Old 14th October 2018, 12:35   #53201  |  Link
nevcairiel
Originally Posted by HDR View Post
It accomplishes the same thing that HDR10+ and Dolby Vision does.
Not really, its just "fake".
Actual dynamic HDR has mastering engineers controlling the parameters of every scene, so that intentional brightness differences are fully maintained, which can give a movie much more depth.
Those automatic algorithms have no clue about the creative intent of a movie and they just "unify" everything, which can take away a lot of depth.
For me, its in a similar boat to the extremely cranked up brightness and color vibrance, or those fake HDR encodes you can find online made from consumer SDR sources. It makes for good show floor presentation, but its far from the creative intent of a movie. If you are into that sort of thing, go nuts. But don't claim your subjective preference is the only valid way to watch anything, because thats just silly.
Old 14th October 2018, 12:40   #53202  |  Link
vanden
Originally Posted by chros View Post
Edit: it's fixed in madVRhdrMeasure10, just wait for the new release. (Although my laptop doesn't have enough juice to use both "compromise tone & gamut mapping ..." unchecked and "highlight recovery" at the same time )
Yes it works properly with "madVRhdrMeasure10"
vanden is offline   Reply With Quote
Old 14th October 2018, 13:03   #53203  |  Link
el Filou
el Filou's Avatar
I am personally suspicious of someone whose account name is 'HDR' and whose very first actions on this forum consist of coming to madVR's thread just after the release of the best HDR processing featureset in a renderer, to say LG's TVs are doing a better job.
HTPC: Windows 10 1809, MediaPortal 1, LAV Filters, ReClock, madVR. DVB-C TV, Panasonic GT60, 6.0 speakers Denon 2310, Core 2 Duo E7400, GeForce 1050 Ti
Old 14th October 2018, 13:36   #53204  |  Link
Manni
Exactly
Win10 Pro x64 b1909 MCE
i7 3770K@4.0Ghz 16Gb@2.18Ghz EVGA GTX 1080 Ti SC2 11Gb@2GHz 441.66 RGB Full 8bits
MPC-BE/LAV/MadVR/jRiver/MyMovies V5.25/CMC V3.1
Denon X8500H>HD Fury Maestro>JVC RS2000
Old 14th October 2018, 13:36   #53205  |  Link
zapatista
a general question for the video experten here:
is it possible with madvr to use the GPU (for ex from a gtx 1060) to play mp4 video files instead of it being processed by the cpu ?
my haswell i7 cpu seems to do most of the work , and i am hoping to offload it to the more modern GPU that might be more efficient (fine for mp4 @ 2k, but the cpu maxes out on 4k mp4 files while the GPU is only @ 10% load). with HEVC files of same resolution, the GPU does most of the work and the cpu stays @ 20 % for ex, this is much more hardware cpu/gpu efficient (i know hevc is a much more efficient file format, but am hoping the gpu can be used more for mp4 decoding now to)
zapatista is offline   Reply With Quote
Old 14th October 2018, 14:05   #53206  |  Link
sneaker_ger
Madvr doesn't do video decoding by itself, other components need to handle that. Usually, players/decoders that allow HEVC hardware decoding also allow H.264/AVC hardware decoding (H.264/AVC is the most common codec in mp4 files, but there are others). For example LAV Video/MPC-HC can do that.
Old 14th October 2018, 14:06   #53207  |  Link
kostik
Anyone else have a pinkish-magentish screen if you choose YCbCr 4:2:0 when watching HDR content (MADVR shows NV HDR...) ?
Switching to HDR mode using windows display settings , works fine.
driver version : 416.34 , latest madvr build
TV :LG OLED 65C8 ; PC:CPU: I7-7700K OC 5.1GHz ; GPU: Gigabyte GeForce® GTX 1080 WINDFORCE OC 8G ;Memory: Corsair Vengeance RGB (2X8GB) DDR4 3100MHz, ;
kostik is offline   Reply With Quote
Old 14th October 2018, 14:16   #53208  |  Link
blaubart
do i really have to quote your ycbcr stuff?
just read the FAQ: https://forum.doom9.org/showpost.php...16&postcount=2
If you knew how deep I doubt in internet being the right place to discuss tiny differences in video playback... One is telling what he sees another is telling what he sees.. then wrapped into some convenient theory (including 'I am right') that's it.
Nobody can see into the ohters screen so no true comparision at all - so no truth at all - so happy dicussion till the end of all days..
blaubart is offline   Reply With Quote
Old 14th October 2018, 14:24   #53209  |  Link
so you still didn't read it and understand that madVR has nothing todo with how a GPU is turning the RGB data from madVR to yCbCr...
i take from this it is working fine with RGB?
Old 14th October 2018, 14:32   #53210  |  Link
kostik
Working fine with ycbcr 4:2:2/4:4:4 and RGB … only happens with ycbcr 4:2:0 when the screen switches to HDR mode (NV HDR not Windows HDR which works fine)…
Old 14th October 2018, 14:34   #53211  |  Link
blaubart
@ huhn ..so also you didn't read and understand what I'm saying - this may be the beginning of a wonderful friendship
Old 14th October 2018, 14:34   #53212  |  Link
should be a driver bug.
madVR doesn't do anything different if you send RGB, 4:2:0 or something like that.
Old 14th October 2018, 14:52   #53213  |  Link
Thunderbolt8
Madshi knows about this and tries to do something about it.
ok, thanks.
Laptop Acer Aspire V3-772g: i7-4202MQ, 8GB Ram, NVIDIA GTX 760M (+ Intel HD 4600), Windows 8.1 x64, madVR (x64), MPC-HC (x64), LAV Filter (x64), XySubfilter (x64)
Old 14th October 2018, 16:29   #53214  |  Link
zapatista
thank you for the answer, i am not sure how to implement your advice however
i have installed madvr, mpc-ht and the LAV Filters 0.73.1 , and been using madvr for many years now on my older htpc setup (but have no expertise in video technology and what exactly does what part)
what settings should i look at to ensure my new GPU (gtx 1060) does the mp4 (h264/AVC) decoding so i can lower the CPU load on my older haswell processor
ps: my current newly re-installed mpc-ht and madvr settings are pretty much still set at default right now
Old 14th October 2018, 16:54   #53215  |  Link
the default settings from mpc-hc do use hardware decoding by default by using DXVA2.
try this guide: https://www.avsforum.com/forum/26-ho...tup-guide.html
it's old but still "accurate". the Video Decoding part is where you should look into.
i recommend DXVA2 copyback.
hardware decoder doesn't really put strain on a GPU.
because a file is "mp4" doesn't mean it can be hardware decoded just to make this clear.
Old 14th October 2018, 17:52   #53216  |  Link
Warner306
I can't live without LG's "active HDR". It tries to mimic HDR10+/Dolby Vision by analyzing the whole scene and adjusting brightness and tone mapping per frame. I don't know if this is something madshi is working on or is even possible with madVR, but until/if this happens I'm sticking with LG's implementation.
It really helps with shadow detail in dark scenes. Often times madVR is simply too dark compared to LG with active HDR turned on.
You can use madVR for tone mapping and still turn on LG active HDR, but then you've got kind of a double tonemapping situation where the tv is trying to dynamically adjust brightness and highlights after madVR has already tone mapped. It doesn't quite look right IMO. Often times it will just make the highlights even darker.
Both madVR and all of the current OLED TVs do dynamic tone mapping that is similar to HDR10+. The goal is to reduce brightness compression in any scene where this is possible by ignoring the single peak brightness variable and measuring each frame and each scene independently. The brightest scenes usually see no relief in compression, but dimmer scenes can be brighter.
madVR's implementation generally alters the information above reference white (100 nits), while the newest LG OLEDs (especially the 2018 models) appear to alter reference white as well as the brighter specular highlights. The LG OLEDs are known to be the most dynamic when it comes to changes in brightness compared to solutions offered by Sony, Panasonic and Phillips. This is probably a matter of taste. None of the OLEDs should be boosting the brightness of any values in an artificial way, just restoring the recorded brightness of each pixel whenever possible. PQ values are absolute in terms of display nits and each pixel is meant to be displayed at a specific brightness. Tone mapping makes the image darker and sometimes causes a visible loss of detail when done poorly as well as some loss of color saturation for bright image areas.
Old 14th October 2018, 17:58   #53217  |  Link
Warner306
Originally Posted by blu3wh0 View Post
I thought that madVR does do dynamic tone mapping to adjust brightness to the whole image, but I think this only seems to work in SDR. It should be able to do this since it does know peak brightness of each scene. However, for most of the range when output in HDR, brightness seems to be unchanged. Is this due to the static metadata that is sent for HDR? Are our TVs only relying on the HDR nits mastering in the metadata to scale brightness? Maybe if the metadata can be manipulated to send peak brightness of the scene as mastering metadata, it may change the brightness range dynamically. I don't know.
If you set pixel shader to 750 nits, only pixels above 750 nits will receive any tone mapping at all. This is how the current test builds work when "measure each frame's peak luminance" is checked. So the first 750 nits should be displayed 1:1 on your display (only if it is that bright), and anything brighter will be tone mapped. This means only very bright scenes should show a visible change.
Of course, this depends on how your display reacts to the input signal. It may take the 750 nit input and compress it instead of displaying it with clipping, which would be inaccurate and less bright than it should be.
Old 14th October 2018, 18:35   #53218  |  Link
corporalgator
How much of a load are we talking about? If you stick to letting your CPU decode, that frees up more of your GPU for madVR rendering.
corporalgator is offline   Reply With Quote
Old 14th October 2018, 18:38   #53219  |  Link
Warner306
That's not true. A hardware decoder is a seperate part of the GPU. Hardware acceleration will actually improve performance (not in madVR, but in general) by freeing up the CPU without harming GPU performance.
Old 14th October 2018, 18:51   #53220  |  Link
Betroz
Is this for real?
Betroz's Avatar
For people who have a GTX 1080 card, what hardware decoder do you then recommend? CUVID or...?
My HTPC : i7 6900K @ 4.2 | nVidia GTX 1080Ti | TV : Samsung 75Q9FN QLED
Betroz is offline   Reply With Quote
