27th January 2008, 02:53 | #582 | Link |
<The VFW Sheep of Death>
Strength 0.5 to 0.6 is now recommended for 0.47? Looks like I missed something here.
Recommended all-in-one stop for x264/GCC needs on Windows: Komisar x264 builds! |
27th January 2008, 03:09 | #584 | Link | |
x264aholic
On a side note, if qcomp is set to 1 and aq-strength is varied, isn't that just making AQ the rate control algorithm? |
27th January 2008, 05:09 | #586 | Link | |
x264... Brilliant!
FIRST think of Sensitivity.... What level of flatness should be considered necessary adjustment. THEN.. knowing what needs to be changed, Strength determines how radical the adjustment is. Higher Sensitivity, more should be fixed. Higher Strength, more radically the attempt to fix it. This is why while lowering one of these and raising the other, you can get a file with the same bitrate. |
27th January 2008, 06:14 | #587 | Link |
Novice x264 User
From what I've tested so far, AQ on anime look much better with strong settings (such as --aq-strength 1.0 --aq-sensitivity 20). Even though it makes file sizes large at a given crf, it still looks nice at smaller file sizes too, though doing that will compromise overall image quality.
Setting qcomp 1, aq str 0.5, and sensitivity 20 looks nice, and the file size is small, but dark areas don't get improved much in comparison. I'm going to re-run the same settings but change strength to 1.0 and see how it turns out. Sorry that I can't post numbers, I'm unorganized and everything's a mess . I'll try and get a consistent order going. |
27th January 2008, 10:33 | #590 | Link |
I did some tests on 'A knight's tale' and 'the 6th day', on both occasions I found the best aq strength and sensitivity, in regards to these two clips as strength 0.6 and senstivity 17.6 to maintain the same file size (very slightly larger, I mean by about 0.5 percent) and be of good quality. I didn't set qcomp.
Again, setting the sensitivity lower than that, even with qcomp being 1, the filesize was way undersized. The quality was also noticeable lower, but was about right in terms of its file size. Setting aq strength to 1 (auto sens.) with the same clips ended up with doubling the file size. I keep ending up with a sensitivity of around 17 for strengths of say, 0.6, and slightly lower at around 15 or 16 for strength 1 Last edited by burfadel; 27th January 2008 at 10:34. Reason: Addition of information |
27th January 2008, 10:51 | #591 | Link | |
x264 developer
27th January 2008, 11:08 | #592 | Link | |
Flying Skull
I was thinking particularly of CRF measuring quality after VAQ has done spatial bitrate distribution, so it would feed extra bitrate in from the top to resharpen the sharp bits of frames like that. Or is that what it does anyhow? {I seem to have deleted my original post by accident (!), but DS quoted it whole.} |
27th January 2008, 15:48 | #595 | Link |
A few months back I experimented with qcomp in conjunction with HAQ (pre-processed to PC Levels + MVDegrain2). It certainly produced interesting results:
AQ 0.3 5 qcomp 0 qcomp 1 source bitrate 24 1827.9 2272.1 1621.0 4762.7 Black Pearl 2270.7 1671.9 2924.5 3639.8 Carnivale 2485.2 2115.3 2942.0 6623.8 Hana & Alice 1 2102.7 2557.1 1958.2 4015.5 Monk 3207.5 2132.0 4358.8 8354.6 War of the Worlds 6829.3 3047.2 11542.4 7059.3 X-Files 1951.0 2275.5 1693.9 4821.1 Average 2953.5 2295.9 3863.0 5611.0 --crf 16 --ref 5 --mixed-refs --no-fast-pskip --bframes 8 --b-pyramid --b-rdo --bime --weightb --subme 6 --analyse p8x8,b8x8,i4x4,i8x8 --8x8dct --me umh --merange 32 --no-dct-decimate qcomp is a bit surprising. Maybe you guys are used to it. I've attached the spreadsheet containing a bit more detail. Jawed Last edited by Jawed; 27th January 2008 at 15:53. |
27th January 2008, 18:54 | #596 | Link |
Pain and suffering
AQ patch 0.47: http://akuvian.org/src/x264/x264_aq_var.47.diff
x264.735.dark.aq.0.47.exe (pthreads/mp4 = yes, made with make fprofiled) Should work i guess, patch did apply. |
27th January 2008, 20:43 | #598 | Link |
Novice x264 User
After some more testing, older anime with lots of noise and details look better (in my opinion) with high CRF and high AQ strength vs low CRF and low AQ strength (at a fixed sensitivity). Both results have their ups and downs.
-Low CRF and Low AQ strength gives a cleaner overall picture as expected, AQ but hardly seems to address ugly blocking in dark areas. -High CRF and High AQ strength results in a worse overall image quality (as expected), but dark areas look much better. This trend happens at lower bitrates. At high bitrates, the results look very similar to each other (very good quality across the board). I'm going to edit this post in a couple hours with some examples. In the meantime, this is what I have so far: --crf 28.0 --qcomp 1 aq-strength 0.5 aq-sensitivity 20: 188 MB (Sample 1) (Sample 2) --crf 33.0 --qcomp 1 aq-strength 1.0 aq-sensitivity 20: 199 MB (Sample 1) (Sample 2) --crf 34.0 --qcomp 1 aq-strength 1.0 aq-sensitivity 20: 161 MB Update: Uploaded the samples. To be honest, none of them are satisfactory lol, but I expect them to look much better in a 2-pass encode. I did a 2-pass encode a while ago (before patch .47) at lower bitrates than those, and it still looks better than both. I'm currently re-running tests with 2-pass at a higher bitrate not only to keep the final filesizes very close to each other (there's an 11 MB bias in the tests above), but to narrow the gap on the differences between high CRF/high AQ strength vs low CRF/low AQ strength. The next set of results will look much easier on the eyes. Last edited by Yoshiyuki Blade; 28th January 2008 at 00:20. |
