Old 4th January 2019, 09:56   #8701  |  Link
How can I achieve this kind of result with MeGUI?
The two things I'm not sure if I want are the change of colors and thickness of lines
MeGUI is an encoder, what you ask is not really in the MeGUI domain.
What kind of result?, you say what you do not want, but not what you do want. (and we are I presume to take it that the src is on the left).
It would be my guess that nobody knows what you want.
Old 4th January 2019, 14:17   #8702  |  Link
videoh
Useful n00b
After you take away the color and line changes, what's left appears to be some sharpening. So apply a sharpening filter of your choice. For anime, something like MSharpen will spare the flat areas.
Old 4th January 2019, 23:19   #8703  |  Link
TakuSkan
TakuSkan's Avatar
Originally Posted by doomleox999 View Post
How can I achieve this kind of result with MeGUI? I want to encode "old" anime. Which AviSynth plugins should I download, where can I get them, and how should I write the script?
The two things I'm not sure if I want are the change of colors and thickness of lines (if you pay attention in the "restored" screens the lines are thinner).
Thanks in advance!
For modifying colors, you may want to play with the ColorYUV and Tweak settings in the AVIsynth file until you get what looks good for you. For instance:
ColorYUV(gain_u=-7, gain_v=-0)
Tweak(sat=.78,bright=5,hue=-3,cont=.8)
Read through these pages:
https://avisynth.org.ru/docs/english...ters/tweak.htm
https://www.animemusicvideos.org/gui...spostqual.html
Sharpening is another option to crispen up lines as videoh suggested. I know no means for adjusting line thickness.
[Taku Skan doesn't represent me, but is recogition of a Lakota sense of the sacred.]
[My TakuSkan avatar is a detail from a Dali painting that's provoked a few philoshopic questions.]
[I do Zen on a K75S]
TakuSkan is offline   Reply With Quote
Old 6th January 2019, 04:59   #8704  |  Link
doomleox999
What about the noise? The default from MeGUI is not enough, not even the "medium" one. I have some 30 seconds samples but I'm not sure if we can share them here. Perhaps a couple of screenshots will do.
doomleox999 is offline   Reply With Quote
Old 6th January 2019, 05:38   #8705  |  Link
I repeat, MeGUI is an encoder. (It basically encodes what you give it)
VideoH gave you a suggestion for MSharpen, good suggestion and it used to be my 'go to' sharpener, but alas I pretty much forgot about it lately.
VideoH, (aka Guest, aka Neuron2, aka Donald Graft) also does the MSmooth plugin, works in counterpart to the MSharpen plugin, maybe also give a try.
I repeat (again), MEGUI is an encoder, learn how to use Avisynth, and hand results to MeGUI for encoding.
Old 6th January 2019, 06:30   #8706  |  Link
Groucho2004
Sorry to be nitpicky but it really isn't. It's a frontend to a bunch of programs including encoders to make it easy for people to convert their video/audio to the desired target format.
Groucho's Avisynth Stuff
Old 6th January 2019, 13:20   #8707  |  Link
Thats OK nitpicker, you dont need apologise, anyways, I think we can agree that it aint a general purpose video editor.
EDIT: Just in case you are not aware of what a nit is,
Egg or young of an insect parasitic on mammals especially a sucking louse; often attached to a hair or item of clothing
you got some nasty habits.
Old 6th January 2019, 18:03   #8708  |  Link
Groucho2004
I do have some nasty habits but picking sucking lice is not one of them.
Old 6th January 2019, 20:16   #8709  |  Link
Zathor
Originally Posted by TakuSkan View Post
I'm still not all that clear on what Zathor means by "a sample" .. "cut from PGC 3 only a VOB ID" Does he mean those 2 VOBs PGCDemux made from PGC 3? Or something I can extract or edit out of them?
The samples you have provided are fine, however I am not able to reproduce it. I used the VTS_02_1.VOB you have provided first, OneClick in default configuration and the encoding (video & audio) has 24:53 as excpected. Are you able to reproduce it with that file only?
Zathor is offline   Reply With Quote
Old 6th January 2019, 22:09   #8710  |  Link
Danette
Using the One-click, I'm pouring a bunch of avs script into it and it all works fine ...EXCEPT for the trim function. I suspect that this is due to MeGUI automatically demuxing everything before even looking at filters.
So, my audio is from the beginning of the stream and way out of sync. I believe that I can use the AVS Cutter tool, but this is somewhat cumbersome (over ten trim points) whereas I can easily build all the trimming into AvsPmod and simply transfer all the script to the One-click. Plus I can't control the fading in the AVS Cutter. Some trim points I want to fade and not others and I want shorter fading.
Is there some way to get the trim and fade avs filters to work in MeGUI like they would if I used Virtualdub to process the file?
Danette is offline   Reply With Quote
Old 6th January 2019, 22:52   #8711  |  Link
Zathor
Have you tried to use the trimmed avs file also as audio input?
Old 7th January 2019, 00:19   #8712  |  Link
Danette
Can you give an example?
Old 7th January 2019, 19:37   #8713  |  Link
Danette
Never mind providing an example. I was able to get it to work.
I had to strip out all of the other filters from the avs file script, leaving only the source video and the trim / fade filter.
Then, when I loaded that stripped-down avs file into the audio encoder, it worked perfectly.
Thanks
Old 8th January 2019, 16:05   #8714  |  Link
hello_hello
Zathor,
Thanks for the work on the chapter creator. It seems to be pretty good now. Except.....
I know it was my idea originally, but is there a reason why you stayed with locking the input fps when opening an IFO file, or locking the output fps when opening a preview?
The locking of the input fps is probably a bit like locking the Input DAR in the script creator. There's times when you need to change it. A common situation would be when opening chapters from an NTSC DVD and applying IVTC. In order to save a correct QP file you need to be able to tell the chapter creator to use 23.976 as the input frame rate instead of 29.97fps. If you open a preview script with IVTC applied, the chapter creator assumes the output fps has been slowed to 23.976fps and the chapter timecodes are also wrong because the frame rate has been reduced by removing frames.
There's a workaround. You can open an IFO file, save the chapters file with the input/output fps set to 29.97fps so the chapter timings are correct, then open the saved chapter file so you can set 23.976fps as the input/output frame rate, and from there save a correct QP file, but I'm not sure why it doesn't make more sense to adjust the input fps when opening an IFO file in the first place, as you can for text chapter files.
Locking the output fps when opening a preview is probably no big deal as it'd be safe to assume the preview script already has IVTC applied etc.
Thanks for the hard work!
Old 10th January 2019, 22:09   #8715  |  Link
Forteen88
Herr
I wonder, how come MeGUI sets x265 to rdoq-level=2 and psy-rdoq=1.00
when I encode video? The default is rdoq-level=0 and psy-rdoq=0.00
I used the x265-parameter:
--preset veryslow --crf 20 --frame-threads 1 --profile main10 --output-depth 10 --rc-lookahead 48 --ctu 32 --no-sao --deblock -1:-1 --qcomp 0.7 --ref 6 --bframes 16 --aq-mode 1 --aq-strength 0.8
I used MeGUI-2896-64 and x265 v3.0RC4.
Thanks
Forteen88 is offline   Reply With Quote
Old 10th January 2019, 22:33   #8716  |  Link
sneaker_ger
Because you are using --preset veryslow.
https://x265.readthedocs.io/en/default/presets.html
Old 10th January 2019, 22:56   #8717  |  Link
Forteen88
Herr
. I used that webpage, but I searched for "psy", and missed it :P
Old 16th January 2019, 05:54   #8718  |  Link
doomleox999
Is it possible to choose the available languages? I only work with 3 and It's a bit annoying to always have to search for any of them in the large list of languages even by just pressing the first letter in the keyboard. I'm not talking about the default languages btw, I'm talking about these:
Old 16th January 2019, 09:54   #8719  |  Link
LigH
LigH's Avatar
You already asked the same in the other MeGUI thread. No crossposting please.
New German Gleitz board
Old 17th January 2019, 21:36   #8720  |  Link
jlw_4049
Subtitles encoding to PGS zlib
Is it normal for MeGUI to encode the subtitles to zlib. Is there any way I can encode without changing the subtitles from PGS to PGS Zlib?
jlw_4049 is offline   Reply With Quote
megui
