Old 26th January 2022, 16:50   #341  |  Link
asarian
I was wondering whether there's way to convert regular Bluray HD to UHD HDR10, using fmtconv? I saw several attempts here, but in all those examples something went wrong. A clean example would be nice.
Gorgeous, delicious, deculture!
asarian is offline   Reply With Quote
Old 18th February 2022, 03:49   #342  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
I'm struggling a bit with some HDR conversions:
Source:
16 bit full range RGB
PQ, BT. 2020
Target:
12 bit limited range YCbCr 4:4:4
PQ, BT. 2020
(for ProRes XQ encoding)
With this script:
import vapoursynth as vs
core = vs.core
source = core.ffms2.Source("flattened_video.mov")
c = source
c = core.fmtc.matrix(source, mat="2100", bits=16)
c = core.fmtc.bitdepth(c, bits=12)
c.set_output()
I get something that's mostly right, but doesn't fully match the source in Resolve. Suggestions?
Blue_MiSfit is online now   Reply With Quote
Old 13th March 2022, 23:47   #343  |  Link
cretindesalpes
cretindesalpes's Avatar
What kind of difference do you have? How could I reproduce your issue in Resolve?
dither 1.28.1 for AviSynth | avstp 1.0.4 for AviSynth development | fmtconv r30 for Vapoursynth & Avs+ | trimx264opt segmented encoding
cretindesalpes is offline   Reply With Quote
Old 11th April 2022, 17:30   #344  |  Link
cretindesalpes
fmtconv r29:
  • Vapoursynth: switched to API v4. Fmtconv now requires Vapoursynth r55 or later, API v3 is not supported anymore.
  • resample: Fixed degnerated cases with invks causing a crash. Thanks to Dogway for the report.
  • resample/Avisynth+: fixed frame property writing when only cplaced is defined, thanks to Dogway for the report.
  • transfer: Added sigmoid curve as a transfer function.
  • transfer: Fixed the float to integer path.
Old 27th April 2022, 02:36   #345  |  Link
Blue_MiSfit
Ok, here's a sample frame:
https://drive.google.com/file/d/1vJg...ew?usp=sharing
Again, this is 16 bit full range RGB in HDR with BT. 2020 primaries and ST. 2084 / PQ transfer. Things have evolved a bit since my last post, and now I want to produce two different types of output:
1) Limited range 4:2:0 10 bit (for HDR10 encoding with HEVC)
2) Limited range 4:4:4 12 bit (for ProRes XQ encoding)
Both seem totally fine if I keep full resolution. However, if I downscale (e.g. to 1080p) I'd like to do the scaling in linear light since this is best practice. When I do, a lot of the higher code values are clipped.
Examples: https://imgur.com/a/1K8iKG3
Good (... I think):
core = vs.core
a = core.ffms2.Source("HDR_Ramp.tif")
#a = a.fmtc.transfer(transs="pq", transd="linear", fulls=True, fulld=True)
a = a.fmtc.resample(w=1920, h=1080)
#a = a.fmtc.transfer(transs="linear", transd="pq", fulls=True, fulld=True)
a = a.fmtc.matrix(mat="2020", fulls=True, fulld=False)
a = a.fmtc.resample(css="420")
a = a.fmtc.bitdepth(bits=10)
a.set_output()
Bad (clipped):
core = vs.core
a.set_output()
Am I doing something wrong? The same pattern holds true if I omit the final resample (keeping 4:4:4) and change bitdepth to 12 to make 4:4:4 12 bit for ProRes XQ.
Old 27th April 2022, 04:48   #346  |  Link
poisondeathray
Originally Posted by Blue_MiSfit View Post
Bad (clipped):
core = vs.core
a.set_output()
Do calcs in 32bit float
a = core.ffms2.Source...
a = a.fmtc.bitdepth(bits=32)
Old 27th April 2022, 06:36   #347  |  Link
Blue_MiSfit
Wow, yeah that totally fixed it.
Why is this necessary? I understand how 32 bit float is certainly more precise than 16 bit integer, but I'd have imagined the differences being a whole lot more subtle than this!
On the off-chance, is it possible to reproduce this filter chain in ffmpeg?
Old 27th April 2022, 18:57   #348  |  Link
poisondeathray
Yes 16bit has higher precision, but 16bit int will still clip to [black,white] or [min,max] , or 0 to 65535 for 16bit code values. "Higher precision" because there are more "steps" described between black to white, but "higher precision" still clips
But the ST2084 PQ to linear transfer function will have values >1 in float ( > 65635 in 16bit) , or "whiter than white"
Yes, using zscale and format=gbrpf32le for float
https://ffmpeg.org/ffmpeg-filters.html#zscale-1
-vf zscale=w=1920:h=1080:transferin=smpte2084:transfer=linear,format=gbrpf32le,zscale=matrix=2020_ncl:transferin=linear:transfer=smpte2084,format=yuv420p10le
Old 27th April 2022, 20:01   #349  |  Link
Blue_MiSfit
Thanks very much for the ffmpeg filter chain! I'll do some testing with that.
Thanks also for the explanation. After I thought about it a bit more this did indeed occur to me
Old 27th April 2022, 23:12   #350  |  Link
Blue_MiSfit
Hmm ok so I had to add a couple of parameters to
a) Identify the input primaries as bt2020
and
b) Specify limited range output
This worked great for a TIF input. The output matches the source in Resolve perfectly:
ffmpeg -i HDR_Ramp.tif -vf zscale=w=1920:h=1080:pin=bt2020:p=bt2020:tin=smpte2084:t=linear,format=gbrpf32le,zscale=m=2020_ncl:tin=linear:t=smpte2084:r=limited,format=yuv420p10le -c:v libx265 -crf 10 reference2.mp4
However, as soon as I swapped over to using the IMF MXF J2K wrapped version of this (same image, just a lossless compressed version of the full range 16 bit RGB TIF), I get the same clipped whites:
ffmpeg -f imf -i .\CPL_FOX-TPS-1MIN-HDR10-ML7_20181105_OV.xml -map 0:v -vf zscale=w=1920:h=1080:pin=bt2020:p=bt2020:tin=smpte2084:t=linear,format=gbrpf32le,zscale=m=2020_ncl:tin=linear:t=smpte2084:r=limited,format=yuv420p10le -c:v libx265 -crf 10 -preset superfast -x265-params keyint=24 -t 1 scale_linear_08.mp4
That clipped white is visible both in MPC-HC and in Resolve.
Both formats seem to insert the same auto scaler from rgb48le to gbrp16le:
[auto_scale_0 @ 00000157ac51b040] picking gbrp16le out of 48 ref:rgb48le alpha:0
[auto_scale_0 @ 00000157ac51b040] w:3840 h:2160 fmt:rgb48le sar:0/1 -> w:3840 h:2160 fmt:gbrp16le sar:0/1 flags:0x0
I tried disabling auto conversion and explicitly adding format=gbrp16le to the head of the filter graph and that errors out:
[format @ 000001f0f4c5ea00] Setting 'pix_fmts' to value 'yuv420p|yuvj420p|yuv422p|yuvj422p|yuv444p|yuvj444p|gbrp|yuv420p10le|yuv422p10le|yuv444p10le|gbrp10le|yuv420p12le|yuv422p12le|yuv444p12le|gbrp12le|gray|gray10le|gray12le'
The filters 'graph 0 input from stream 0:0' and 'Parsed_format_0' do not have a common format and automatic conversion is disabled.
Error reinitializing filters!
Old 28th April 2022, 00:04   #351  |  Link
poisondeathray
and
Interesting, I would have thought that in tif without any flags or metadata, pin=bt2020=bt2020 should be a no-op and do nothing, and that RGB to YUV limited range would be default setting... But you're right, they are required or the proper flags need to be set
But for current ffmpeg behaviour - it appears is the metadata for primaries in the output file isn't written , unless you set it in the zscale arguments, or the encoder settings. The actual video data is unaffected and still a no-op
Color primaries : BT.2020
(I guess it's better to be explicit and check assumptions)
However, as soon as I swapped over to using the IMF MXF J2K wrapped version of this (same image), I get the same clipped whites:
Not sure, there might be other metadata or flags in the imf that overrides some settings or assumptions. what pixel format for the imf ?
You can add -report to the command line and look ath the ffmpeg log for clues
Old 28th April 2022, 03:07   #352  |  Link
Blue_MiSfit
Thanks. It's all still 16 bit full range RGB BT. 2020 / PQ in the IMF.
I'll start a new thread elsewhere about the ffmpeg stuff. Continuing on the VapourSynth track here I realized I'd missed some really nasty halos in the high contrast areas. Forcing kernel=bicubic helped this quite a lot.
Resting the eyes now, hopefully I'll get that sorted tomorrow
Old 11th July 2022, 23:44   #353  |  Link
mastrboy
I have some unexpected behavior when doing 709->601 conversion having to run fmtc_matrix twice to get the expected result when compared to "old" dither based conversion.
I'm updating some of my ancient script and started to move to fmtc from Dither.
On the other hand 601->709 works as expected, the following two snippets create visually similear color output:
PHP Code:
# old method
Dither_convert_8_to_16()
Dither_convert_yuv_to_rgb(matrix="601"output="rgb48y"lsb_in=true)
SelectEvery (30)
SelectEvery (31)
SelectEvery (32)
Dither_convert_rgb_to_yuv (rgbmatrix="709"lsb=falsemode=6)
# new method:
fmtc_resample (css="444")
fmtc_matrix (mats="601"matd="709")
fmtc_resample (css="420")
fmtc_bitdepth (bits=8
But the following 709->601 snippets does not produce the similar results:
PHP Code:
# old method
Dither_convert_yuv_to_rgb(matrix="709"output="rgb48y"lsb_in=true)
SelectEvery (30)
SelectEvery (31)
SelectEvery (32)
Dither_convert_rgb_to_yuv (rgbmatrix="601"lsb=falsemode=6)
# new method:
fmtc_matrix (mats="709"matd="601")
But, if I call fmtc_matrix twice, like "fmtc_matrix (mats="709", matd="601").fmtc_matrix (mats="709", matd="601")" I get similar results to Dither.
What am I doing wrong here with fmtc? Or is it Dither that is wrong?
Edit: Seems the issue is with AVSPmod and not fmtc, after downgrading AVSPmod v2.6.2.8 I'm not able to reproduce this issue anymore. (Seems to be a bug introduced in AVSPmod somewhere between v2.6.2.9 - v2.7.1.3 where it looks like it fetches a cached frame somewhere in the filter pipeline...)
(i have a tendency to drunk post)
mastrboy is offline   Reply With Quote
Old 31st August 2022, 08:06   #354  |  Link
cretindesalpes
fmtconv r30:
  • matrix: The _ColorRange frame property is now set when a matrix preset is used.
  • transfer: Added ACEScct transfer function.
  • primaries: Added DCI P3+ and Cinema Gamut presets.
  • primaries: Added wconv parameter for full conversion.
  • Changed the configure options to compile with Clang.
  • Updated datatypes in the examples.
