10th May 2011, 18:56 | #11081 | Link |
User of free A/V tools
I don't think eac3to cares about any meta data in general. I'd suggest to try foobar2000 or latest LameXP for such simple conversions.
11th May 2011, 02:18 | #11082 | Link | |
Telewhining
12th May 2011, 13:27 | #11083 | Link |
aac to ac3
probably something that's been discussed a lot before but nothing seems to work for me.
Trying to convert an aac file to ac3 with eac3to and I always get "eac3to Getting "Nero Audio Decoder 2" instance failed" I don't have nero7 installed and I'm not sure I want to install it either or whether it even works on win7 x64. I do have the NeroAAC decoder/encoder pack but am unsure how to make eac3to use it... hope someone can help. |
15th May 2011, 00:32 | #11088 | Link |
Posts: n/a
3: DTS Master Audio, Italian, 1.0 channels, 16 bits, 48kHz (core: DTS, 1.0 channels, 16 bits, 384kbps, 48kHz) [a03] Extracting audio track number 3... [a03] Decoding with DirectShow (Sonic Audio Decoder)... [a03] The WAV writer didn't receive the format information. <ERROR> Aborted at file position 19418609664. <ERROR> |
19th May 2011, 09:20 | #11089 | Link |
Lately I've come across some DTS-HDMA 6.1 tracks which I want to convert to FLAC. The FLAC file however doesn't play right. The length is wrong (2:14:58 instead of 1:57:50) and the sound is distorted in the way that the pitch seems to be way off. Lots of high frequencies and sharpness. Don't know how to describe it properly, but you can hear immediately that it's all wrong. Is this a known bug?
I tried to downmix it to 5.1, but the result is the same - shitty audio. Code:
C:\Program Files (x86)\EAC3TO>eac3to d:\sources\infernalaffairsIII 1) 3:d:\audio \InfernalAffairsIII.flac -down6 M2TS, 1 video track, 3 audio tracks, 3 subtitle tracks, 1:57:50, 24p 1: Chapters, 20 chapters 2: h264/AVC, 1080p24 (16:9) 3: DTS Master Audio, Chinese, 6.1 channels, 16 bits, 48kHz (core: DTS-ES, 6.1 channels, 16 bits, 1509kbps, 48kHz) 4: AC3 EX, Chinese, 5.1 channels, 640kbps, 48kHz 5: AC3 EX, Chinese, 5.1 channels, 640kbps, 48kHz 6: Subtitle (PGS), Chinese 7: Subtitle (PGS), Chinese 8: Subtitle (PGS), English v02 The video framerate is correct, but rather unusual. a03 Extracting audio track number 3... a03 Remapping channels... a03 Decoding with ArcSoft DTS Decoder... a03 Mixing surround channels... a03 Encoding FLAC with libFlac... a03 Creating file "d:\audio\InfernalAffairsIII.flac"... a03 The original audio track has a constant bit depth of 16 bits. a03 The processed audio track has a constant bit depth of 16 bits. Video track 2 contains 169690 frames. eac3to processing took 12 minutes, 26 seconds. Done. |
19th May 2011, 12:41 | #11092 | Link |
I just converted the DTS-HDMA 6.1 track from Infernal Affairs 3 to FLAC 6.1 using Sonic Audio Decoder version 4.3.0.169 and I checked all 6 channels with Audacity. None of them is empty. So it seems that using this version of Sonic Audio Decoder solves the problem I had with Arcsoft decoder version 1.1.0.7. Thanks for the helping hand nautilus7 and TDiTP_.
21st May 2011, 14:04 | #11094 | Link |
Ive lost track again, was there actually one thing which 1.1.0.7 or 1.1.0.8 could do 1.1.0.0 couldnt do, or was there no reason to switch to 1.1.0.7/8 at all, when having 1.1.0.0 working?
21st May 2011, 16:39 | #11095 | Link |
1.1.0.7/1.1.0.8 cannot decode 6.0 properly (results in 5.0), and 1.1.0.7 cannot decode Mono.
1.1.0.0 can decode everything, as far as i am aware.
21st May 2011, 19:17 | #11096 | Link |
alright, no sense to talk about .7 and .8 any further
27th May 2011, 19:21 | #11097 | Link |
Hey madshi, is there any appetite to adding the ability to mux streams together via either Matroska or MP4 (via mp4box)?
HdBrStreamExtractor |
30th May 2011, 02:15 | #11098 | Link | ||||
I wish that were true, I'm a newbie who just wants to rip all my BD audio to .flac, but there's conflicting information in this thread about the limitations of different Arcsoft versions. On page 545 TDiTP_ says
Needless to say I'm confused about which version of Arcsoft I should be using, because if there's a problem with 1.1.0.0 I'd like to know about it before using it for all my encodes :/ |
eac3to |
