15th March 2009, 13:51 | #2943 | Link |
Life's clearer in 4K UHD
GUI tweak suggestion
How about the following changes to the (MPEG-2) "AR" layout: -
Cheers
15th March 2009, 13:53 | #2944 | Link |
Ok, but the append feature was broken in the last version I tried (v1.8.24), which also had not corrected the clpi issues... So I didn't realise that was the case until this version. Thanks for pointing that out.
There have been several versions released within the last few days so I think I can be forgiven for being a little "behind" in the times. Last edited by Ryu77; 15th March 2009 at 14:04. |
15th March 2009, 14:38 | #2945 | Link |
Location: The Great North (the better half of North America)
Since the new versions have been coming out... and since the TrueHD bug has been fixed, has anyone experienced issues with TrueHD muxing?
I muxed a TrueHD movie maybe a week or 10 days ago, I cannot remember what version I used. The TrueHD does not play... sorta, the center channel is not present, surrounds and fronts are playing. The AC3 core works fine. I'm demuxing from my AVCHD FAT32 collection and I'm going to re-process as a new THD+AC3 and PCM tracks... we'll see. |
15th March 2009, 14:49 | #2946 | Link | |
Hey Now!
15th March 2009, 14:50 | #2947 | Link |
Hey Now!
Talked with smlabs folks and thier take on using pcm files is that they must contain the 4 byte HDMV_LPCM_audio_data_header on each frame before being used with tsmuxer..hence we may not be able to get rid of using pcm2tsmu on pcm files from eac3to.
they did slip me a bit of source code..hehe Code:
This file does not contain LPCM audio headers, so tsMuxeR can’t recognize file format. Each LPCM frame MUST be preced 4 byte HDMV_LPCM_audio_data_header Syntax No. of bits Mnemonics HDMV_LPCM_audio_data_header() { audio_data_payload_size 16 uimsbf channel_assignment 4 bslbf sampling_frequency 4 uimsbf bits_per_sample 2 uimsbf start_flag 1 bslbf reserved 5 bslbf } |
15th March 2009, 17:25 | #2948 | Link | |
I'm using a PS3, FAT32 1TB external, and AVCHDManager. The problem is gone now. I demuxed, remuxed with the latest version of tsMuxeR, which I know handles TrueHD fine... and it works, both the TrueHD and the PCM file I created. |
16th March 2009, 02:37 | #2950 | Link |
greetings.
i use tsmuxer for create a blu ray structure, but the final size is to big to burn in a dvd-5 4.7gb. I use tsspliter but when i split the file i cannot see the subtitles. But in a another file and smaller file <4.7gb i can see the subtitles very well. Any suggestions?? thanks in advanced. |
16th March 2009, 05:24 | #2951 | Link | |
Hey Now!
16th March 2009, 08:19 | #2952 | Link |
I've never had much luck with tsmuxer splitting and subtitles/chapters, I don't why it doesn't display subtitles correctly, the timing is right and all. The chapter problem is trivial. But PopBD does something like jamos describes except all in one mux somehow. People have reported subs working on hardware players.
What I have had luck with for subtitle displays on software and hardware players (the chapters are still messed up) is splitting with mkvmerge then creating BD structures from the split files, it doesn't support sup subtitles though which is a real shame. I used to have a batch file that would split mkv's in half with dragging and dropping to it. It was something like this (doesn't work) Code:
@echo off for /f "delims=" %%i in ('dir /od /b "%1"') do ( SET size=%%~zi ) set /a halfsize=%size%/2 "mkvmerge" -o "%1-.mkv" -S %1 --split size:%halfsize% pause Last edited by turbojet; 16th March 2009 at 08:22. |
16th March 2009, 12:32 | #2953 | Link | |
Yeah, i have done that in first place but no results :-( Turbojet, i also use mkmergue, and i already tried in my case to split with mkmergue the file and later create the BD structure from the split files but no results. My subtitles is SRT. |
16th March 2009, 16:10 | #2956 | Link |
FWIW, the bugs I reported have just been fixed. Also I've been told that WAV64 input support is coming in a future version. So the 4GB problem should soon be gone.
So things are looking good, as far as I can say! |
16th March 2009, 17:28 | #2959 | Link | |
A few hours ago i tried with POPBD and still see and hear all good, but the subtitles i can't see. As i told before, only when i split the file. When i push the remote control it let me select the language, in my case only a subtitle, but no display anything. Thank you for all your recomendations. |
tsmuxer |
