16th April 2010, 13:38 | #342 | Link | |
I've found that Dedup doesn't contribute significantly at all to compression ratio. Last edited by Stephen R. Savage; 16th April 2010 at 13:40. |
16th April 2010, 15:45 | #344 | Link | |
i have a problem about the ffms2.dll from
my script is Code:
loadplugin("C:\Program Files (x86)\AviSynth 2.5\plugins64\ffms2.dll") ffvideosource("E:\Encode\0_2.mkv") crop(0,22,-0,-22) |
16th April 2010, 18:44 | #346 | Link | |
16th April 2010, 21:19 | #347 | Link | ||
The script I used was: Quote:
http://img684.imageshack.us/img684/7910/testjc.png After resizing, the image is noticeably darker: http://img651.imageshack.us/img651/446/shiftcxifb.png This also appears to happen with BicubicResize and LanczosResize, though it is a bit difficult to see with bicubic due to all the blur. Converting to YV12 first does not result in the same problem. |
17th April 2010, 00:00 | #349 | Link |
You've already asked once. If someone has the time and energy they will eventually get to it. But you are currently the only one asking for it. Repeating your request will not make it happen faster, you'll just make people ignore you.
17th April 2010, 01:39 | #351 | Link |
@Stephen
Ah, I know why it happens in both . . . the resize code for RGB is pretty much left stock by myself, just pulled out into an asm file and written for all local register usage. It's never been performance optimized by anyone, to my knowledge. RGB resize doesn't come up that often I guess? Found the problem, as well, I think. I'm uploading a new build for you to run through: Here's the test build. Slowly stepping through the interleave appears to be improved, but the original problem was subtle upon first inspection by my eyes. It's not completely gone . . . 32bit difference map: 64bit difference map: Red means that the pixels are strictly different between adjacent frames of the image stream, using your script in VDub32 and VDub64. As you can see, it's better, but not perfect. I've been playing around with the code seeing how much performance I could eek out of the core . . . let me know if anything breaks before I go update the first post. For the devs, from the 2.58 source directly (and in 2.6 apparently): Code:
// RGB24 is not recommended. 75% of all pixels are not aligned. int y = vi.height; int w = vi.width * 3; int fir_filter_size = pattern_luma[0]; int* pattern_lumaP1 = pattern_luma+1 - fir_filter_size; static const __int64 xFF000000 = 0xFF000000; __asm { push ebx mov esi, srcp mov edi, dstp pxor mm2, mm2 movq mm4, xFF000000 align 16 yloop24: xor ecx, ecx mov edx, pattern_lumaP1 ;cur - fir_filter_size align 16 xloop24: mov eax, fir_filter_size lea edx, [edx+eax*4] ;cur += fir_filter_size mov ebx, [edx] lea ebx, [ebx+ebx*2] ;ebx = ofs = *cur * 3 add edx, 4 ;cur++ pxor mm0, mm0 ;btotal, gtotal pxor mm1, mm1 ;rtota lea edx, [edx+eax*4] ;cur += fir_filter_size add ebx, esi ;ebx = srcp + ofs*3 lea eax, [eax+eax*2] ;eax = a = fir_filter_size*3 align 16 aloop24: sub edx, 4 ;cur-- sub eax, 3 movd mm7, [ebx+eax] ;mm7 = srcp[ofs+a] = 0|0|0|0|x|r|g|b punpcklbw mm7, mm2 ;mm7 = 0x|0r|0g|0b movq mm6, mm7 punpcklwd mm7, mm2 ;mm7 = 00|0g|00|0b punpckhwd mm6, mm2 ;mm6 = 00|0x|00|0r movd mm5, [edx] ;mm5 = 00|co (co = coefficient) packssdw mm5, mm2 punpckldq mm5, mm5 ;mm5 = co|co pmaddwd mm7, mm5 ;mm7 = g*co|b*co pmaddwd mm6, mm5 ;mm6 = x*co|r*co paddd mm0, mm7 paddd mm1, mm6 jnz aloop24 pslld mm0, 2 pslld mm1, 2 ;compensate the fact that FPScale = 16384 packuswb mm0, mm1 ;mm0 = x|_|r|_|g|_|b|_ psrlw mm0, 8 ;mm0 = 0|x|0|r|0|g|0|b packuswb mm0, mm2 ;mm0 = 0|0|0|0|x|r|g|b pslld mm0, 8 psrld mm0, 8 ;mm0 = 0|0|0|0|0|r|g|b movd mm3, [edi+ecx] ;mm3 = 0|0|0|0|x|r|g|b (dst) pand mm3, mm4 ;mm3 = 0|0|0|0|x|0|0|0 (dst) por mm3, mm0 movd [edi+ecx], mm3 add ecx, 3 cmp ecx, w jnz xloop24 add esi, src_pitch add edi, dst_pitch dec y jnz yloop24 emms pop ebx Code:
movd mm5, [edx] ;mm5 = 00|co (co = coefficient) packssdw mm5, mm2 punpckldq mm5, mm5 ;mm5 = co|co Code:
movd mm5, [edx] ;mm5 = 00|co (cocoefficient) pshufw mm5, mm5,0xCCh Last edited by JoshyD; 17th April 2010 at 01:49. |
17th April 2010, 02:21 | #352 | Link |
Good work! Let's hope this update gets included in the main Avisynth trunk. I don't see any red on flat areas anymore, so I'm guessing it's about as fixed as it can get. Out of curiosity, what was the source of the bug?
Also, I hate to pester, but any chance of updating MaskTools to v2.0a37? The changes should be trivial. Edit: Also, what did you use to make the difference map? Edit2: Also, any chance you can port the Average() plugin (or write your own)? Last edited by Stephen R. Savage; 17th April 2010 at 03:44. |
17th April 2010, 03:04 | #353 | Link |
@Stephen
The source of the problem is those two lines of highlighted inline ASM for 2.58, or in my case similar lines of code living in my .asm file of a comparable function. Basically, the resizers are working with an intent of doing the calculation of the new pixel value as a floating point value, and then converting it back to an integer quantity. For this, it's best to adopt some sort of rounding methodology, where I noted above. The rounding value is used in YV12 and YUY2 calculations, it was just omitted from the RGB functions, probably because they're pretty well neglected. The masktools v2.0a37 changes are pretty trivial, I'll see what I can cook up in the next few days. The program I was using is from an image analysis pack called ImageMagick. I'll just go back to their compare function to give some basic statistical analysis of changes I make to speed up the algorithms. Essentially, to weigh speed vs quality. This error was a blatant error and actually was rather trivial to find, I was going to submit a SourceForge bug to the Avisynth guys, but apparently the site is down at the moment. As for average, I'm not getting any hits from the filter collection or the web in general, is this something a) in 2.58 that I didn't port and am totally drawing a blank on b) in 2.6 that can be added c) has the source tucked away in a location you are familiar with d) closed source If it falls under those categories a-c, then probably feasible, I just need to know where to find the basis. If it falls under the dreaded category d (nnedi2!) then well, I can try to recreate it, but ugh, I've been busy. I was considering writing a comparable plugin to nnedi2, but this conversion may be easier in the short term. The busy factor also means I have limited time to set up an RSS feed, document well, etc. The downside of OSS is that it's generally poorly documented . . . I can see why now. Please, if you get a chance, put the posted build through the paces, it has a number of small tweaks which generate a measurable performance difference. I've been playing with a lot of instruction ordering and code size variability, but can only test it with my machine. It may throw up on itself under another environment. This would be good to know in advance to prevent another total mess like last time. Last edited by JoshyD; 17th April 2010 at 03:09. |
17th April 2010, 03:26 | #354 | Link |
Average plugin: http://www.wilbertdijkhof.com/mg262/Average_v11.zip
It's actually very simple. It takes an arbitrary number of clips and weights, then calculates the weighted average (w_a * a + w_b * b + w_c * c [...]). Edit: @Avs developers: Why is the YV12 luma channel centered on 126? @JoshyD: I can't tell a difference between the Y-channel differences for RGB and YUV resizing now. I think this problem is fixed for certain. Good work. Edit2: @JoshyD: Also, what happened to the TCPDeliver/Source plugin that ships with normal Avisynth? Last edited by Stephen R. Savage; 17th April 2010 at 04:30. |
17th April 2010, 22:05 | #358 | Link |
JoshyD: Yeah you can use the benchmark results wherever you want. It was done on an Athlon II 620 at 3.4 ghz. The deadlock didn't display anything, x264.exe was using 25% cpu with no status updates. During the benchmark it seemed to me the goal with avisynth mt is hitting 90%+ CPU with the fewest number of threads with a truly multi-threaded encoder (x264 with fairly fast settings). Deciding between MT() and SetMTMode() seems to be a crap shoot and both may result in a deadlock. With a lot of research and some coding it might be possible to automatically set the optimal setmtmode or mt when it's helpful and works.
Stephen: For update notifications you can get an rss feed from the googlecode download page. |
18th April 2010, 19:42 | #359 | Link | ||
That would be awesome! It would also be nice to have a repository to submit & compare speeds among various filters. This database could be helpful in manually and/or programatically selecting the optimal setting. Last edited by levi; 18th April 2010 at 20:01. |
18th April 2010, 20:31 | #360 | Link |
Derek Prestegard IRL
I'm getting some nasty crashes in virtualdub x64 or x264 x64 when using the 4/12 release on an MDegrain2 script...
setmtmode(2,0) directshowsource("E:\BluRay Rips\Extract\Extract.mkv", audio=false, fps=23.976) assumefps("ntsc_film") spline36resize(1280,720) md2(150,300) distributor Has anyone had luck getting something like this working with the current x64 releases? Thanks ~MiSfit
These are all my personal statements, not those of my employer :) |
