23rd February 2017, 17:06 | #21581 | Link |
latencymon
CPU performance wise I think I am like i5 2400(sandy bridge) with the OC but yes,it's pre sandy. I can play 59fps 4k 10bit HEVC 75Mbps with no problem with DXVA2(native) Last edited by Damien147; 23rd February 2017 at 17:12. |
23rd February 2017, 17:30 | #21582 | Link |
Previously it worked only in DXVA mode, if you tried to use it in software mode it failed and playback got stuck. But apparently it got fixed, wonder if Microsoft had to do that in EVR or the GPU drivers managed to do that.
23rd February 2017, 20:35 | #21584 | Link | |
MadVR is generally more heavy internally then EVR-CP though you can optimize it's complexity downwards with it's advanced options system. But a small higher overhead per clock cycle then EVR-CP will always stay especially on the CPU side. Laencymons own pooling overhead though should be allways taken into account it doesn't work for Free and can itself depending on which edge you are impact the overall result You shouldn't give much about the Hard pagefaults look in Latencymons own statistics it creates the most overhead trough to it's Pagefile handling, you most of the times need to run it several times before it's own impact is minimized And it's own pooling and resource usage can also impact the result of it's "Video will run BAD latency wise with crackle and pops result display" Overall LatencyMon is as a 32bit ETW Tracer not really efficient. On Nvidias side Drivers are now very stable the last DPC issue was this https://forum.doom9.org/showpost.php...postcount=1235
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 24th February 2017 at 00:34. |
24th February 2017, 10:42 | #21585 | Link |
Non 10bit HEVC files play smooth with dxva2(copyback).
So to conclude there isn't any solution for the slow on 10bit HEVC dxva2(copyback) in my system?An AMD driver could solve that? Last edited by Damien147; 24th February 2017 at 15:40. |
26th February 2017, 13:15 | #21586 | Link |
What is it so special with this HEVC 8bit clip ?
https://www.sendspace.com/file/4aw5y1 It seems that only LAV Video can decode it in HW. MS decoder fails and PotPlayer falls back to SW decoding.
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all |
26th February 2017, 14:44 | #21587 | Link | |
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
26th February 2017, 18:09 | #21588 | Link | |
28th February 2017, 23:12 | #21593 | Link |
I remember when madshi identified the issue it only applied to Nvidia GPUs, but probably any GPU could spontaneously develop it with a driver update.
madVR options explained |
5th March 2017, 19:06 | #21595 | Link |
Recently mpc-be has been reverting to mpc Audio Decoder (low merit) in some instances. The audio files show up as E-AC-3
ID : 2 Format : E-AC-3 Format/Info : Enhanced Audio Coding 3 Format settings, Endianness : Big Codec ID : A_EAC3 Duration : 57 min 48 s Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 kHz Frame rate : 187.500 FPS (256 spf) Compression mode : Lossy Stream size : 265 MiB (14%) Language : English Default : Yes Forced : No This happened in the past with the MS DTV-DVD Audio Decoder, setting that audio filter to disabled in the mpc-be options disabled it. However this time the MPC Audio Decoder does not display in the available filters to block. The problem is that DTS or DD passthrough does not work when this MPC Audio Decoder is used instead of lav filters. Does lav filters support E-AC-3? I am sure it does as it supports most audio. This might be an mpc-be problem... |
6th March 2017, 08:38 | #21596 | Link |
MPC-BE Audio Decoder support all type passthrough - AC3/E-AC3/DTS/DTS-HD/TrueHD.
6th March 2017, 15:12 | #21597 | Link |
You should disable passthrough for E-AC3. Then LAV Audio will work fine. Your receiver (or sound driver) does not support E-AC3 bitstreaming. LAV Audio decoder does not (yet) have a fallback to normal decoding when passthrough fails.
7th March 2017, 02:06 | #21599 | Link |
I don't know about LAV Audio Decoder - but i know that is possible.
7th March 2017, 08:57 | #21600 | Link |
Just to recap, i made some test at the weekend, and on my systems, h264 is now working without errors on Rx and Fury with the latest Driver (17.2.1)+ Lavfilter with DXVA and CB
Changelog: On some Radeon GCN products DXVA H.264 encoded video may experience corruption when fast forwarding or seeking through content |
