9th June 2007, 21:01 | #203 | Link | |
After remuxing with version 11 disk played on PS3, but without video and audio. After remuxing with version 12 I got that error. |
9th June 2007, 21:03 | #204 | Link | |
Coder
I've changed BDedit to work with it. |
9th June 2007, 22:35 | #206 | Link |
OK. Managed to finally burn a BDMV created with version 12. Disc plays fine in PS3, I can see a picture but there's no sound. Exactly the same results as with the previous version; PS3 reports nothing about audio etc.
Panny BD10 again recognizes the disc as BD and tries to play it. After a couple of seconds of black screen player display reads STOP and playback stops. I seem to remember that PC-burned BD-REs used to work on the Panny, but that was before I updated its firmware to v2.0. Maybe that disabled non-AACS BD-RE support? |
9th June 2007, 22:39 | #207 | Link |
FYI, my burn process is as follows:
1) remux with TsRemux to "Blu-ray" 2) select Blu-ray Disc (UDF) compilation type in Nero 7 Premium (v7.9.6.0), switch file system manually to UDF 2.50 and drop the BDMV directory into compilation 3) select Image Recorder as destination and write a .NRG disc image on HDD 4) use the latest ImgBurn to burn the image on BD-RE disc Oddly enough one of my PCs burns discs at 1x speed only. Another PC burns happily at 2x - same burner, same media. Weird stuff. |
9th June 2007, 22:42 | #208 | Link |
Update on the Panny BD10 issue. Found an older BD-RE which worked on the Panny (luckily I had written that on the label as a reminder) and placed it in the player. Works fine!
So, TsRemuxed BDMVs not working on the Panny is not Panny's fault. |
10th June 2007, 02:01 | #209 | Link | |
I also have chapters every 5 minutes and can skip between chapters. So, TsRemuxed BDMVs not working on PS3 is not PS3's fault. Probably Nero producing inconsistent results with burning Blu-ray disks. My burn process is as follows:
10th June 2007, 18:35 | #214 | Link | |
Keeping this in mind, I dug out that BD-RE which works in the Panny BD10 v2.0. I burned it quite some time ago,way before the Panny 2.0 firmware was released. I thought the missing CERTIFICATE could be the reason why my TsRemuxed test burns aren't working in the Panny... but that's not the cause. The older BD-RE that works in the Panny doesn't have CERTIFICATE either; only BDMV. Hey, maybe I should rip that discs' BDMV directory for you to check? |
10th June 2007, 18:46 | #215 | Link |
Here's the BDMV (sans STREAM, naturally) from the BD-RE which works in the Panasonic:
http://www.box.net/shared/jiupl9nurt |
10th June 2007, 21:00 | #216 | Link | |
Not enough System Resources to Start.Any Idea whats goes Wrong Icemaan |
10th June 2007, 23:00 | #219 | Link |
dmz01:
Version 0.0.12 works very well for me! Some problematic transport streams I recorded with media portal tv server 3, now are fully playable with MPC+Haali+CoreAVC, after I passed (and trimmed beginning/end) it through TSRemux. I do use .ts as output format. Thanks a lot! |
