryzen 5900x, RTX 3070, Win 10-64. Pioneer VSX-LX503, LG OLED65C9 |
4th December 2011, 05:21 | #7549 | Link | |
You're right!
I didn't believe it until I saw it with my own eyes. Potplayer plays it very well and very sharp in detail using it's internal mpeg2 decoder with hardware acceleration without any post processing. It looks like Potplayer might have been tested with these types of interlaced television files.
NevCariel, please... could you try to see why Potplayer's FFmpeg-based hardware decoding can; and, see if it's possible to get LAV video decoder to decode these types just as well? I would very, very much appreciate it. Quote:
4th December 2011, 06:00 | #7550 | Link |
How can I downmix AC3 5.1 to stereo 2 speakers output in my Windows 7 notebook with LAV? Do I need to install another directshow mixer? In this case how can I connect LAV 6 channels output to this mixer?
4th December 2011, 07:13 | #7552 | Link | |
Then again nevcairel is a real smart cooking and quick draw developer :0 |
4th December 2011, 08:57 | #7553 | Link | |
Switch LAV Video to software for MPEG-2 as well, and playback should be better. At least for me, in software mode it seemed acceptable, even fine. I have no control over CUVID hardware decoding, either it works or it doesnt - if it doesnt, complain to NVIDIA.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 4th December 2011 at 09:02. |
4th December 2011, 09:46 | #7554 | Link |
I had some problems with lavfilters, first it couldn't properly render a corrupted mp3, being corrupted there wasn't much to discuss but winamp had no problems whatsoever so that made me think it could be improved. I deleted it by mistake, even when I had in mind to keep it for you to check :/
Also please check the clip in this thread, in graphedit I could split audio and decode it, but not video despite I was using ffdshow with its MS Video->libavcodec module setted on. So my guess is LAV Splitter wasn't communicating well with ffdshow. At last there is something very annoying lately. I don't think its MPC-HC fault but I explain. When I have a file with a video and audio stream, and in the same folder another audio file with the same name, when I open the video I get LAV duplicates for Splitter and Audio. This is very strange and makes both audio play at the same time without the ability to disable, or select just one of them. Before it was one LavSplitter and inside you could see all the possible streams and choose alike. |
4th December 2011, 10:39 | #7555 | Link | ||
Even crashes with MPC-HCs internal AVI splitter or the MS AVI splitter. I could probably try adding support for this format to LAV Video, though. Quote:
To stop multiple tracks playing at the same time, you need to enable MPC-HCs internal audio switcher.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 4th December 2011 at 10:50. |
4th December 2011, 11:26 | #7556 | Link |
I checked now with an "old" version I had 0.38 and it was the same, same when using ffdshow so I must have been mistaken with mkv playback behaviour, or when I had audio switcher on by default for audio delay, not now anymore since you added it to lavaudio (I use it a lot so thanks!) so enabling audio switcher is yet another resources hog for the player I thought I had got ridden since then. Do you recommend another player which LAVFilters work best?
Also it's really pitty I deleted the mp3 because it was a good straight to the point case that I don't happen to encounter much. I tried to get it back with recuva but nothing. I will come back again if I find something worth for you to improve the filters. |
4th December 2011, 12:41 | #7557 | Link |
Nevcairiel, I have a flash video that causes the media player stop responding. If I playback and enter the LAV settings during playback then exit via OK, Cancel or Apply and then seek afterwards it occurs.
Tested with both the latest SVN and official release MPC and Potplayer using LAV 0.42. I gave the latest nightly LAV a go as well but no change, sample below. http://www.mediafire.com/?246bybvmhpyhakc |
4th December 2011, 13:55 | #7558 | Link | |
4th December 2011, 14:08 | #7559 | Link | |
LAV Splitter works fine with FFDShow (< rev3823) on CRAM and RLE video though.
My hobby website |
4th December 2011, 16:21 | #7560 | Link |
Those are paletted formats. Libavcodec expects the palette in a SideData packet. It must be extracted from the extradata and put in a sidedata packet. When using libavfromat that might get done automatically? That is possibly why it works with LAV splitter and not with MS splitter.
MPC-HC 2.2.1 |
