18th March 2016, 04:59 | #5021 | Link | |
There are about 238 remove dirt variants and versions You have one in your script, called as a function as a dependency for removedirtmc . That actually relies on one of the 164.5 versions of removegrain.dll http://forum.doom9.org/showthread.ph...16#post1761016 Code:
. . . function RemoveDirt(clip input, int "limit", bool "_grey") { clensed=input.Clense(grey=_grey, cache=4) alt=input.RemoveGrain(2) return RestoreMotionBlocks(clensed,input,alternative=alt,pthreshold=6,cthreshold=8, gmthreshold=40,dist=3,dmode=2,debug=false,noise=limit,noisy=4, grey=_grey) # Alternative settings # return RestoreMotionBlocks(clensed,input,alternative=alt,pthreshold=4,cthreshold=6, gmthreshold=40,dist=1,dmode=2,debug=false,noise=limit,noisy=12,grey=_grey,show=true) # return RestoreMotionBlocks(clensed,input,alternative=alt,pthreshold=6,cthreshold=8, gmthreshold=40,dist=3,tolerance= 12,dmode=2,debug=false,noise=limit,noisy=12,grey=_grey,show=false) } . . . |
18th March 2016, 05:16 | #5022 | Link |
I know you're trying to lead me down a path to understand what's happening, but I'm afraid I'm too inexperienced to see it..
I guess my question still is, it appears that that particular removedirt needs a loadplugin? I thought that if I had its replacement (rgtools) in the autoload folder, it would load by itself. When I manually load the RGtools, the script works. |
18th March 2016, 05:38 | #5023 | Link | |
Notice in the rgtools documention , the clense version there doesn't have cache argument, the original one does https://github.com/tp7/RgTools/blob/master/README.md http://avisynth.nl/index.php/RemoveG...veGrain/Clense You would have to modify your script or use the other version I don't think rgtools needs loadplugin(), not sure what is going on there. Do you have the .dll in the plugins folder (not in a subfolder) ? rgtools does include removegrain, which is part of that function for that version of removedirt |
18th March 2016, 06:28 | #5024 | Link | |
I'm still kind of having a hard time figuring out where to get the speed back up to 29.97 after running the filters. I looked for a return final statement, or something similar, and the script isn't written exactly that way. Looking at the script, do you have any suggestions on where I might put it? Maybe there is some verbiage in there that you recognized as the equivalent of the "return final" type of statement? |
18th March 2016, 22:37 | #5025 | Link |
Your last line of the actual script is
Eval(result) and at the top of the script, where you enter parameters, you've defined result as: Code:
result="result4" It would be this one: result4= PreBorderFrame.coloryuv(off_U=blue,off_V=red).levels(black_level,gamma,white_level,0,255).addborders(bord_left+in_bord_left, bord_top+in_bord_top, bord_right+in_bord_right, bord_bot+in_bord_bot).ChangeFPS(30000,1001) |
19th March 2016, 05:05 | #5026 | Link | |
I think I tried that spot, (I tried a few places) in the same position, but not as a continuation of the same text line you did, (after adding a period) I just put a new line of text with the changeFPS command under that line. If that not working doesn't make sense, then I must be mistaken. But regardless, it worked. Thank you PDR, and also Groucho, thank you very much also. And kudos to you both for putting up with my beginners level of comprehension about these processes. Now that that has been hammered out, alond with my issues with AVSPmod, I think I'll go back to the other thread in Avisynth Usage, and try to get from having a good .264 file, to having it authored and ready to put on a BD. And probably before I do that I also need to incorporate the L-Smash into the script so as to be able to take on some more robust files out of Vegas. Again, thanks to all. |
4th April 2016, 00:59 | #5029 | Link |
MeGUI version 2624 has a bug that it cannot export presets.
When I export my custom presets I get an empty 1kb .zip If I revert to previous MeGUI 2525 version I am able to export the presets. You can reproduce this by following these steps:
End result: empty 1kb .zip file. |
4th April 2016, 07:10 | #5030 | Link |
MeGUI's script creator is somewhat misleading at the moment when anamorphic encoding is enabled. It doesn't matter if the resizing and aspect error are wrong because resizing is disabled, but it's misleading, especially for someone new to MeGUI, and it's hard enough for them to understand the anamorphic options. Today I found myself once again explaining to someone via a forum post why you can encode mod16 with an option called "encode non mod16". Could the name be easily changed? "Anamorphic strict" as Handbrake describes it would make more sense.
I don't know whether you saw my bug report a while back Zathor, but switching encoder presets still doesn't work when the encoder configuration is open, it only has an effect if you also change an encoder setting. If you select a different preset and close the encoder configuration it'll revert to the previously selected preset. Opening the preview via the button in the video section and changing the DAR should force MeGUI to use the selected DAR if you add the script to the queue for encoding immediately after closing the preview. It's not working. Thanks. |
5th April 2016, 14:05 | #5031 | Link |
I'm not sure if it's a real bug or I doing something wrong, but maybe you can help me.
I have several times try to encode some different mpeg2.ts files, but everytime the encoding crashed at the second rendering job with this error: Process exits with error: 0xC0000005 STATUS_ACCESS_VIOLATION (-1073741819) The error comes only when the second pass encoding starts, whitout them anything works well, but for better quality I want the second pass... I already tried different thinks like disable x264 64bit, but nothing help. For the last test I deinstalled and reinstalled MeGui complette, but without success... Errorlog is attached. Greets Carlo |
5th April 2016, 15:03 | #5032 | Link | |
x264's quality based encoding (CRF) encodes exactly the same way as 2 pass. There's very minor differences, but if each method encoded the same video at the same bitrate, the quality would be identical. So for 2 pass encoding the bitrate or file size is known, but the quality is unknown. For CRF encoding it's the other way around. You pick the quality and the bitrate will be whatever it needs to be (according to how hard the video is to compress). |
5th April 2016, 18:04 | #5033 | Link |
Hi hello_hello.
Ok, I had always selected CRF18 and pre-rendering. If I understand you right, that was not necessary. But on the other way, it should work anyway... for that there must be something wrong. Greets Carlo |
7th April 2016, 18:45 | #5034 | Link |
Carlo75,
I'm not sure if I'm following your log file exactly.... there seems to be some OneClick encoder stuff in there.... but when you referred to a second pass I thought you meant you'd configured x264 for 2 pass encoding. It runs the first pass to work out how to distribute the bits and a second pass to encode, and you'd specify a file size or bitrate. A pre-rendering job is something else. To be honest I've never used it as it was probably intended. I think the idea is if you're using 2 pass encoding (x264 configured for 2 pass) and you've got very slow filtering in a script, the pre-rendering job applies the filtering to the video but the output is encoded as a lossless AVI in a single pass. Once that's done the lossless AVI is used for 2 pass encoding and the encoder can run each pass at full speed. The filtering doesn't have to be run twice as it normally would. I'm pretty sure MeGUI lets you add a pre-rendering job when using CRF encoding but I can't imagine there'd ever be much point. Without pre-rendering the source is being decompressed and re-encoded, with pre-rendering the source is being decompressed and saved as a lossless AVI which is then re-encoded, but the result should be exactly the same either way. I did manage to reproduce your problem. Process exits with error: 0xC0000005 STATUS_ACCESS_VIOLATION (-1073741819) I'm running XP so I can't use the latest ffmpeg (which is used to create the lossless AVI) because it doesn't work, so I rolled back to an earlier version. It created the lossless AVI for me, but after that was indexed x264 produced the same error in the log file. I tried again while encoding with Xvid and I thought it was successful, but I discovered it had encoded the error message instead. This time it was: CAVIStreamSynth: Access Violation at 0xba3c06, reading from 0x1091020 Best as I can tell it's ffmsindex's fault. If I manually create a script to open the lossless AVI with L-Smash it encodes successfully. For the moment though it's probably not something you need to worry about because it seems like creating a pre-rendering job isn't necessary in your case. For anyone who might want to look at the problem, if I create a lossless AVI using MeGUI's pre-rendering option, and I then create the following script to open it, the script will open in MeGUI's preview, it'll open in MPC-HC, but it won't encode via MeGUI. That's me and MeGUI and XP, if it's relevant. I can't test older versions of ffms2 myself at the moment as I'm in the middle of some encoding jobs that are using it for decoding. LoadPlugin("C:\Program Files\MeGUI\tools\ffms\ffms2.dll") FFVideoSource("D:\test.avi", threads=1) |
10th April 2016, 13:06 | #5035 | Link |
Mr. Woof
Hello, I'd like to request the ability to sort the columns in the HD Stream Extractor window, specifically in the Features pane. Right now when you click on a column name/header, it does nothing. Having them sort in both ascending and descending fashion would be helpful when processing discs with Screen Pass protection, for example.
11th April 2016, 13:59 | #5036 | Link |
I started to have same problem ''0xC0000005 STATUS_ACCESS_VIOLATION (-1073741819)'' everything was working well yesterday, today I tried to encode x264 video like always and it kept giving this error, I don't know what to do
this is my log file info: --[Error] [11-Apr-16 3:52:06 PM] Process exits with error: 0xC0000005 STATUS_ACCESS_VIOLATION (-1073741819) --[Information] [11-Apr-16 3:52:06 PM] Job completed -[Information] [11-Apr-16 3:52:15 PM] Successfully deleted C:\Users\Adem\Desktop\Hundred OP60.264 -[Information] Log for job2 (mux, Hundred OP60.264 -> Hundred OP60.mp4) --[Information] [11-Apr-16 3:52:15 PM] Deleting intermediate files -[Information] Log for job1 (video, Hundred OP.avs -> Hundred OP60.264) --[Information] [11-Apr-16 3:54:48 PM] Started handling job --[Information] [11-Apr-16 3:54:48 PM] Preprocessing -[NoImage] SetMemoryMax(512) -[NoImage] #SetMTMode(3,4) -[NoImage] PluginPath = "E:\video encoding\MeGUI\tools\avisynth_plugin\" -[NoImage] LoadPlugin(PluginPath+"svpflow1.dll") -[NoImage] LoadPlugin(PluginPath+"svpflow2.dll") -[NoImage] Import(PluginPath+"InterFrame2.avsi") -[NoImage] LoadPlugin("C:\Program Files (x86)\Haali\MatroskaSplitter\avss.dll") -[NoImage] dss2("C:\Users\Adem\Desktop\Hundred OP.mp4", fps=23.976).AssumeFPS(24000,1001).ConvertToYV12() -[NoImage] #SetMTMode(2) -[NoImage] #deinterlace -[NoImage] #crop -[NoImage] #denoise -[NoImage] #resize -[NoImage] InterFrame(Cores=4, GPU=True) --[Information] [11-Apr-16 3:54:48 PM] Avisynth input script --[Information] [11-Apr-16 3:54:48 PM] resolution: 1920x1080 --[Information] [11-Apr-16 3:54:48 PM] frame rate: 60/1 --[Information] [11-Apr-16 3:54:48 PM] aspect ratio: 16:9 (1.778) --[Information] [11-Apr-16 3:54:48 PM] Job command line: "E:\video encoding\MeGUI\tools\x264_10b\x264-10b.exe" --level 5.2 --preset superfast --tune animation --bitrate 10000 --keyint 600 --vbv-bufsize 300000 --vbv-maxrate 300000 --sar 1:1 --output "C:\Users\Adem\Desktop\Hundred OP60.264" "C:\Users\Adem\Desktop\Hundred OP.avs" --[Information] [11-Apr-16 3:54:48 PM] Process started --[Information] [11-Apr-16 3:54:48 PM] Standard output stream --[Information] [11-Apr-16 3:54:48 PM] Standard error stream ---[Information] [11-Apr-16 3:54:49 PM] avs [info]: 1920x1080p 1:1 @ 60/1 fps (cfr) ---[Information] [11-Apr-16 3:54:49 PM] x264 [info]: using SAR=1/1 ---[Information] [11-Apr-16 3:54:49 PM] x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX ---[Information] [11-Apr-16 3:54:49 PM] x264 [info]: profile High 10, level 5.2, 4:2:0 10-bit --[Error] [11-Apr-16 3:56:18 PM] Process exits with error: 0xC0000005 STATUS_ACCESS_VIOLATION (-1073741819) --[Information] [11-Apr-16 3:56:18 PM] Job completed -[Information] [11-Apr-16 3:56:26 PM] Successfully deleted C:\Users\Adem\Desktop\Hundred OP60.264 -[Information] Log for job2 (mux, Hundred OP60.264 -> Hundred OP60.mp4) --[Information] [11-Apr-16 3:56:26 PM] Deleting intermediate files |
12th April 2016, 17:21 | #5037 | Link | |
http://download.videolan.org/pub/vid...x264/binaries/ |
13th April 2016, 15:28 | #5038 | Link | |
Edit: I still have same problem, encoding stops at 63% or sometimes 67% :/ |
13th April 2016, 15:55 | #5039 | Link | |
E:\video encoding\MeGUI\tools\x264_10b\x264-10b.exe So please download 10bit x264 for Win32 http://download.videolan.org/pub/vid...65-a01e339.exe Then please copy downloaded file to folder E:\video encoding\MeGUI\tools\x264_10b\ At the end please rename x264-10b-r2665-a01e339.exe to x264-10b.exe ------------- There is new stable source code for x264 ver. 148.2691. Soon should be new binaries. Last edited by Ma; 13th April 2016 at 16:12. |
14th April 2016, 13:11 | #5040 | Link | |
