15th November 2009, 01:54 | #561 | Link | |
For your sample clip, because it has so much pure video and just sporadic soft pulldown, you should use field operation Honor Pulldown and then deinterlace with a filter in your script. There's no point to try to get to film rate with that clip because all the video parts will become jerk city. I'll try to improve the user manual discussion of all this when the code settles down. Last edited by Guest; 15th November 2009 at 01:58. |
15th November 2009, 04:03 | #563 | Link |
Thanks for the force film, worked for me as expected so far. Now that it's implemented do you plan on adding a Video Type FILM/INTERLACED like dgindex has?
Also is there a chance to get information window docking back in DGIndex(NV)? It seemed to disappear around DGIndex 1.5.0 or so. |
15th November 2009, 04:21 | #564 | Link | ||
15th November 2009, 04:44 | #565 | Link | ||
Also I noticed DGIndexNV takes 3-4x longer to process then DGIndex with the same video\audio. Is there a chance to speed DGIndexNV up? Maybe by multithreading. |
15th November 2009, 04:52 | #566 | Link |
Posts: n/a
Id say it is slower cause from what i can see there is more information in the index file. On a 40 minute episode my d2v file is around 300kb where the dgm file is a bit over 1mb. I don't think its that big of a deal though cause you easily make that time extra indexing time back, plus more, in the encoding stage so the overall indexing/encoding is faster with NV.
15th November 2009, 05:18 | #567 | Link | |||
15th November 2009, 09:33 | #568 | Link | |||
Thanks. Also is there or can there be a value in the project file assigned to a frame that signifies film or ntsc? This is very helpful for TIVTC's d2v parameter when there's some but not all FILM frames. Quote:
I found out that if I minimize DGIndexNV it finishes the same set of vob's in 2:48 a huge improvement. I tried disabling display while the screen was showing and it made no difference. This is with Windows 7 x64. Any idea why minimizing DGIndexNV has such an impact? Also a few things I see different between DGIndex and DGIndexNV (by design?): - Force film still shows 29.97030 fps in DGIndexNV - Saving a project auto adds .dgm (or .dgv/.dga) even if it's already in the file name in DGIndexNV After some comparing dgnv resize to lanczos I found out dgnv kind of blurs the image and misses a lot of details. Kind of a bummer since most of the speedup comes from dgnv resizing but is there any chance of changing/improving the resizer that's used? Here's an example, it's most noticable in the bushes (trees): DGNV Lanczos Last edited by turbojet; 16th November 2009 at 01:24. |
16th November 2009, 17:31 | #569 | Link |
Missing frame
Hi neuron2
I'm experiencing a little weirdness with dgdecnv200b3. This file indexes to 63 frames but DGDecodeNV.dll only appears to serve 62 frames. -- Nikolaj Last edited by nixo; 16th November 2009 at 17:34. |
16th November 2009, 18:12 | #571 | Link |
It's from the very end of a Blu-ray.
http://www.mediafire.com/file/1ylzzztwi2b/sample.dga -- Nikolaj |
16th November 2009, 19:45 | #572 | Link | |
Possible typo in DGDecodeNVManual.html?
16th November 2009, 21:03 | #573 | Link |
Here is the end of the DGA:
IDR 109472 FRM 7 0 PIC 0 FRM 5 3 PIC 0 FRM 6 1 PIC 0 FRM 6 2 PIC 0 FRM 5 5 SIZ 1920 x 1088 FPS 25000 / 1000 CODED 63 PLAYBACK 63 You can see that the POCs for the last GOP's frames are: 0 1 2 3 5 4 is missing so 5 is discarded. |
16th November 2009, 21:30 | #575 | Link | |
I thought the point of use_pf=true was to use the indication of progressive frames in a way so that only the interlaced frames would be de-interlaced and the progressive frames would "hopefully" be left alone.
17th November 2009, 17:27 | #578 | Link | |
I would like to use deinterlace=2 for a particular TV show that is pure interlaced, except for a few places during the commercials. When the video is being served, none of these frames with soft pulldown will ever be served (because I edit the commercials out with Trim commands in my script), but because they are in the index file, if the pulldown is not honored it will obviously cause audio sync issues. Is there any way you can make it work in this situation, or would it be just as hard as getting honor pulldown working with deinterlacing in all cases? If it is, I know I can always fall back to another Bob filter in my script, but I really like using the Nvidia one. Thanks! Matt |
18th November 2009, 23:38 | #580 | Link |
Thanks. They don't seem to be doing that anymore, as all my shows this season do not have any pulldown. Now that my tool to fix audio sync when there are glitches in the stream is almost done, I can finally start working on all the shows I have recorded from last year...
