16th May 2009, 11:37 | #2721 | Link | ||
Programmer (or just 教务长)
Thanks for pointing it out - I was also getting the error - just had no time to test everything. Quote:
@rendez2k: Thanks for testing. Please remove your log from the the post. Dean ****** Build 588: * Fixed a problem with "Thumbnail menu" * Fix for DTS to AC3 conversion. * Added Support for MPEG audio (mp2) tracks in named after the video. They will be converted to AC3 on the fly (i.e. movie.m2v + movie.mp2). Last edited by deank; 16th May 2009 at 11:57. |
16th May 2009, 17:16 | #2722 | Link |
After few test with 588 build, the loop playback after the last title mvoie not works (with quit on last title finish option unchecked).
On AVCHD with menu after last title playback the player return on menu. On AVCHD with menu after last title playback the player stop. |
16th May 2009, 17:41 | #2723 | Link | |
It is supposed to work like that: * When QUIT is not selected: 1) With menu - last title finishes -> go to menu 2) Without menu - last title finishes -> quit/stop. * When QUIT is selected: 1) With menu - last title finishes -> quit/stop 2) Without menu - last title finishes -> quit/stop. Dean |
16th May 2009, 18:07 | #2725 | Link | |
Update to 589.
Build 589: * Fixed forced Quit/Stop if no menu is used * Completely rewritten DVD IFO/Folder import * Full information about DVD titles (#'s and duration) on load * Calculation of total DVD duration * Display of largest title in a DVD input * Fixed IFO import with selecting the largest title * Fixed MP2->AC3 conversion - existing AC3 track (if present) gets overwritten by the newly converted MP2 Dean A note from Ai_em_ron: Quote:
590: If you get any errors in editor tab: use multiUPDATE.exe Last edited by deank; 16th May 2009 at 20:06. |
17th May 2009, 01:01 | #2728 | Link |
Build 591:
* Preview button in Editor tab after you click to edit title name - available only for DVD and FILE media - it won't work if you have old AVCHD or Blu-ray playlists imported. * Preview will show 3x3 (9 thumbnails) extracted from the whole video (DVD playlist/title) * DVD import now fully supported * Full download is updated with the latest BDSup2Sub.jar (3.6.0) Dean @shv: It is fixed in 591. Last edited by deank; 17th May 2009 at 02:20. |
17th May 2009, 11:31 | #2733 | Link |
Dean, the log file is now showing it's encoding the audio as AC3, but I'm still not getting any audio when I play the output files.
[06:16:53] Log started for multiAVCHD v2.7 (build 591) [06:16:56] Track has 2 channels. [06:16:56] Trying to encode AAC audio to AC3... [06:16:56] Encoding (ffmpeg)... [06:16:57] Adding AC3 encoded audio track... [06:16:57] Total of 2 tracks found in this file. Am I doing something wrong? |
17th May 2009, 11:36 | #2734 | Link | |
17th May 2009, 12:19 | #2735 | Link | |
You can't get the sound if you're playing directly the M2TS/MTS files. You need to play the whole AVCHD structure with AVCHD/Blu-ray player. If you have TMT - drag the BDMV folder to it to initiate playback. |
17th May 2009, 17:57 | #2736 | Link |
a few days ago I reported about convert-problems with subtitles from imported VIDEO_TS folders on HDD, ripped from original DVD with 2 language files and 1 german subtitle. The program always got stuck with a certain title while MENCODER tried to extract the subtitle (CPU always at 60%). After 1 hour I had to abort. With version 591 no difference!
Since I wanted this film in the compilation of 5 movies I tried out as follows and it worked: with Subrip extracted the subtitle from each film, added it to the imported (joined) VOB´s in TsmuxeR and exported all as m2TS. These files loaded in multiAVCHD made no problem anymore except 2 errors with Directshow and Mplayer, but only concerning thumbnails in title 3 (see attachments). After closing that message it went on and the final result on BD-RE 25 is completely OK (with subtitles!). Dean, could you say, what causes those messages? And another thing: sometimes after closing multiAVCHD and starting again I get the attached message, but taskmanager doesn´t show that process, and also had it even after restarting the computer. Any idea to that? By the way: the editor preview is GREAT! strad Last edited by strad; 17th May 2009 at 18:06. Reason: correction |
17th May 2009, 18:11 | #2737 | Link |
Dean-this a very unique and useful program-but I have a question. This is the logfile from a conversion that I tried. Evidently tsmuxer doesn't like the files-but here's the odd thing-I tried the same files before and they converted perfectly-I'm thinking that when I tried to update the program something got botched. Any ideas? Thanks.
11:12:04] Log started for multiAVCHD v2.7 (build 581) [11:12:04] Current output mode will include [11:12:04] maximum of 252 titles. [11:12:04] Processing 2 input files/folders. [11:12:04] Strict AVCHD folder mode is enabled... [11:12:04] Converting to BDMV structure (U:\Aria The Natural 1-26\Aria The Natural 01.mkv). [11:12:05] Detected frame reference count: 8 (max:16). [11:12:05] Detected video: ID#1:V_MPEG4/ISO/AVC 712x480, fps=29.970, ref=8 [11:12:05] Detected subtitles: ID#3:S_TEXT/ASS Language: eng [11:12:05] Detected audio: ID#2:A_AC3 (48000Hz 2ch) Language: jap [11:12:05] Added audio: A_AC3, "U:\Aria The Natural 1-26\Aria The Natural 01.mkv", track=2, lang=jap [11:12:05] Extracting SSA subtitle tracks. [11:12:05] Plase wait - it may take a while! [11:12:09] Converting to SRT... [11:12:09] Converting U:\Aria The Natural 1-26\Aria The Natural 01.eng.tid_3.ssa to SRT... [11:12:10] Generating meta file for tsMuxer... [11:12:10] M2TS stream split set at 3999MiB... [11:12:10] Adding subtitles (Aria The Natural 01.eng.tid_3.srt) (und) [11:12:10] Inserting 5 min chapters... [11:12:10] Detected frame reference count: 8 (max:16). [11:12:10] Compliant with L4.1 for 712x480p [11:12:10] Creating clip and playlist info (tsMuxeR)... [11:12:10] Done! [11:12:10] Important files missing (clpi/mpls/m2ts)... [11:12:10] Possible tsMuxer failure to process your input file (U:\Aria The Natural 1-26\Aria The Natural 01.mkv). [11:12:10] M2TS (media) file count: 1 [11:12:10] CLPI (clipinfo) file count: 0 [11:12:10] MPLS (playlist) file count: 0 [11:12:10] Processing playlist files... [11:12:10] Converting to BDMV structure (U:\Aria The Natural 1-26\Aria The Natural 02.mkv). [11:12:11] Detected frame reference count: 8 (max:16). [11:12:11] Detected video: ID#1:V_MPEG4/ISO/AVC 712x480, fps=29.970, ref=8 [11:12:11] Detected subtitles: ID#3:S_TEXT/ASS Language: eng [11:12:11] Detected audio: ID#2:A_AC3 (48000Hz 2ch) Language: jap [11:12:11] Added audio: A_AC3, "U:\Aria The Natural 1-26\Aria The Natural 02.mkv", track=2, lang=jap, timeshift=16ms [11:12:11] Extracting SSA subtitle tracks. [11:12:11] Plase wait - it may take a while! [11:12:18] Converting to SRT... [11:12:18] Converting U:\Aria The Natural 1-26\Aria The Natural 02.eng.tid_3.ssa to SRT... [11:12:18] Generating meta file for tsMuxer... [11:12:18] M2TS stream split set at 3999MiB... [11:12:18] Adding subtitles (Aria The Natural 02.eng.tid_3.srt) (und) [11:12:19] Inserting 5 min chapters... [11:12:19] Detected frame reference count: 8 (max:16). [11:12:19] Compliant with L4.1 for 712x480p [11:12:19] Creating clip and playlist info (tsMuxeR)... [11:12:20] Done! [11:12:20] Important files missing (clpi/mpls/m2ts)... [11:12:20] Possible tsMuxer failure to process your input file (U:\Aria The Natural 1-26\Aria The Natural 02.mkv). [11:12:20] M2TS (media) file count: 1 [11:12:20] CLPI (clipinfo) file count: 0 [11:12:20] MPLS (playlist) file count: 0 [11:12:20] Processing playlist files... [11:12:20] Preparing authoring information... [11:12:20] Creating NTSC top menu. [11:12:20] Authoring menu (NTSC). [11:12:20] Encoding navigational pages... [11:12:26] Setting menu navigation... [11:12:26] Authoring custom menu completed. [11:12:26] Setting menu for 0 titles... [11:12:26] Setting menu properties... [11:12:26] Processing clip (CPI/CLPI) files... [11:12:26] Completed. [11:12:27] Done! [11:12:27] 2 other warnings/errors! [11:12:27] T:\AVCHD_ARIA THE NATURAL folder created! [11:12:27] Burn its CONTENTS to DVD-R/RW UDF 2.50/2.60 disc! [11:12:27] Launching ImgBurn... |
17th May 2009, 18:31 | #2738 | Link |
FinalCut´ter
This programm get´s more and more important for me as tsmuxer meanwhile has broken with my HDV mov files as thy are nor more accepted. Last working version was 1.9.9 ... and now the only way to process my footage is multiAVCHD. But I fear that it also will break with my footage as it has tsmuxer integrated.
