Old 25th June 2017, 18:51   #44201  |  Link
SamuelMaki
If you are running out of VRAM, try with minimum queues. Could easily check that with GPU-Z running same time as watching.
SamuelMaki is offline   Reply With Quote
Old 26th June 2017, 01:02   #44202  |  Link
amayra
Quality Checker
amayra's Avatar
exactly the same bugs
I love Doom9
amayra is offline   Reply With Quote
Old 26th June 2017, 09:22   #44203  |  Link
AngelGraves13
Originally Posted by iSeries View Post
Even running a torture test heat doesn't pass 70. I'll check advanced render steps a bit later, hopefully that will give more of a clue
Could be your GPU downclocking then...not sure.
AngelGraves13 is offline   Reply With Quote
Old 26th June 2017, 13:03   #44204  |  Link
takenori
Setting power config to Adaptive should be enough.
this works for me thanks.
i never know theres differences between adaptive and optimal performance.
takenori is offline   Reply With Quote
Old 26th June 2017, 14:44   #44205  |  Link
lunnar
Hey, I just found out this week end that to be able to use the HDR metadata passthru with MPC-HC, I have to use the 32bit version. I have always used the 64bit... this might have been tell before in this thread and I've misse it probably...
anyway since the switch, I have been able to test out both the Nvidia API as well as the Windows 10 API and both work pretty well. On one occasion the HDR flag stayed up after exiting the movie and I couln't find any way to reset it exept rebooting my PC. But overall , works nicely.
lunnar is offline   Reply With Quote
Old 26th June 2017, 19:16   #44206  |  Link
Damie
When playing a source video in DXVA2 copy-back mode with BT.2020 matrix & primaries and passthrough HDR, Mad-VR says "HDR 1000 nits, BT.2020 -> DCI-P3".
Should I select DCI or BT.2020 in my TV (X850C) menu settings? With BT.2020 enabled the colors look deeper without oversaturation.
Is there a setting in MadVR to disable the BT.2020 -> DCI-P3 conversion (DXVA2 native mode, perhaps?)
Thanks for any help!
Damie is offline   Reply With Quote
Old 26th June 2017, 20:37   #44207  |  Link
nevcairiel
This line only informs you of the actual used colorspace inside the stream. Its always contained in a BT.2020 container, however BT.2020 covers a huge range of colors which isn't fully used by anything so far (nor can TVs fully reproduce it). So HDR contains metadata that informs the player about the actually used colorspace - in this case thats DCI-P3, in a BT.2020 container.
So that line is just informationl.
You should select whatever you set in madVR under devices -> <device> -> calibration. Those settings have to match (if you're not calibrating manually, set it to display is already calibrated and select BT.2020 or DCI-P3 in the box below)
At this point in time, perhaps using DCI-P3 would be best, although BT.2020 would also work (but if you're not using 10-bit output, it may cause a bit of loss).
Old 26th June 2017, 20:45   #44208  |  Link
Zaoshi
Are my colors wrong?
Hey there,
I encountered this pack containing some test videos and some of them caught my interesting: https://drive.google.com/file/d/0B9F...p1eGVnTG8/edit
When I play "MP4-2c\Basic Settings\3-White Clipping.mp4" what I see on the screen matches what the video says: 235 and higher are completely white, while 230-234 are slightly gray (refer to the image), but shouldn't I see whole range up to 253?
I tried checking colors in Paint and 230 column is actually 249 white, while 234 column is 254 white. Why is this considered to be correct output when colors are incorrect?
Similar issue with "1-Black Clipping.mp4" file - dark colors are darker than the number says.
Zaoshi is offline   Reply With Quote
Old 26th June 2017, 20:48   #44209  |  Link
nevcairiel
On a properly calibrated screen and playback chain, you should not see values above 235 or below 16.
Note that when you take a screenshot of the video, it is already after various levels of processing, and the values don't match the actual values in the video.
Old 26th June 2017, 20:54   #44210  |  Link
Zaoshi
In that case my colors are displayed correctly, but why is that?
Shouldn't 235 appear as 235, not 255? If video is going to have colors in ranges 0-16 and 235-255 they'll just get thrown away.
If I use EVR and set LAV to output 16-235 then I can actually see the whole range and color values match the number (which implies video does have those colors, but as seen in the picture those colors just disappear). Shouldn't this be the correct way?
Old 26th June 2017, 21:30   #44211  |  Link
Damie
Thank you! So it's the same as "Mastering display color primaries " shown by Mediainfo.
As my TV shows 96% of DCI P3 uv gamut, and only 72% of BT.2020 uv gamut, and because the source is DCI P3, I'll be selecting the latter in the TV menu.
Selecting BT.2020 in TV menu would result in oversaturation, yes? But if my TV could reproduce 100% of BT.2020 gamut, there would be no oversaturation, right?
Old 26th June 2017, 21:31   #44212  |  Link
iSeries
are you running out of Vram? check the advanced rendersteps part and see if you get spikes in finalstep.
Yep, out of vram. 2gb not enough I guess
iSeries is offline   Reply With Quote
Old 26th June 2017, 22:45   #44213  |  Link
nevcairiel
These test videos are specifically designed to include data that should not usually be visible, so that you can actually detect problems with that - ie. if you do see it, you know that its wrong.
Old 26th June 2017, 23:06   #44214  |  Link
Asmodian
To expand on what nevcairiel said, the test video is flagged as limited range but contains full range information to expose incorrect playback chains.
madVR options explained
Old 27th June 2017, 01:16   #44215  |  Link
johnnylaiyee
johnnylaiyee's Avatar
By setting to 4 present queue ,my 1050 2gb can play a whole 1080p upscaling to 4k without any issue
Sent from my LG-H860 using Tapatalk
johnnylaiyee is offline   Reply With Quote
Old 27th June 2017, 02:01   #44216  |  Link
sauma144
Originally Posted by johnnylaiyee View Post
By setting to 4 present queue, my 1050 2gb can play a whole 1080p upscaling to 4k without any issue.
What upscaler do you use?
sauma144 is offline   Reply With Quote
Old 27th June 2017, 02:22   #44217  |  Link
iSeries
Upscaling 1080p to 4k is no problem (i often crop black bars and zoom to fill the screen, using ngu doubling for upscaling). 4k hdr downscaled to 1080p is what my card is struggling with.
Old 27th June 2017, 02:39   #44218  |  Link
johnnylaiyee
Luma ngu sharp high
Chroma superxbr 150
Old 27th June 2017, 13:25   #44219  |  Link
pankov
Hello fellow madVR users,
last week I got the chance to test my first 4K TV with HDR support (LG OLED65E6) and I was very impressed with the "punch" of the HDR picture and the OLED picture in general. I was using a few HDR demos and one of them had some external subtitles (.srt) with comments which I decided to try and I think I stumbled on an major downside of using external text subs with HDR videos with current subtitle renderers and/or madVR.
Here is the issue:
Since madVR is smart enough to turn on the HDR mode on the TV and get specular highlights in 1000+ nits (well ~500 nits on this OLED TV) while maintaining the rest of the picture at lower levels ... or even much lower in dark scenes ... the rendered subtitles (which by default are "white" - RGB 255,255,255) are blindingly bright and they have much greater area than a specular highlight and are almost hurting the eyes. This got me thinking if the way madVR and XySubFilter that I use are actually rendering the subtitles is correct. On one side XySubFilter doesn't know if the subs are rendered over an HDR or SDR video ... I think ... and the preference for font color it uses is always the same ... which makes me believe that it's madVR's job to lower the brightness of the color/white in some way (f.e. 255,255,255 = 100 nits as per SDR spec) but on the other side if there is some color/brightness information in the SRT file (I'm not 100% sure if it's possible but with other external subtitles formats it is AFAIK) how should madVR react?
So I'll be glad to hear your thoughts on the subject.
I don't have access to UHD Blu-Ray player and real movies so I'm wondering how these things designed in the real/official format.
Can you someone with access to such content share a few pictures with us? For example one picture from a dark scene with subs and a different one from a very bright scene again with subs on screen.
Z370M Pro4 | i3-8100 | 16GB RAM | 256GB SSD + 40TB NAS
NVIDIA GTX 1060 6GB (385.28) | LG OLED65B7V
Win 10 64bit 1803 + Zoom Player v14
pankov is offline   Reply With Quote
Old 27th June 2017, 23:47   #44220  |  Link
sauma144
I don't know if this can be useful for madVR.
But it seems it's possible to detect HDR support of any displays with Windows.
https://github.com/Microsoft/DirectX...12HDR.cpp#L904
Hope it's not only for latest Win10 release and/or D3D12.
