29th September 2005, 12:54 | #641 | Link |
º¿º XviD N00B º¿º
Thanks for reply Doom9
D2V Creator: I'm not sure I understand all the reasons for not being able to load more than one Vob in D2V Creator. But it sure sounds complicated. Good luck with implementing that I'll just do it manually with DGIndex for now Regarding Avisynth Script Creator: Yes I see it's the same as DGIndex. I guess I'm just spoiled by GordianKnot and the instant preview of my resize and PAR it offers. Regarding Resize: I did see a problem with the suggested resolution. However I figured out I had to check SUGGEST RESOLUTION after Crop. BTW. Why Isn't it possible to go higher than 720 horizontal ? Should have been 640 x 272 I never did say thanks for developing this nice gui
"We are all Newbies at something" -- NightRhyme |
29th September 2005, 14:20 | #642 | Link | ||||
clueless n00b
29th September 2005, 14:21 | #643 | Link | |
clueless n00b
29th September 2005, 16:09 | #644 | Link |
º¿º XviD N00B º¿º
Thanx again for reply Doom9
Ohh I see that's how D2V creator works Didn't know Resolution: ok 720 is max for pal. I guess It's just me who likes upsizing a bit Resizing: No the resizing function works correctly. The screenshot was taken without cropping before checking SUGGEST RESOLUTION.
1st October 2005, 07:03 | #645 | Link |
i have some problems with the mkv muxing function once you hit AutoEncode
it gives me no option to select if my .aac is AAC+ ( i understand the option needs to be checked for proper muxing if your .aac is AAC+ ) also the vobsub muxing doesnt work for me.. whenever i select a .sub to mux into the mkv i get an error saying there's a command line error.. i do not get an option to select a .idx - however in mkvmerge gui i have to select the .idx and it works perfectly |
1st October 2005, 07:42 | #646 | Link | ||
clueless n00b
1st October 2005, 08:14 | #647 | Link | |
for the aac i use besweet with dimzon's winamp dlls.. dont like NAAC because it requires nero installed and i hear winamp's dlls provide better quality sound than FAAC |
1st October 2005, 08:33 | #648 | Link | |
clueless n00b
1st October 2005, 08:59 | #649 | Link | |
muxing the .mkv movie file with .aac audio and vobsubs works fine in mkvtoolnix gui though.. thats why i thought it should work in megui as well |
2nd October 2005, 19:37 | #650 | Link | |
Error: 'D:\DVD\Projects\MOVIE_VTS_02_PGC1\MOVIE.sub': Error parsing a MPEG PS packet during the header reading phase. This stream seems to be badly damaged. thats the error i get everytime i try to mux a .sub into an mkv with megui |
2nd October 2005, 20:18 | #651 | Link | |
clueless n00b
2nd October 2005, 20:50 | #652 | Link | |
i cant select a .sub file with 'all supported media files' in the dropdown menu for file types but if i switch to 'all files' it is possible to select a .sub i havent tried if it works though.. all i know is that .sub muxing in megui doesnt work right and if i select .idx in mkvtoolnix it works fine |
2nd October 2005, 21:06 | #653 | Link | |
clueless n00b
3rd October 2005, 02:50 | #654 | Link |
Hates all his encodes
I'm having a problem it seems, with MeGUI... Originally I thought it was a .NET problem
http://x1.putfile.com/10/27420491042.gif Any causes, solutions?
http://thevideophile.blogspot.com/ Watch and be amazed by my frustration over the video world! |
3rd October 2005, 03:29 | #656 | Link | |
No... I simply have to execute the program. >> And, no, I have 1.1. In fact, I reinstalled it (twice) to make sure, but no-go.
3rd October 2005, 09:46 | #659 | Link |
BeHappy/MeGUI developer
Bug Report
Seems like MeGUI trying to read "jobs" folder from current directory (not executable directory)
BeHappy - AviSynth-based audio transcoding tool Audio encoding via AviSynth On2 VP7 is great in quality but it is unusable for long-term video backup puposes! Sincerely Yours, MCPD/MCTS |
3rd October 2005, 10:12 | #660 | Link |
clueless n00b
@locke86: thanks for testing. I suppose the fix will be to simply disallow .sub input and enable .idx subtitle input instead. I'll put that into the next build but I have no release date yet as I'm completely restructuring the dgindex part to allow queueing of multiple one click jobs.
