Old 14th March 2009, 18:24   #2921  |  Link
ron spencer
DVD Magistrate
was .24 the last version with a gui to download? I am getting lost in these updates LOL
thanks!!!
ron spencer is offline   Reply With Quote
Old 14th March 2009, 18:28   #2922  |  Link
jamos
Hey Now!
thanks!!!
yes just copy the .24 gui into the folder with the newer tsmuxer.exe's it will work with the newer versions as long as they are in the same directory.
jamos is offline   Reply With Quote
Old 14th March 2009, 18:45   #2923  |  Link
jamos
Hey Now!
Am talking with the TSmuxer devs on LPCM and WAV issues with 7.1 they admit there is some channel ordering problems..
Sent: Saturday, March 14, 2009 6:08 PM
To: xxx
Subject: RE: LPCM/WAV 7.1 mixing channel order.
When tsMuxer create LPCM track from 8-th WAV file, muxer made next channel reordering:
5-th WAV channel ---> 4-th LPCM channel
7-th WAV channel ---> 5-th LPCM channel
8-th WAV channel ---> 6-th LPCM channel
6-th WAV channel ---> 7-th LPCM channel
4-th WAV channel ---> 8-th LPCM channel
1-th WAV channel ---> 1-th LPCM channel
2-th WAV channel ---> 2-th LPCM channel
3-th WAV channel ---> 3-th LPCM channel
Seems this reordering is invalid. I’ll recheck this function at nearest time.
I need a clean small sample pcm file to send them..hopefully they will clean up the error with large pcm files also.
Old 14th March 2009, 19:24   #2924  |  Link
mrr19121970
@Jamos
Perhaps you can mention this too:
http://forum.slysoft.com/showpost.ph...&postcount=539
If i select BD/iso as final result, works great, all options i select are there, all is good. If i select mt2s as final result and audio is DTS-HD 7.1 on the source, the sound will always be just plain DTS 5.1
So to sum up:
M2TS
DTS-HD 7.1 works ok
Blu-Ray
DTS-HD 7.1 gets downgraded to DTS 5.1
mrr19121970 is offline   Reply With Quote
Old 14th March 2009, 21:24   #2925  |  Link
Ryu77
Ryu77's Avatar
I've also noticed that the append feature seems to be broken in tsMuxeR v1.8.24. It seems to work fine in v1.8.19 though...
Did anyone else notice this?
Ryu77 is offline   Reply With Quote
Old 14th March 2009, 21:45   #2926  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
http://www.smlabs.net/tsMuxer/tsMuxeR_1.8.29(b).zip is up
shon3i is offline   Reply With Quote
Old 14th March 2009, 22:32   #2927  |  Link
SomeJoe
Originally Posted by idbirch2 View Post
Firstly Dean, while an awesome programmer, is not involved in TSMuxer development, the resident dev here was roman76r but he sadly hasn't been attending for a while.
TrueHD is fixed for most people and definitely for those with PS3s so the best thing you can do is mail smlabs using this address describing your issue in as much detail as possible. Users here, including myself, have had very prompt replies and fixes to issues we have reported.
After reading a lot of posts in the thread, I was under the impression that deank was one of the developers.
I'll e-mail SMLabs and see if they can help out.
- SomeJoe
SomeJoe is offline   Reply With Quote
Old 14th March 2009, 23:19   #2928  |  Link
tebasuna51
tebasuna51's Avatar
You have a clean wav file with pcm contain.
Old 14th March 2009, 23:27   #2929  |  Link
jamos
Hey Now!
Originally Posted by mrr19121970 View Post
@Jamos
So to sum up:
M2TS
DTS-HD 7.1 works ok
Blu-Ray
What I understand from that link is the opposite, dts-hd 7.1 works fine in bluray (which it does) and m2ts downgrades to dts 5.1.
Old 14th March 2009, 23:29   #2930  |  Link
jamos
Hey Now!
did you check the m2ts file after you muxed it and made sure that tsmuxer did not mess with the channel ordering? according to smlabs it should mess it up. if i demux wav or pcm from it will it recorrect the order? I got a sample sent to them they are checking it.
Old 15th March 2009, 00:26   #2931  |  Link
idbirch2
Jamos is right, DTS-HD works fine with "BluRay Disc" output mode. Don't know about .m2ts output, don't use it.
idbirch2 is offline   Reply With Quote
Old 15th March 2009, 01:42   #2932  |  Link
m1482
http://www.smlabs.net/tsMuxer/tsMuxeR_1.8.30(b).zip
m1482 is offline   Reply With Quote
Old 15th March 2009, 02:13   #2933  |  Link
Mtz
Mtz's Avatar
Link not working.
Mtz is offline   Reply With Quote
Old 15th March 2009, 02:54   #2934  |  Link
m1482
Originally Posted by Mtz View Post
Link not working.
Yes it is...Try again...
Old 15th March 2009, 03:55   #2935  |  Link
jamos
Hey Now!
I also sent them a link to your pcm2tsmu thread and told them about the large pcm issue, so hopefully they will fix that also.
Old 15th March 2009, 10:48   #2936  |  Link
videobelu
join files
Thanks for this beautiful prog!
The last version 1.8.3.0 have the GUI working for Join files
but there is no a way to select multiple file to join togheter....
when the files are many this will be very useful
Thanks
videobelu is offline   Reply With Quote
Old 15th March 2009, 12:17   #2937  |  Link
Ryu77
Ryu77's Avatar
Originally Posted by m1482 View Post
This version seems to have corrected the issues in the Clip Information File (.clpi)... No more need to apply jdobbs's fixclpi patch!
Old 15th March 2009, 12:25   #2938  |  Link
G_M_C
Okay
Can we conclude most of the standing bugs are solved ?
CLPI's are build correctly ?
Pachetsize/filesize is set correctly ?
TrueHD is muxed correctly ?
How's fforwarding/reversing and/or chapter skipping working now ?
G_M_C is offline   Reply With Quote
Old 15th March 2009, 12:29   #2939  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Fine here
Old 15th March 2009, 12:43   #2940  |  Link
idbirch2
That was done several versions ago - see here and here.
tsmuxer
