22nd October 2017, 12:25 | #46801 | Link |
To detect how and when to activate RCA and RRN, it would be nice to have access to mediainfo's bitrate in order to combine it with resolution of video. It probably couldn't be fully automatic but, at least at the single user level, one could further combine it with source folder naming to have broad categories to act upon.
Just my two cents. |
22nd October 2017, 17:01 | #46802 | Link | |
22nd October 2017, 18:44 | #46803 | Link | |
No. RCA@4 itself is pretty damn good.
I'm infected with poor sources. |
23rd October 2017, 00:47 | #46805 | Link | |
23rd October 2017, 01:02 | #46807 | Link |
Can you pls recheck the version from Nvidia drivers ? (IIRC the latest GF divers have an issue, stick with 385.69 or 385.41)
Does this also happen after resetting Madvr to default settings ? Try to figure this out first. Why do you still use "windowed overlay'' in your Madvr settings ? You could also update LAV to the latest nightly (see OP LAV-filters) What video-card do you use ? Last edited by Pat357; 23rd October 2017 at 01:36. |
23rd October 2017, 01:39 | #46808 | Link | |
I tried disabling overlay as well as selcting 1050 TI in LAV - same result. I also upgraded to W10 Fall update. I'll now go back to 385.69 and see if that helps. There are too many variables now after the W10 update ... |
23rd October 2017, 06:38 | #46809 | Link |
Hi! I have problems in "Pc mode" when playing HDR with my TV. I do not know why, the colors look different with less brightness. My Tv is a LG OLED C7P.
I think it's because of the color range, but in my tv in "Pc modte47a e/HDR" it is locked. If I change the label of "Pc mode" to HDMI it works perfect bit is 422. Any idea why? The difference between 444 and 422 is visible?
"To infinity, and beyond!" |
23rd October 2017, 09:16 | #46810 | Link | |
@madshi I'd like to note that madVR takes away a lot of potential shortcuts by not allowing a bunch of valid characters on my keyboard, by falsely claiming they're invalid: "νιαűφόσőϊ". That's nine, plus "." and "," both become "decimal" and neither of them work so, nor does "/*-+" that's +5. Seeing as media players already use a lot of shortcuts this greatly aggravates an already bad situation. (I don't understand why software typically don't read keycodes and modifiers and thus are perpetually bugged on non-english keyboards) |
23rd October 2017, 10:10 | #46811 | Link |
Hi, one question, in "display mode-> list all displa modes madvr may switch". Is there any way to specify the bits? For example, some way to automaticaly change from 2160 60Hz 8-bit to 2160 23Hz 12-bit? Without going to the nvidia panel, of course...
23rd October 2017, 10:51 | #46812 | Link | |
You are right though, it would be very nice to choose bit depth in both resolution switching and in the custom resolution setup (if possible). Last edited by Razoola; 23rd October 2017 at 10:59. |
23rd October 2017, 11:35 | #46813 | Link | |
23rd October 2017, 11:57 | #46814 | Link | |
Win7Ult || RX560/4G || Ryzen 5 |
23rd October 2017, 12:25 | #46815 | Link | |
23rd October 2017, 16:01 | #46816 | Link | |
(Resolution)(bit)(Colour space) i.e (2160p@24)(8)(4:2:0) |
23rd October 2017, 16:09 | #46817 | Link | |
Posts: n/a
Black Screen FCU
Hi guys. Just did a fresh install of windows 10 fall creators update, and installed mpc and madvr. video plays fine but when i enter fullscreen it goes black. Sound is playing and i can see the mouse pointer, but no video. When i leave fullscreen the buttons of mpc are all black
Also if i press the right mouse button the menu shows up and video too, but after a few seconds it goes black again. EVR Custom works fine. madvr 0.92.7. Quote:
But i wasn't using d3d11 on previous install and was working fine. Last edited by leandronb; 23rd October 2017 at 16:12. |
23rd October 2017, 17:57 | #46819 | Link |
I wasnt suggesting you put that in the display modes, that was just an example of what could be put in there if this was further developt as per your suggestion, mine is currently set as:
1080p24, 1080p25, 1080p30, 1080p50, 1080p60, 2160p24, 2160p60 |
23rd October 2017, 18:55 | #46820 | Link |
GPU driver rejected this mode, for unknown reason
I recently updated my Nvidia drivers to 385.41 (uninstalled older using DDU).
My display measurements were still there, so it did not take to long before I had set everything up to the state I was before updating the drivers. I tested different input files and checked on Madvr OSD whether the '1 frame repeat every .... " was still far above a normal movie length (order > 1 day). So everything was working ! Today I noticed madvr didn't switch to the correct mode no longer : every file was played @60Hz. I went to custom modes setting in Madvr and tested some optimised modes: for every mode I got "GPU driver rejected this mode, for unknown reason". Even for the default modes (CTA, CTF, ...) I got the same error. Anyone knows how to get rid off this error ? Will deleting all custom modes and start over help ? Reinstalling the display drivers ? anything else ? |
