Old 7th September 2009, 16:30   #321  |  Link
Inspector.Gadget
I've begun to have an odd problem with the NV suite. Loading files into any of the NV tools results in a "GPU decoder: Failed to create video decoder [100]".
I'm running a 9650M GT (ASUS) on Windows Vista SP2 x64, 4 GB RAM, newer C2D CPU. I recently updated my video card drivers to version 186.37 after relying on the 179.XX series for several months because the 185.XX series was broken on the 9650M GT. I ran Driver Sweeper before installing this latest driver, so I don't think it's a matter of conflicting .dll files. CoreAVC's CUDA works fine with these drivers.
Any suggestions, neuron2 or others, as to what my problem might be?
Inspector.Gadget is offline   Reply With Quote
Old 7th September 2009, 16:42   #322  |  Link
GZZ
You should update to the latest 190.62 driver as it says in the readme file. Your error is a classic driver fucked up (well atleast it was on my computer when I last got it). So try uninstall, reboot, install new driver, reboot and then see if it works.
GZZ is offline   Reply With Quote
Old 7th September 2009, 16:43   #323  |  Link
laserfan
Aging Video Hobbyist
Unless you're using an older version of DGTools, you need to be upgraded to latest nvidia, which is 190.62 (see Readme.txt).
laserfan is offline   Reply With Quote
Old 7th September 2009, 18:58   #324  |  Link
Inspector.Gadget
Unfortunately, the 190.xx series has not been ported to my GPU. Oddly enough, the NV tools were working fine with the 179.XX and 185.XX series (at least when the latter didn't puke). But shame on me for not consulting the readme. Thanks.
Old 7th September 2009, 23:41   #325  |  Link
laserfan
Ouch, you're right of course--not sure why that [notebook] GPU would get left behind??? Anyway sorry for my misinformation...
Old 8th September 2009, 00:00   #326  |  Link
Inspector.Gadget
Not your fault, NVIDIA seems to have more difficulty than they expected getting drivers for this model that don't generate artifacting, BSODs, etc.
Old 8th September 2009, 04:52   #327  |  Link
woah!
Originally Posted by GZZ View Post
I have used the resize function in NV tools for like 20 movies+ (1920x1080 -> 1280x720) for BD5/9 without any problems. Try reinstall your Nvidia Driver, first uninstall, then reboot, then install, then reboot, then try again and see if it works. Also please provide the avs script you are using and also try another source and see if it works...
well over the last day or so i have tried many different things to solve this. prime95 is perfect over 13hrs, uninstall reinstall drivers, used revo to do that to make sure all crap was gone. system is box standard, no oc'ing and still blue screening at different times, when encoding if i say opened a mkv in mpc-hc it would crash to blue screen. now i have gone back to 190.38 drivers with beta7 and so far no issues what so ever?
seems i have reached a certain level on this system so i will stay at this until i upgrade... oh i have a 260gtx old version not the 216shader version, and a intel q9550
woah! is offline   Reply With Quote
Old 8th September 2009, 08:53   #328  |  Link
GZZ
Its hard to say what is wrong, but I dont think its DGtool. If it can crash to blue screen (blue screen of death ?) when opening a mkv file, then you have a hole other issue. My system are almost like yours, its a GTX 260 (216 core edition) and a Q9450 OCed to 3 Ghz and it have no issue at all. I'm also running Vista 64 bit.
Have you tried the Intelburntest program, its really evil (some says its better then prime and also faster). Just run it for 30 min and see if all the calculation are the same. Be aware that it will raise your CPU temperature by 20+ degress over your full load. So if your normal full load is 60 degress, then this program can raise it to 80+, so if your cooling is bad it will fail. Get it here (freeware) http://www.ultimate-filez.com/files/IntelBurnTest.zip
Old 11th September 2009, 17:55   #329  |  Link
Originally Posted by Efenstor View Post
I'd better wait for the final solution.
See here:
http://forum.doom9.org/showthread.php?t=149441
Your feedback will be appreciated.
Old 13th September 2009, 15:04   #330  |  Link
Efenstor
See here:
Yessss!
That's it.
Feedback is on the way (in the aforementioned thread).
Efenstor is offline   Reply With Quote
Old 16th September 2009, 23:12   #331  |  Link
Shirtfull
Crop line in NVBeta9.
Earth The Power of the Planet on BBC HD, recorded this back in Nov 2007 (1440x1088 MBAFF) and when resizing to 1280x720 with no crop, the crop line appears at the bottom of the NVBeta9 screen and the resized image.
Sample provided
102Mb
http://rapidshare.com/files/281072275/sample.ts_9
Shirtfull is offline   Reply With Quote
Old 17th September 2009, 00:01   #332  |  Link
It appears to be that way in the source. Have you tried it in other players?
You'll have to overcrop it before the resizing.
Old 18th September 2009, 07:01   #333  |  Link
hxhxd
I encountered a problem with beta9. Yesterday I encoded a dvd using x264. It took about 14 hours. The problem is CUVIDServer quited while encoding. no prompt, no log.
After checking encoded files left, I guess CUVIDServer exits after 9.4 hour from beginning.
It's hard to find some debug info. Everything look good except this.
My system is server 2008 64bit, display driver is 8.16.11.9062, 8400gs.
Any idea? Thanks!
hxhxd is offline   Reply With Quote
Old 18th September 2009, 08:18   #334  |  Link
woah!
was the source material maff or interlaced? were you using the resizer/deinterlacer.
Old 18th September 2009, 10:23   #335  |  Link
halsboss
likes to tinker
your website appears to have been hacked
halsboss is offline   Reply With Quote
Old 18th September 2009, 13:36   #336  |  Link
I don't see any problem with it. Can you tell me why you think it was hacked?
Old 18th September 2009, 14:03   #337  |  Link
deets
any chance of having a drop down for resizing, with some presets or some way to enter the info in the prog without having to edit the avs file?
deets is offline   Reply With Quote
Old 18th September 2009, 14:08   #338  |  Link
halsboss
likes to tinker
Sure, http://neuron2.net/ has this on the front page and on other pages. Noticed it on the PC at work and then as well as the PC at home... firefox on both, noscript active adblockplus active.
"# glucovance drug generic
# order glucovance cash on delivery
# low cost glucovance now
# glucovance for sale online
# purchase glucovance online overseas
# best pric"
Interestingly, IE8 doesn't display it. But, if I "view source" in the lower frame, it's there.
eg a snippet from the heap of stuff:
<!-- [f0049cafa0bb81ee8256da71d8976e9d --><!-- 0218123521 --><noscript><ul><li><a http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=3088">glucovance drug generic</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=5215">order glucovance cash on delivery</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=4690">low cost glucovance now</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=1313">glucovance for sale online</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=3230">purchase glucovance online overseas</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=719">best price of grifulvin</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=5050">purchase grifulvin online overseas</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=147">purchase grifulvin overnight delivery</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=5624">order grifulvin without prescription</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=275">get a grifulvin without prescription</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=3821">purchase grifulvin without prescription</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=4542">where can i buy griseofulvin without a prescription</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=1587">generic for grisactin pills</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=4661">how to get grifulvin</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=715">low cost grifulvin now</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=330">grisactin drug generic</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=4773">order grisactin without prescription</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=4264">buy grisactin medication</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=876">cheap grisactin tablets</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=5576">cheap grisactin no rx</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=1495">buy grisactin overnight shipping</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=2303">grifulvin v online without prescription</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=1098">order grisactin cash on delivery</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=508">buy grisactin in the uk</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=4318">grisactin without a prescription</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=17">gyne-lotrimin online without prescription</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=290">how to get clotrimazole vaginal</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=1319">buy gyne-lotrimin in the uk</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=5812">order gyne-lotrimin cash on delivery</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=5157">gyne-lotrimin drug generic</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=4533">gyne-lotrimin c.o.d.</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=2668">buy clotrimazole vaginal online without rx</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=4153">buying gyne-lotrimin online without prescription</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=3013">best price of clotrimazole vaginal</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=3885">buy cheap gyne-lotrimin online</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=1191">hoodia gordonii weight loss patch</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=3703">hoodia gordonii</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=2788">purchase hoodia without script next day delivery</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=1330">where can i buy hoodia without a prescription</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=3103">cheap hoodia tablets</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=3022">buy hoodia gordonii online without rx</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=5087">hoodia suppliers australia</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=1424">hoodia direct from bassaroot hoodia farms</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=4545">buy hoodia medicine</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=3516">hoodia diet-max</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=2128">purchase hoodia online overseas</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=4827">generic for hoodia pills</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=2090">hoodia cactus african</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=114">body choice hoodia</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=5713">buy cheap hoodia online</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=1411">pure hoodia</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=1606">natural weight loss appetite hoodia</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=1781">hoodia buy</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=2478">hoodia for sale online</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=2116">low cost human growth hormone now</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=6055">buy human growth hormone medicine</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=2498">order human growth hormone cash on delivery</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=2360">order human growth hormone overnight without prescription</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=1117">hgh human growth hormone</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=2072">natural human growth hormone</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=1303">buy discount human growth hormone</a></li><li><a href="http://www.sarunicamp.com/saruni_gallary/Migration/description.php?ulls=1&position=5638">human growth hormone somatropin buy online</a></li><li><a
Old 18th September 2009, 14:29   #339  |  Link
halsboss
likes to tinker
Oh, I was notified today by email of the change in the first place by "watchthatpage.com" and it listed some of that too.
Old 18th September 2009, 14:53   #340  |  Link
A case of "google poisoning". Pop that into Google for a real horror show.
At least they didn't destroy anything. It'll take me a while to clean all that stuff off.
In the meantime, I have refreshed beta 9 with an update to the CUVID server. If an encode is violently killed, previously the server would lock up and require a task manager kill. Now, its Exit function continues to work, and it should recover itself within 4 seconds of the violent kill such that killing it should not be necessary. So redownload beta 9 and get CUVIDServer.exe. Please advise if this change causes any problems.
