Old 7th April 2016, 16:59   #24001  |  Link
kufo
kufo's Avatar
Originally Posted by kufo View Post
This seems to be solved in the redfox forum. To get a working copy youŽll ned the original disc or an untouched mounatable image.
Lok here for details: https://forum.redfox.bz/threads/mockingjay-2.68608/
Sorry for double post After first post a server error was shown.
kufo is offline   Reply With Quote
Old 7th April 2016, 17:32   #24002  |  Link
jdobbs
Fixed it. I got one of those earlier today also.
Website: www.jdobbs.net
Old 8th April 2016, 00:45   #24003  |  Link
wakko709
[04/05/16] BD Rebuilder v0.50.14
[11:57:33] Source: PACIFIC_RIM
- Input BD size: 35.30 GB
- Approximate total content: [02:27:19.830]
- Target BD size: 22.95 GB
- Windows Version: 6.2 [9200]
- Auto Quality: Good (Very Fast), ABR
- Decoding/Frame serving: X264/LAVF
- Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640
[11:57:42] PHASE ONE, Encoding
- [11:57:42] Processing: VID_00001 (1 of 7)
- [11:57:42] Extracting A/V streams [VID_00001]
- Error in attempt to extract audio/subs.
wakko709 is offline   Reply With Quote
Old 8th April 2016, 00:46   #24004  |  Link
wakko709
Old 8th April 2016, 00:52   #24005  |  Link
wakko709
and theres another issue with mokeingjay2 won't work
Old 8th April 2016, 00:53   #24006  |  Link
Ch3vr0n
Then post the encode log for that one, no log no fix.
Verstuurd vanaf mijn Nexus 7 met Tapatalk
Ch3vr0n is offline   Reply With Quote
Old 8th April 2016, 01:15   #24007  |  Link
jdobbs
Uninstall and reinstall BD-RB, AVISYNTH, and LAV filters (or FFDSHOW) and see if that fixes it.
Old 8th April 2016, 03:35   #24008  |  Link
Lathe
Lathe's Avatar
Originally Posted by varekai View Post
I was hoping for something like:
1. Create the mentioned script setting, save as (***.avs ?)
2. Add the ***.avs script in BDRB
3. Add the Blu-ray title
4. Do the necessary output settings in BDRB
5. Hit "Backup"
I'm a very much GUI person and not very good at command line...
Oh well, lots to learn. No easy way?
Well, what I do is just simply add specific 2nd pass 'tweaks' that I want BDRB to do. I don't myself create an entire command line for the encode.
I've found that BDRB does a fine job on encoding and adds all the necessary parameters for most stuff.
For example, here is what I usually add if I am doing a pretty heavily compressed Blu-ray (in other words, say if you are compressing from 35 Gigs to 23 to fit on a single layer Blu-ray):
TWEAK_PASS_TWO=--ref 4 --deblock -2:-2 --psy-rd 1.00:0.20 --me umh --subme 8 --trellis 2 --direct auto --qcomp 0.50
Now, most here will tell you that this probably isn't necessary, and they are probably right but, I just like to tweak the deblocking, Psychovisual / Trellis, and make sure the 'me' & 'subme' are a bit higher than BDRB normally sets them for 'High - Default' (the super slow setting IS indeed overkill though and sets the settings TOO high I feel) and alter the qcomp a tad (this was suggested by Selur who designed HYBRID - it basically takes a few more bits from the high motion scenes and assigns them to the more static scenes, no big deal...)
I use these tweaks if I feel that there is not going to be that much compression (like just 2 or 3 Gigs):
TWEAK_PASS_TWO=--deblock -2:-2 --qcomp 0.50
Just to make the picture a tad sharper and the 'moving bits around thing'
If you want to experiment where it's pretty easy, I would suggest adding tweaks to BDRB and let it do most of the work
I am definitely NOT an expert, but I just kind of fiddle around a little bit with this kind of stuff... I only mention these that I use because you said that you wanted to experiment around a little. Hope that helps somewhat.
Lathe is offline   Reply With Quote
Old 8th April 2016, 08:18   #24009  |  Link
Sharc
@Lathe
I am not sure whether it's a terribly good idea to change --deblock and --direct between passes. They should better be the same for pass1 and pass2, as the speed gain for pass1 is minimal with the lower settings. The other parameters are less critical and can be changed for pass2 (I am not sure about --qcomp though).
Anyway, the discussion has nothing to to with a BD-RB bug report.
Edit:
About changing --direct between passes, see here:
http://forum.doom9.org/showpost.php?...1&postcount=30
So in best case, it has no effect at all.
Or the discussion here:
http://forum.doom9.org/showthread.php?t=135533
Old 8th April 2016, 08:57   #24010  |  Link
varekai
varekai's Avatar
@Lathe
@Sharc
Thanks guys, appreciate the input, will try to learn more.
Now back on topic... but I never seems to find any bugs...
varekai is offline   Reply With Quote
Old 8th April 2016, 12:54   #24011  |  Link
Weirdo
Hello, I interrupted a backup process about half-way, but seems BD-RB cannot resume this one, I get the "working path is not empty - delete all old files?" prompt. Haven't made any changes or used BD-RB in-between. Any suggestions on how I could resume this? Thank you.
Log in Working folder:
[04-06-16] BD Rebuilder v0.50.14
[22:50:47] Source:  MY_SOURCE
  - Input BD size: 28.30 GB
  - Approximate total content: [05:17:45.337]
  - Target BD size: 7.84 GB
  - Resize: 1080p to 720p enabled
  - Auto Quality: High Quality (Default), Two Pass
  - Decoding/Frame serving: DirectShow
  - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640
[22:50:47] PHASE ONE, Encoding
 - [22:50:47] Processing: VID_00231 (1 of 22)
 - [22:50:47] Extracting A/V streams [VID_00231]
 - [22:50:57] Reencoding video [VID_00231]
   - Rate/Length: 23.976fps, 480 frames
   - Convert: 1280x720, 23.976fps, 480 frames
   - Bitrate: 8,536 Kbs
 - [22:50:57] Reencoding: VID_00231, Pass 1 of 2
 - [22:51:11] Reencoding: VID_00231, Pass 2 of 2
 - [22:51:22] Video Encode complete
 - [22:51:22] Processing audio tracks
 - [22:51:22] Multiplexing M2TS
 - [22:51:26] Blanking: VID_00274 (2 of 22)
 - [22:51:26] Processing: VID_00295 (3 of 22)
 - [22:51:26] Extracting A/V streams [VID_00295]
 - [22:52:13] Reencoding video [VID_00295]
   - Rate/Length: 23.976fps, 6,902 frames
   - Convert: 1280x720, 23.976fps, 6,902 frames
   - Bitrate: 8,468 Kbs
 - [22:52:13] Reencoding: VID_00295, Pass 1 of 2
 - [22:54:29] Reencoding: VID_00295, Pass 2 of 2
 - [23:01:13] Video Encode complete
 - [23:01:13] Processing audio tracks
 - [23:01:13] Multiplexing M2TS
 - [23:01:24] Processing: VID_00304 (4 of 22)
 - [23:01:24] Extracting A/V streams [VID_00304]
 - [23:02:20] Reencoding video [VID_00304]
   - Rate/Length: 23.976fps, 7,191 frames
   - Convert: 1280x720, 23.976fps, 7,191 frames
   - Bitrate: 8,461 Kbs
 - [23:02:20] Reencoding: VID_00304, Pass 1 of 2
 - [23:04:51] Reencoding: VID_00304, Pass 2 of 2
 - [23:11:16] Video Encode complete
 - [23:11:16] Processing audio tracks
 - [23:11:16] Multiplexing M2TS
 - [23:11:25] Processing: VID_00305 (5 of 22)
 - [23:11:25] Extracting A/V streams [VID_00305]
 - [23:11:46] Reencoding video [VID_00305]
   - Rate/Length: 23.976fps, 5,814 frames
   - Convert: 1280x720, 23.976fps, 5,814 frames
   - Bitrate: 4,172 Kbs
 - [23:11:46] Reencoding: VID_00305, Pass 1 of 2
 - [23:14:01] Reencoding: VID_00305, Pass 2 of 2
 - [23:18:36] Video Encode complete
 - [23:18:36] Processing audio tracks
 - [23:18:36] Multiplexing M2TS
 - [23:18:42] Processing: VID_00306 (6 of 22)
 - [23:18:42] Extracting A/V streams [VID_00306]
 - [23:18:54] Reencoding video [VID_00306]
   - Rate/Length: 29.970fps, 3,442 frames
   - Convert: 1280x720, 59.940fps, 6,884 frames
   - Bitrate: 4,170 Kbs
 - [23:18:54] Reencoding: VID_00306, Pass 1 of 2
 - [23:21:19] Reencoding: VID_00306, Pass 2 of 2
 - [23:25:18] Video Encode complete
 - [23:25:18] Processing audio tracks
 - [23:25:18] Multiplexing M2TS
 - [23:25:23] Processing: VID_00307 (7 of 22)
 - [23:25:23] Extracting A/V streams [VID_00307]
 - [23:25:41] Reencoding video [VID_00307]
   - Rate/Length: 23.976fps, 5,423 frames
   - Convert: 1280x720, 23.976fps, 5,423 frames
 - [23:25:41] Reencoding: VID_00307, Pass 1 of 2
 - [23:27:44] Reencoding: VID_00307, Pass 2 of 2
 - [23:31:43] Video Encode complete
 - [23:31:43] Processing audio tracks
 - [23:31:43] Multiplexing M2TS
 - [23:31:48] Processing: VID_00308 (8 of 22)
 - [23:31:48] Extracting A/V streams [VID_00308]
 - [23:31:57] Reencoding video [VID_00308]
   - Rate/Length: 29.970fps, 2,239 frames
   - Convert: 1280x720, 59.940fps, 4,478 frames
 - [23:31:57] Reencoding: VID_00308, Pass 1 of 2
 - [23:33:23] Reencoding: VID_00308, Pass 2 of 2
 - [23:35:41] Video Encode complete
 - [23:35:41] Processing audio tracks
 - [23:35:41] Multiplexing M2TS
 - [23:35:45] Processing: VID_00309 (9 of 22)
 - [23:35:45] Extracting A/V streams [VID_00309]
 - [23:38:20] Reencoding video [VID_00309]
   - Rate/Length: 23.976fps, 48,634 frames
   - Convert: 1280x720, 23.976fps, 48,634 frames
   - Bitrate: 4,171 Kbs
 - [23:38:20] Reencoding: VID_00309, Pass 1 of 2
 - [23:56:32] Reencoding: VID_00309, Pass 2 of 2
 - [00:24:31] Video Encode complete
 - [00:24:31] Processing audio tracks
 - [00:24:31] Multiplexing M2TS
 - [00:24:51] Processing: VID_00310 (10 of 22)
 - [00:24:51] Extracting A/V streams [VID_00310]
 - [00:25:15] Reencoding video [VID_00310]
   - Rate/Length: 29.970fps, 9,330 frames
   - Convert: 1280x720, 59.940fps, 18,660 frames
   - Bitrate: 4,169 Kbs
 - [00:25:15] Reencoding: VID_00310, Pass 1 of 2
 - [00:29:57] Reencoding: VID_00310, Pass 2 of 2
 - [00:36:42] Video Encode complete
 - [00:36:42] Processing audio tracks
 - [00:36:42] Multiplexing M2TS
 - [00:36:48] Processing: VID_00311 (11 of 22)
 - [00:36:48] Extracting A/V streams [VID_00311]
 - [00:37:10] Reencoding video [VID_00311]
   - Rate/Length: 23.976fps, 7,477 frames
   - Convert: 1280x720, 23.976fps, 7,477 frames
 - [00:37:10] Reencoding: VID_00311, Pass 1 of 2
 - [00:39:30] Reencoding: VID_00311, Pass 2 of 2
 - [00:43:56] Video Encode complete
 - [00:43:56] Processing audio tracks
 - [00:43:56] Multiplexing M2TS
 - [00:44:02] Processing: VID_00312 (12 of 22)
 - [00:44:02] Extracting A/V streams [VID_00312]
 - [00:44:21] Reencoding video [VID_00312]
   - Rate/Length: 23.976fps, 5,898 frames
   - Convert: 1280x720, 23.976fps, 5,898 frames
 - [00:44:22] Reencoding: VID_00312, Pass 1 of 2
 - [00:46:14] Reencoding: VID_00312, Pass 2 of 2
 - [00:49:40] Video Encode complete
 - [00:49:40] Processing audio tracks
 - [00:49:40] Multiplexing M2TS
 - [00:49:46] Processing: VID_00313 (13 of 22)
 - [00:49:46] Extracting A/V streams [VID_00313]
 - [00:49:57] Reencoding video [VID_00313]
   - Rate/Length: 29.970fps, 3,169 frames
   - Convert: 1280x720, 59.940fps, 6,338 frames
 - [00:49:57] Reencoding: VID_00313, Pass 1 of 2
 - [00:51:34] Reencoding: VID_00313, Pass 2 of 2
 - [00:53:53] Video Encode complete
 - [00:53:53] Processing audio tracks
 - [00:53:53] Multiplexing M2TS
 - [00:53:57] Processing: VID_00314 (14 of 22)
 - [00:53:57] Extracting A/V streams [VID_00314]
 - [00:54:06] Reencoding video [VID_00314]
   - Rate/Length: 23.976fps, 1,531 frames
   - Convert: 1280x720, 23.976fps, 1,531 frames
 - [00:54:06] Reencoding: VID_00314, Pass 1 of 2
 - [00:54:37] Reencoding: VID_00314, Pass 2 of 2
 - [00:55:22] Video Encode complete
 - [00:55:22] Processing audio tracks
 - [00:55:22] Multiplexing M2TS
 - [00:55:27] Processing: VID_00315 (15 of 22)
 - [00:55:27] Extracting A/V streams [VID_00315]
 - [00:55:40] Reencoding video [VID_00315]
   - Rate/Length: 29.970fps, 4,096 frames
   - Convert: 1280x720, 59.940fps, 8,192 frames
 - [00:55:40] Reencoding: VID_00315, Pass 1 of 2
 - [00:57:46] Reencoding: VID_00315, Pass 2 of 2
 - [01:00:46] Video Encode complete
 - [01:00:46] Processing audio tracks
 - [01:00:46] Multiplexing M2TS
 - [01:00:51] Processing: VID_00316 (16 of 22)
 - [01:00:51] Extracting A/V streams [VID_00316]
 - [01:02:14] Reencoding video [VID_00316]
   - Rate/Length: 29.970fps, 30,649 frames
   - Convert: 1280x720, 59.940fps, 61,298 frames
 - [01:02:14] Reencoding: VID_00316, Pass 1 of 2
 - [01:17:49] Reencoding: VID_00316, Pass 2 of 2
 - [01:45:04] Video Encode complete
 - [01:45:04] Processing audio tracks
 - [01:45:04] Multiplexing M2TS
 - [01:45:15] Processing: VID_00317 (17 of 22)
 - [01:45:15] Extracting A/V streams [VID_00317]
 - [01:45:23] Reencoding video [VID_00317]
   - Rate/Length: 29.970fps, 2,521 frames
   - Convert: 1280x720, 59.940fps, 5,042 frames
   - Bitrate: 4,173 Kbs
 - [01:45:23] Reencoding: VID_00317, Pass 1 of 2
 - [01:46:59] Reencoding: VID_00317, Pass 2 of 2
 - [01:49:25] Video Encode complete
 - [01:49:25] Processing audio tracks
 - [01:49:25] Multiplexing M2TS
 - [01:49:29] Processing: VID_00318 (18 of 22)
 - [01:49:29] Extracting A/V streams [VID_00318]
 - [01:49:59] Reencoding video [VID_00318]
   - Rate/Length: 23.976fps, 9,776 frames
   - Convert: 1280x720, 23.976fps, 9,776 frames
 - [01:49:59] Reencoding: VID_00318, Pass 1 of 2
 - [01:53:38] Reencoding: VID_00318, Pass 2 of 2
 - [02:01:31] Video Encode complete
 - [02:01:31] Processing audio tracks
 - [02:01:31] Multiplexing M2TS
 - [02:01:38] Processing: VID_00319 (19 of 22)
 - [02:01:38] Extracting A/V streams [VID_00319]
 - [02:02:58] Reencoding video [VID_00319]
   - Rate/Length: 29.970fps, 29,478 frames
   - Convert: 1280x720, 59.940fps, 58,956 frames
 - [02:02:58] Reencoding: VID_00319, Pass 1 of 2
 - [02:19:04] Reencoding: VID_00319, Pass 2 of 2
 - [02:44:45] Video Encode complete
 - [02:44:45] Processing audio tracks
 - [02:44:45] Multiplexing M2TS
 - [02:44:57] Processing: VID_00320 (20 of 22)
 - [02:44:57] Extracting A/V streams [VID_00320]
 - [02:52:27] Reencoding video [VID_00320]
   - Rate/Length: 29.970fps, 153,101 frames
   - Convert: 1280x720, 59.940fps, 306,202 frames
 - [02:52:27] Reencoding: VID_00320, Pass 1 of 2
[02:54:57]PHASE ONE aborted by user request
[04-08-16] BD Rebuilder v0.50.14
[14:35:59] Source:  MY_SOURCE
  - Input BD size: 46.18 GB
[14:36:03] - Aborted per user request
[14:38:55] Source:  MY_SOURCE
[14:39:01] - Aborted per user request
Inf file in Working folder:
[Status]
LABEL=MY_SOURCE
VERSION=v0.50.14
SOURCE_SIZE=30384267392
SOURCE_VIDEO_SIZE=30379051008
TARGET_SIZE=8422162432
REDUCTION=.277064153379363
RESIZE_1080=-1
RESIZE_1440=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=0
SUBS_TO_KEEP=ell;eng;fra;fre;ger;ita;rus;spa;
BACKUP_MODE=0
MOVIEONLY_TYPE=0
USE_LAVF=0
INSTANCES=1
DGDECNV=0
DGDECIM=0
FRIMSOURCE=0
FFMS2=0
SSIF_MODE=0
QUICK=0
ENCODE_STEP=1.5
COMPLETED=19
REBUILD_COMPLETE=0
[00231]
AUDIO=10
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=23540860
RATE=8536
SPLITS=1
NSTART=27000000
NEND=27900900
NSIZE=1579008
FLINK=0
MLINK=0
[00295]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=335846652
RATE=8468
SPLITS=1
NSTART=27000000
NEND=39954191
NSIZE=329367552
FLINK=-1
MLINK=0
[00304]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=349647053
RATE=8461
SPLITS=1
NSTART=27000000
NEND=40496608
NSIZE=342921216
FLINK=-1
MLINK=0
[00305]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=142833389
RATE=4172
SPLITS=1
NSTART=27000000
NEND=37912151
NSIZE=141576192
FLINK=0
MLINK=0
[00306]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=67619754
RATE=4170
SPLITS=1
NSTART=27000000
NEND=32168163
NSIZE=67952640
FLINK=0
MLINK=0
[00307]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=133218899
RATE=4172
SPLITS=1
NSTART=27000000
NEND=37178293
NSIZE=131328000
FLINK=0
MLINK=0
[00308]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=43988673
RATE=4170
SPLITS=1
NSTART=27000000
NEND=30361858
NSIZE=44752896
FLINK=0
MLINK=0
[00309]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=1194476070
RATE=4171
SPLITS=1
NSTART=27000000
NEND=118279938
NSIZE=1184335872
FLINK=0
MLINK=0
[00310]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=183259186
RATE=4169
SPLITS=1
NSTART=27000000
NEND=41008994
NSIZE=182691840
FLINK=0
MLINK=0
[00311]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=183613260
RATE=4170
SPLITS=1
NSTART=27000000
NEND=41033394
NSIZE=182145024
FLINK=0
MLINK=0
[00312]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=144848891
RATE=4170
SPLITS=1
NSTART=27000000
NEND=38069808
NSIZE=143671296
FLINK=0
MLINK=0
[00313]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=62238840
RATE=4169
SPLITS=1
NSTART=27000000
NEND=31758253
NSIZE=62588928
FLINK=0
MLINK=0
[00314]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=37606817
RATE=4171
SPLITS=1
NSTART=27000000
NEND=29873495
NSIZE=37502976
FLINK=0
MLINK=0
[00315]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=80477091
RATE=4170
SPLITS=1
NSTART=27000000
NEND=33150144
NSIZE=80289792
FLINK=0
MLINK=0
[00316]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=601940589
RATE=4169
SPLITS=1
NSTART=27000000
NEND=73019472
NSIZE=601024512
FLINK=0
MLINK=0
[00317]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=49558540
RATE=4173
SPLITS=1
NSTART=27000000
NEND=30785281
NSIZE=49846272
FLINK=0
MLINK=0
[00318]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=240174990
RATE=4172
SPLITS=1
NSTART=27000000
NEND=45348330
NSIZE=238147584
FLINK=0
MLINK=0
[00319]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=579405778
RATE=4172
SPLITS=1
NSTART=27000000
NEND=71261216
NSIZE=578433024
FLINK=0
MLINK=0
[00320]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=3009672306
RATE=4173
SPLITS=1
Win 10 Pro x64
Weirdo is offline   Reply With Quote
Old 8th April 2016, 13:16   #24012  |  Link
Weirdo
Update: I reloaded the source path (even though it was already loaded at BD-RB startup), and after that BD-RB picked up the previous job and is now resuming.
The overall progress shows 116% and increasing - a bit alarming.
Some more info that wouldn't fit in the previous post:
[04-08-16] Checking System Settings
  - BD-Rebuilder v0.50.14
  - Working Path Free Space: 46.60GB
  - AVISYNTH Version: 2.6.0.6, Ok
  - LAVFILTERS:  Ok
  - AnyDVD settings check: Ok.
  - X264:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - MP4BOX:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
  - FRIMEncode:  Ok
  - FRIMDecode:  Ok
[04-08-16] Systems Settings Check complete
Win 10 Pro x64
Old 8th April 2016, 16:52   #24013  |  Link
wakko709
it doesnt!
Old 8th April 2016, 16:59   #24014  |  Link
jdobbs
it doesnt!
Then the best guess is that you either have a corrupt source or one that hasn't been decrypted correctly. That's pretty much the only thing that could cause an error in demuxing.
Old 8th April 2016, 23:45   #24015  |  Link
AmigaFuture
AmigaFuture's Avatar
Originally Posted by MrVideo View Post
FYI: 59.94 fps video doesn't exist. 29.97 fps video does. FPS = frames per second, not fields per second.
Originally Posted by DoctorM View Post
For 720p (and 4k) it does... but then you wouldn't need to IVTC it.
What I know is, I became excited when Comcast announced the change to MPEG-4 from MPEG-2. With a very slow migration. Now, some of what I like is encoded with my TiVo device as MPEG-4. I understand 59.940 doesn't actually exist, which is why the render down. BD-RB went too low with 23.976, and another software I use sometimes allowed for 29.97. I was wondering if something might be broken or just not detecting correctly.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!!
AmigaFuture is offline   Reply With Quote
Old 9th April 2016, 02:09   #24016  |  Link
MrVideo
MrVideo's Avatar
The only difference between the the MPEG-2 days and the MPEG-4 days is that the video is now H.264. Any produced program that is 1080, will be 1080i @ 29.97 fps. Those programs will normally also be sourced from 23.976 video, meaning that it will be run thru 2:3 pulldown to get to the 29.97 frame rate. Stuff produced on video, like live sports, will be be 1080i as well, but with pure 29.97 frame source. When it comes to comes to produced programs aired via a 720p channel, the frame rate will indeed be 59.94. Again 2:3 pulldown will be used for 23.976 source material.
So, I'm confused by your render down statement. There is no 59.94 1080i source to render down, only 720p. For 1080i you either keep it at 1080i29.97 or you IVTC to 1080p23.976. Same goes for 720p. You either keep it at 720p59.94 or IVTC it to 720p23.976.
What do you mean that "BD-RB went too low with 23.976?" And why would the software "sometimes allowed for 29.97?" 29.97 is a valid frame rate for all 1080i source material.
There are some who prefer to take 1080i29.97 video (sports for example) and de-interlace it to 1080p29.97. IMHO, that ruins time spacial information. I don't care for sports, so I never deal with it.
So, if you think that you have 1080i59.94 source material coming from Comcast, you don't.
Old 9th April 2016, 05:37   #24017  |  Link
AmigaFuture
Then I'm curious why:
[04/08/16] BD Rebuilder v0.50.12
[19:20:52] Source:  THE_STORY_OF_GOD_WITH_MORGAN_FREEMAN_-_''BEYOND_DEATH''_(RECORDED_APR_3,_2016,_NGCPHD)_00000
  - Input BD size: 1.04 GB
  - Approximate total content: [00:50:04.017]
  - Windows Version: 6.1 [7601]
  - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled
  - Mode: MKV Container, 1280x720, Intact Audio
  - Decoding/Frame serving: DGDecNV
[19:20:53] PHASE ONE, Encoding
 - [19:20:53] Processing: VID_00000 (1 of 1)
 - [19:20:53] Extracting A/V streams [VID_00000]
 - [19:21:02] Reencoding video [VID_00000]
   - Source Video: MPEG-4 (AVC), 1280x720
   - Rate/Length: 59.940fps, 180,061 frames
   - Inverse Telecining in effect (IVTC)
   - Bitrate: 2,352 Kbs
 - [19:21:02] Reencoding: VID_00000, Pass 1 of 2
 - [19:40:19] Reencoding: VID_00000, Pass 2 of 2
 - [19:59:29] Video Encode complete
 - [19:59:29] Processing audio tracks
[19:59:29]PHASE ONE complete
[19:59:29]PHASE TWO - Rebuild Started
 - [19:59:29] Building ALTERNATE OUTPUT Structure
[19:59:49] - Encode and Rebuild complete
[19:59:49] JOB: THE_STORY_OF_GOD_WITH_MORGAN_FREEMAN_-_''BEYOND_DEATH''_(RECORDED_APR_3,_2016,_NGCPHD) finished.
Output is 23.976fps when it should be 29.97fps. Which is why the video is jerky.
Side note...to everyone.. Go to Target and comment about the 24.99$ version of Star Wars: The Force Awakens not being any different than the 19.99$ version other than the front cover. I got mine for "Noticing the Force" reduced rate of 14.99$. At eBay it's 16.99$ (by Target). In line I commented about the price difference and why and...interaction followed about "The Force" and a reduction.
Maybe you'll get the same reaction?? I love the Extras. Before I went shopping, I had a feeling.
Old 9th April 2016, 06:03   #24018  |  Link
Sharc
Upload a 2s sample of your captured video source.
Old 9th April 2016, 06:29   #24019  |  Link
AmigaFuture
As requested. You didn't specify where, this is after the commercials at the start.
If you want during the episode I'll resend. But should show the same information.
Old 9th April 2016, 06:49   #24020  |  Link
Sharc
It would be better/faster to upload to a filehoster like mediafire or similar than attach it here.
