Old 29th September 2016, 00:23   #39601  |  Link
ryrynz
ryrynz's Avatar
Originally Posted by Ver Greeneyes View Post
Deblocking would be great, yeah.
It's surprising how blocky some frames of video can be even at 720 or 1080 resolution.
It's the lower quality videos that require the most help from madVR. Still a lot of lower quality content being watched out there and onboard GPU's are really starting to stretch their legs now.
Old 29th September 2016, 05:06   #39602  |  Link
CarlosCaco
I have some internet rips that are taged as variable framerate... what the purpose of this? How media player and madvr handle this? Why the ripper want to make a rip with a variable framerate...
Should I expect to see judder, glitches, frame drops on this type of file?
Desktop, i5 2500, 8GB, N570 GTX TF III PE/OC
Asus X555LF, i7-5500U, 6GB Ram, Nvidia 930m/HD 5500
Windows 8.1 Pro x64
CarlosCaco is offline   Reply With Quote
Old 29th September 2016, 05:19   #39603  |  Link
ryrynz
ryrynz's Avatar
I'd guess that depends on what your refresh rate is. If you have Smooth Motion enabled it shouldn't be an issue.
Old 29th September 2016, 06:30   #39604  |  Link
CarlosCaco
No... its on my 23.976 mode but the files have a minibus and a maximum framerate...
Why someone doe that?
Windows 8.1 Pro x64
Old 29th September 2016, 08:37   #39605  |  Link
because the source is VFR. that's the only correct treatment you can do to some sources.
there is a lot of content that has 23p scene and 29p scene put in 59i or 59p. the only solution is a VFR encode.
smoothmotion can handle VFR BTW.
Old 29th September 2016, 12:08   #39606  |  Link
ShiftyFella
Originally Posted by JarrettH View Post
Why isn't this activating for 60 fps?
if (srcWidth <= 800) "SD"
if (srcWidth >= 801) "HD"
if (fps = 60.000) "Live Stream"
Can someone simply fix this? Thanks
I've tried reordering it too (assuming it looks for 60 fps first)
Somehow it needs to not activate HD before looking at the fps
else if (srcWidth >= 801) and (fps = 60.000) "Live Stream"
else "HD"
This doesn't work either. Is something bugged?
srcfps option never worked for me, try using deintFPS >=50 instead as 1st rule, this will obviously screw settings for files that do require deinterlacing and are not live sports but most of my files that require it are, so no issue for me. you can always try switching profiles manually tho
ShiftyFella is offline   Reply With Quote
Old 29th September 2016, 20:09   #39607  |  Link
Warner306
deintFps works for me as a profile rule. The source doesn't need to be deinterlaced.
Old 30th September 2016, 02:43   #39608  |  Link
Asmodian
else "HD"
I would suggest:
else if (deintFPS > 59) "Live Stream"
else "HD"
The "else if" will only be evaluated if the first statement is false so you don't need to check the resolution again. Never use an = sign for fps, the real value has higher precision than 60.000 and is usually something like 59.94005994005994, your 60.000 was probably something like 60.000001 fps.
madVR options explained
Old 30th September 2016, 08:12   #39609  |  Link
AngelGraves13
Is there a way to tell madvr to use double expanded range for a specific file every time? I've heard you can add something into the filename, but what about a header in the mkv or a tag?
AngelGraves13 is offline   Reply With Quote
Old 30th September 2016, 09:20   #39610  |  Link
that's the file name thing: levels: levels=PC|TV|fullrange|limited|doubleExp|tripleExp *range= is synonymous
http://forum.doom9.org/showthread.php?t=171787
Old 30th September 2016, 13:10   #39611  |  Link
ashlar42
Originally Posted by pose View Post
This guide is terrible honestly. The worst guide ive seen in a while. Ive spend a lot of time and still couldn't make it work.
I don't want to pick a fight or anything but still... you say it's terrible and yet you haven't posted asking for help. I (and hannes69) have invested a lot of time to write it, hoping for it to be clear enough. If it isn't I've openly stated that I'm all for changing it for the better (and I have done so upon suggestions received).
Hannes69 has worked on a program that will simplify some of the calculations needed and streamlines the process. We are currently testing.
But really, if anyone finds the guide too complicated or is in need of help, please post there. I will gladly help to the best of my ability.
Thank you.
Edit: also, for ryrynz, the fact that you have a working starting point doesn't mean you'll have perfect playback. Check the stats in madVR. The point of the guide was not to have an "okay" setting, the point of the guide is having a perfect setting. One that moves the drops/repeats outside the normal usage range (once you reach... 5 or 6 hours, chances are you'll never experience one, considering the material we watch usually).
Old 30th September 2016, 14:49   #39612  |  Link
CarlosCaco
Thank you.
For me it's only guide that have real important content... i really like it and I glad you for the hard work...
if people be persistent certanly the guide will bring good results
Windows 8.1 Pro x64
Old 30th September 2016, 18:25   #39613  |  Link
Asmodian
You can add it to the directory name too, if you don't want to have to edit a lot of file names.
No header or tag for mkv, it would be an odd custom one and double expanded isn't something that should be part of normal video spec, imo.
Old 30th September 2016, 18:43   #39614  |  Link
JarrettH
Thanks ShiftyFella and Asmodian
Old 30th September 2016, 20:55   #39615  |  Link
AngelGraves13
Yes I know but Texas Chainsaw Massacre remake has incorrect mastering of black levels.
Old 30th September 2016, 23:36   #39616  |  Link
Stereodude
Originally Posted by iSeries View Post
Is it possible to add profiles for 3dluts? Or maybe a keyboard shortcut to switch them? My plasma calibrates completely differently at different refresh rates so this would be very useful.
It already can be done. I have a different 3DLUT for 24Hz when my Plasma uses a 96Hz refresh than I do when it's refreshing at 60Hz. You can create a profile rule based on refresh rate and change between them automatically.
Stereodude is offline   Reply With Quote
Old 1st October 2016, 00:50   #39617  |  Link
Uoppi
I don't know but it seems I am the only person on the planet who never got this to work, for whatever reason (in Kodi + DSPlayer).
The tag for double expansion is doing absolutely nothing at all (I posted about it here a few months back) but fortunately the black and white level tags DO work, so that I am able to achieve a similar result. So all is well but it is an odd thing for sure.
Uoppi is offline   Reply With Quote
Old 1st October 2016, 06:29   #39618  |  Link
robl45
Weird problem tonight maybe due to win10 update. Half the time I would play movie it would show queue for render and present at 1-2 instead of 11-12 or whatever. It was also randomly picking 24 Hz or 23.976 when it always picked 23.976 before and my queues were always near full. Anyone else have this or have any ideas?
robl45 is offline   Reply With Quote
Old 1st October 2016, 06:59   #39619  |  Link
ryrynz
ryrynz's Avatar
First thing I'd do is reinstall the graphics driver.
Old 1st October 2016, 13:06   #39620  |  Link
Kotik
Thank you.
I did follow the guide and i am very happy with the results, i don't find the guide complicated. People tend to confuse the guide with the procedure itself. The guide is fine, people have to understand that the nature of the procedure is complicated, yes.... sometimes in our lives we have to press more than one button to get what we want.
Thanx for the guide and sorry for the off topic.
Kotik is offline   Reply With Quote
