29th March 2009, 15:01 | #8641 | Link | |
Aging Video Hobbyist
Many thanks madshi for the update--your attention to detail is VERY MUCH APPRECIATED! |
29th March 2009, 19:33 | #8643 | Link |
Re : de-emphasis
[/QUOTE]
What would that switch do exactly? [/QUOTE] Some rare CDs have pre-emphasis. Extracting them in secure mode with EAC leaves the file emphasised. eac3to could have a switch to get proper gain figure at high frequencies when processing the wavs. WaveEmph110 does the job, but a switch in eac3to could be a nice feature, although rare. Regards, narshorn |
29th March 2009, 21:06 | #8646 | Link | ||
Requested Log file
eac3to v3.14 command line: "c:\VID2EVA\tools\eac3to\eac3to.exe" "c:\VID2EVA\Videos\Vid2eva_0.vob"+"c:\VID2EVA\Videos\Vid2eva_1.vob"+"c:\VID2EVA\Videos\Vid2eva_2.vob"+"c:\VID2EVA\Videos\Vid2eva_3.vob"+"c:\VID2EVA\Videos\Vid2eva_4.vob"+"c:\VID2EVA\Videos\Vid2eva_5.vob"+"c:\VID2EVA\Videos\Vid2eva_6.vob"+"c:\VID2EVA\Videos\Vid2eva_7.vob"+"c:\VID2EVA\Videos\Vid2eva_8.vob"+"c:\VID2EVA\Videos\Vid2eva_9.vob"+"c:\VID2EVA\Videos\Vid2eva_10.vob"+"c:\VID2EVA\Videos\Vid2eva_11.vob"+"c:\VID2EVA\Videos\Vid2eva_12.vob"+"c:\VID2EVA\Videos\Vid2eva_13.vob"+"c:\VID2EVA\Videos\Vid2eva_14.vob"+"c:\VID2EVA\Videos\Vid2eva_15.vob"+"c:\VID2EVA\Videos\Vid2eva_16.vob"+"c:\VID2EVA\Videos\Vid2eva_17.vob" "c:\VID2EVA\Videos\Vid2eva.mkv" -seekToIFrames -lowPriority ------------------------------------------------------------------------------ VOB, 1 video track, 3 audio tracks, 3 subtitle tracks, 2:00:55 1: Joined VOB file 2: MPEG2, 480p24 /1.001 (4:3) with pulldown flags 3: AC3 Surround, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB, 24ms 4: AC3, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB, 24ms 5: AC3 Surround, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB, 24ms 6: Subtitle (DVD) 7: Subtitle (SRT) 8: Subtitle (DVD) [v02] Extracting video track number 2... [a03] Extracting audio track number 3... [a04] Extracting audio track number 4... [a05] Extracting audio track number 5... [s07] Extracting subtitle track number 7... [a03] Removing AC3 dialog normalization... [a04] Removing AC3 dialog normalization... [a05] Removing AC3 dialog normalization... [v02] Muxing video to Matroska... [a03] Applying (E-)AC3 delay... [a04] Applying (E-)AC3 delay... [a05] Applying (E-)AC3 delay... [a03] A remaining delay of -8ms could not be fixed. [a04] A remaining delay of -8ms could not be fixed. [a05] A remaining delay of -8ms could not be fixed. [a04] Creating file "c:\VID2EVA\Videos\Vid2eva - 4 - AC3, 5.1 channels, 448kbps, 48khz.ac3"... [a03] Creating file "c:\VID2EVA\Videos\Vid2eva - 3 - AC3 Surround, 2.0 channels, 192kbps, 48khz.ac3"... [a05] Creating file "c:\VID2EVA\Videos\Vid2eva - 5 - AC3 Surround, 2.0 channels, 192kbps, 48khz.ac3"... [s08] Extracting subtitle track number 8... [s06] Extracting subtitle track number 6... [s06] Creating file "c:\VID2EVA\Videos\Vid2eva - 6 - Subtitle (DVD).sup"... [s08] Creating file "c:\VID2EVA\Videos\Vid2eva - 8 - Subtitle (DVD).sup"... [v02] Video has a gap of 7 frames at playtime 1:57:07. <WARNING> [v02] The MKV file was created without making use of the gap/overlap information. <WARNING> [v02] Please check whether audio is in sync. If it is in sync everything is fine. <WARNING> [v02] Otherwise ask eac3to to repeat the muxing. It will then automatically make <WARNING> [v02] use of the detailed gap/overlap information. <WARNING> [s07] Creating file "c:\VID2EVA\Videos\Vid2eva - 7 - Subtitle (SRT).srt"... Added fps value to MKV header. Video track 2 contains 174101 frames. Subtitle track 6 contains 1857 captions. Subtitle track 8 contains 1421 captions. eac3to processing took 10 minutes, 11 seconds. Done. Code:
eac3to v3.14 command line: "c:\VID2EVA\tools\eac3to\eac3to.exe" "c:\VID2EVA\Videos\Vid2eva_0.vob"+"c:\VID2EVA\Videos\Vid2eva_1.vob"+"c:\VID2EVA\Videos\Vid2eva_2.vob"+"c:\VID2EVA\Videos\Vid2eva_3.vob"+"c:\VID2EVA\Videos\Vid2eva_4.vob"+"c:\VID2EVA\Videos\Vid2eva_5.vob"+"c:\VID2EVA\Videos\Vid2eva_6.vob"+"c:\VID2EVA\Videos\Vid2eva_7.vob"+"c:\VID2EVA\Videos\Vid2eva_8.vob"+"c:\VID2EVA\Videos\Vid2eva_9.vob"+"c:\VID2EVA\Videos\Vid2eva_10.vob"+"c:\VID2EVA\Videos\Vid2eva_11.vob"+"c:\VID2EVA\Videos\Vid2eva_12.vob"+"c:\VID2EVA\Videos\Vid2eva_13.vob"+"c:\VID2EVA\Videos\Vid2eva_14.vob"+"c:\VID2EVA\Videos\Vid2eva_15.vob"+"c:\VID2EVA\Videos\Vid2eva_16.vob"+"c:\VID2EVA\Videos\Vid2eva_17.vob" "c:\VID2EVA\Videos\Vid2eva.mkv" -seekToIFrames -lowPriority ------------------------------------------------------------------------------ VOB, 1 video track, 3 audio tracks, 3 subtitle tracks, 2:00:55 1: Joined VOB file 2: MPEG2, 480p24 /1.001 (4:3) with pulldown flags 3: AC3 Surround, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB, 24ms 4: AC3, 5.1 channels, 448kbps, 48khz, dialnorm: -27dB, 24ms 5: AC3 Surround, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB, 24ms 6: Subtitle (DVD) 7: Subtitle (SRT) 8: Subtitle (DVD) [v02] Video gap description file detected, will be used for muxing... [v02] Extracting video track number 2... [a03] Extracting audio track number 3... [a04] Extracting audio track number 4... [a05] Extracting audio track number 5... [s07] Extracting subtitle track number 7... [a03] Removing AC3 dialog normalization... [v02] Muxing video to Matroska... [a04] Removing AC3 dialog normalization... [a05] Removing AC3 dialog normalization... [a03] Applying (E-)AC3 delay... [a04] Applying (E-)AC3 delay... [a05] Applying (E-)AC3 delay... [a03] A remaining delay of -8ms could not be fixed. [a04] A remaining delay of -8ms could not be fixed. [a05] A remaining delay of -8ms could not be fixed. [a04] Creating file "c:\VID2EVA\Videos\Vid2eva - 4 - AC3, 5.1 channels, 448kbps, 48khz.ac3"... [a03] Creating file "c:\VID2EVA\Videos\Vid2eva - 3 - AC3 Surround, 2.0 channels, 192kbps, 48khz.ac3"... [a05] Creating file "c:\VID2EVA\Videos\Vid2eva - 5 - AC3 Surround, 2.0 channels, 192kbps, 48khz.ac3"... [s08] Extracting subtitle track number 8... [s06] Extracting subtitle track number 6... [s06] Creating file "c:\VID2EVA\Videos\Vid2eva - 6 - Subtitle (DVD).sup"... [s08] Creating file "c:\VID2EVA\Videos\Vid2eva - 8 - Subtitle (DVD).sup"... [s07] Creating file "c:\VID2EVA\Videos\Vid2eva - 7 - Subtitle (SRT).srt"... Added fps value to MKV header. Video track 2 contains 174101 frames. Subtitle track 6 contains 1857 captions. Subtitle track 8 contains 1421 captions. eac3to processing took 11 minutes, 24 seconds. Done. Code:
03/26/2009 04:42 PM 174,273,024 Vid2eva - 3 - AC3 Surround, 2.0 channels, 192kbps, 48khz.ac3 03/26/2009 04:42 PM 406,637,056 Vid2eva - 4 - AC3, 5.1 channels, 448kbps, 48khz.ac3 03/26/2009 04:42 PM 174,273,024 Vid2eva - 5 - AC3 Surround, 2.0 channels, 192kbps, 48khz.ac3 03/26/2009 04:30 PM 3,126,648 Vid2eva - 6 - Subtitle (DVD), 1857 captions.sup 03/26/2009 04:42 PM 3,126,648 Vid2eva - 6 - Subtitle (DVD).sup 03/26/2009 04:42 PM 204,990 Vid2eva - 7 - Subtitle (SRT).srt 03/26/2009 04:30 PM 2,338,892 Vid2eva - 8 - Subtitle (DVD), 1421 captions.sup 03/26/2009 04:42 PM 2,338,892 Vid2eva - 8 - Subtitle (DVD).sup 03/26/2009 04:42 PM 2,768 Vid2eva - Log.txt 03/26/2009 04:42 PM 5,461,622,129 Vid2eva.mkv 03/26/2009 04:30 PM 16 Vid2eva.mkv.gaps |
29th March 2009, 21:39 | #8647 | Link |
Help! Stumped.
Welcome home madshi!
I'm trying to serve a live 16-bit 44.1 FLAC stream via Tribler, but so far, so stumped. Tribler uses Python to convert live input (FLAC in my case) to .mpegts, but thus far, none of my .mpegts output is readable. There is one thing I should mention about the FLAC I use as input: VLC can play it as a live stream (from another instance of VLC) but foobar2000 can only play it once it has been saved as a finished file. Any tips on how to proceed? madshi, especially would appreciate your weighing in here. |
30th March 2009, 16:13 | #8648 | Link | |
So I conlude that if eac3to had not "corrected" the "delay", it would still be in sync. I was going to try Ctrl+C, but I thought I would ask first because I don't like it. Maybe I'm too late and the files are already changed and might not work any longer. I assume it would be easy for you to add an undocumented switch "-no2pass" or similar. If it means a lot of trouble for you, please forget about it. |
30th March 2009, 21:57 | #8649 | Link |
I'm confused about the handling of Dolby Digital, Dolby Digital Plus (aka E-AC3), and TrueHD. If I encounter a track like this:
3: TrueHD/AC3, English, 5.1 channels, 48khz (embedded: AC3, 5.1 channels, 640kbps, 48khz, dialnorm: -30dB) and I don't want the TrueHD track, do I convert to "ordinary AC3" by using the -core option, or -640 option, or neither e.g. "eac3to 3: audio.ac3" ? |
30th March 2009, 23:45 | #8651 | Link | |
For 5.1: L, R, C, LFE, Ls, Rs For 6.1: L, R, C, LFE, Ls, Rs, Cs For 7.1: L, R, C, LFE, Lss, Rss, Lsr, Rsr All capitals are acceptable. These are the extensions that are printed on the labels of the tapes delivered from the studios to be encoded for Blu-Ray. These extensions are also used by the two professional audio encoding suites: DTS-HD Master Audio Suite Encoder and the Dolby Media Encoder. You can see both of these encoders expecting these extensions here: Dolby: http://www.dolby.com/professional/pr...ng/DMP_02.html (Click on the image to make it bigger) DTS: http://www.dts.com/Pro-Audio_Softwar...D_Encoder.aspx (Again, click on the image...) These two pieces of software will auto-fill the WAV files when you select one if the file names are correct. That's the only reason I mentioned it... People keep reversing the letters, or in some cases, use completely different letters, and it can get confusing sometimes... Again, it's not really a big deal (there's probably more imortant things you have to worry about)... It's not like it's hard to rename the files. I was just making an observation... |
31st March 2009, 07:16 | #8652 | Link |
User of free A/V tools
Hello madshi,
any chance you could put the most recent version of libFLAC.dll in your package at next release? Just for the sake of having up-to-date libraries included with eac3to. |
31st March 2009, 09:01 | #8653 | Link | |
Front Left - FL Front Right - FR Front Center - FC Low Frequency – LF Back Left - BL Back Right - BR Front Left of Center - FLC Front Right of Center - FRC Back Center - BC Side Left - SL Side Right - SR ...
31st March 2009, 17:49 | #8654 | Link |
Joined VOBs from DVD?
I've been pulling some of my older DVDs to disk for storage on my server. Being a user of EAC3TO for HD-DVD and BD, I was trying to stick with a similar process. Does EAC3TO do "joined VOB" correctly?
command line: eac3to.exe VTS_01_1.VOB+VTS_01_2.VOB+VTS_01_3.VOB+VTS_01_4.VOB+VTS_01_5.VOB+VTS_01_6.VOB 2: movie.m2v 3: movie.ac3 Am I doing something wrong or is this just not the correct way to use the tool? |
31st March 2009, 19:35 | #8655 | Link | |
The Questionable Usefulness of Message Boards
31st March 2009, 19:40 | #8656 | Link | |
Use DVD Decrypter. Last edited by Jeff Flowerday; 31st March 2009 at 19:42. |
1st April 2009, 03:25 | #8657 | Link |
I just ripped my copy of Iron Man Blu-Ray using eac3to and have two questions.
1. It appears that MKmerge does not support muxing of TrueHD audio tracks (at least the version I'm using (v 2.53) doesn't. How can I mux a TreuHD audio track into mkv? Is this possible? My audio file has the extension *.thd. 2. For playback i use Zoom Player which as you know is highly configurable, allowing me to select directshow filters for play back. Howver, I can't seem to get the Iron Man TrueHD audio track to play. In graphedit I tried using Nero File source (Async) > Nero Splitter > Nero Audio Decoder 2 > Audio Renderer. But nothing connects (yes, I renamed graphedit to "Recode"). Any suggestions on a working graph for TrueHD playback?? Thanks, The_Keymaker |
1st April 2009, 04:09 | #8658 | Link | |
3 eyed CRT supporter
You could convert the TrueHD track losslessly to FLAC - that's what most of use do. Flac is easy to decode, thanks to Madshi writing the Madflac decoder |
1st April 2009, 05:18 | #8659 | Link |
Yes, definitely use DVD Decrypter and pay attention you choose only one PGC to decrypt in IFO mode. Select None file splitting as to finish with only one (rather huge) VOB file instead of many smaller ones. eac3to has (probably as many other tools) problems with multiangle VOB stuff and such. I recently used eac3to with 2 joined VOBs ripped via IFO mode (one PGC only) successfully - The Lion King 2 Special Edition.
1st April 2009, 05:31 | #8660 | Link | |
If I was in a bad mood I'd say your post is nothing but violating our forum rules, especially point 12. My advice to you is find Tribler discussion forum and try to ask for solution there. |
eac3to |
