Old 23rd November 2007, 14:28   #1  |  Link
narco220
VobBlanker 2.1.3.0 Preview window problem
Been having problems viewing the video i want to blanke with VobBlanker as the preview window won't show the video.
Its just a blank black window after selecting the PGC and pressing the red play buttom.
Same thing happends when using the prev/cut option it wont show the video??
Anyone have any info on this?
narco220 is offline   Reply With Quote
Old 23rd November 2007, 15:17   #2  |  Link
blutach
Country Member
blutach's Avatar
Have you tried re-installing? Does preview work in other apps such as PgcEdit? If not, check your directx.
Regards
Les
Only use genuine Verbatim or Taiyo Yuden media.
blutach is offline   Reply With Quote
Old 26th November 2007, 12:34   #3  |  Link
narco220
No Preview in PgcEdit I just updated to latest Directx via the microsoft site but still not working???
The preview works fine on dvdshrink
I am running vista by the way
Old 27th November 2007, 13:43   #4  |  Link
zacoz
Posts: n/a
Any change if you go into Settings --> More Settings, and under Previews tick the "Do not use Overlay" option. Don't use Vista myself, but seem to recall some posts around video overlay not being the same or supported or something in Vista.
Old 27th November 2007, 17:41   #5  |  Link
jeanl
jeanl's Avatar
The vobblanker preview (and the pgcedit preview) don't use direct X... But I also seem to remember that there were problems in vista. You should definitely check whether disabling overlay helps...
Jeanl
A few PgcEdit guides.
DVDSubEdit a free tool to edit subtitles directly inside the vob.
jeanl is offline   Reply With Quote
Old 27th November 2007, 21:18   #6  |  Link
narco220
Thanx guys it now works fine after disableing overlay
Old 28th November 2007, 21:14   #7  |  Link
blutach
Country Member
blutach's Avatar
Darn Vista! http://forum.doom9.org/showthread.php?t=119761
Regards
Les
Old 24th September 2020, 15:07   #8  |  Link
dixxfixx
And 13 years later...
Yes, and in Win7. For PgcEdit, you go to the "Preview" menu and turn off overlays.
dixxfixx is offline   Reply With Quote
