8th April 2013, 09:27 | #18261 | Link |
@6233638: Yeah, but it's still ambiguous. If you add a tag like "[gamma=2.40]" then how should madVR know whether you mean the source gamma and the desired display gamma? What's so bad about using the brightness tag instead? I don't really understand why you don't like that...
@turbojet: Finding might be hard if there are multiple video starts in that log file. If it's just video start then it's less of a problem. However, zipping, uploading, downloading, unzipping, editing such a large file is all very painful, of course. |
8th April 2013, 09:30 | #18262 | Link | |
using dscaler mod. It would be great if madVR would do the same as dscaler mod does. My second wish where detection or at least a file tag to crop non anamorphic DVDs. (doing this with the zoom option of the TV degrades Quality). |
8th April 2013, 09:32 | #18263 | Link |
It sounds like a hassle but it happens randomly so logging needs to be on all the time. I'll try to delete the log regularly or maybe script it to be deleted when the video is closed.
It doesn't happen if monitor is set to 48hz but also get the occasional repeated frame then.
PC: FX-8320 GTS250 HTPC: G1610 GTX650 PotPlayer/MPC-BE LAVFilters MadVR-Bicubic75AR/Lanczos4AR/Lanczos4AR LumaSharpen -Strength0.9-Pattern3-Clamp0.1-OffsetBias2.0 Last edited by turbojet; 8th April 2013 at 09:35. |
8th April 2013, 09:39 | #18264 | Link | ||
I prefer to get things correct, rather than what "looks good" so I would rather be able to set 2.20 exactly. And I think that you use 2.20 as the "reference" gamma in madVR, so setting it to 2.20 is equivalent to having gamma correction disabled. Do brightness adjustments correspond to gamma at all? Would +10 brightness be equivalent to -0.10 gamma? (or some other fixed amount) As long as it's explained that you are setting the gamma correction value, I'm not sure why tagging it with [gamma=2.20] or some other value would be confusing. (having a gamma tag mean anything else would be) Quote:
You should be able to do this in your player. Last edited by 6233638; 8th April 2013 at 09:45. |
8th April 2013, 09:57 | #18265 | Link | |
How ? I am using Zoom Player. Would it work without manually switching the aspect ratio ? Last edited by italospain; 8th April 2013 at 09:59. |
8th April 2013, 11:52 | #18266 | Link | |
Kid for Today
You said yourself that FRC wasn't preferable to a plain 24Hz multiple refresh rate, and 24p@24/48/96Hz with Reclock is like an unstoppable train on my rig Well, there's still quite a bunch of ppl on XP: http://www.netmarketshare.com/operat...10&qpcustomd=0 It mostly boils down to laziness to upgrade when everything works just fine as is...as soon as Windows moved to the NT core, upgrades settled down and even after giving away W8 upgrades barely anyone(3% in that previous link) bothered making the (big) jump. I saw all the aforementioned plasma's fed with 1080/50i DVB-T...black level on the 50VT30 was very impressive, though! It's good to read that Pana has moved its R&D to OLED now Last edited by leeperry; 8th April 2013 at 13:00. |
8th April 2013, 12:10 | #18267 | Link | ||
Similarly, the EU models also show 25p/25i/50p video at 100 Hz because 50 Hz flicker is way too noticeable (like the 48 Hz flicker mentioned above). This produces the same "double image" effect if you know how to spot it, but it's still very preferable to flicker. If I understand correctly, LCDs refresh the image differently and don't have any issues showing 50 Hz natively without flicker.
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 Last edited by DragonQ; 8th April 2013 at 14:20. |
8th April 2013, 12:33 | #18268 | Link |
Yea my Panasonic tcp65vt50 has 48/60/96 for 24 and I agree with the above assessment.
Sent from my Xoom using Tapatalk HD
8th April 2013, 12:52 | #18269 | Link | |
madshi, I have a question:
When madVR plays a film on Blu-Ray and it shows "(best guess)" after the matrix and primaries value, does that always mean that madVRīs internal guessing logic (resolution, etc.) comes into play rather than getting that info directly from the stream? Or do you use (best guess) for both cases where you assume the film to be correctly tagged and if it isnīt you would show (best guess) anyway? Quote:
I also donīt like the brightness adjustment. Itīs confusing for people that are accustomed to calibrating/adjusting their displays, who work with gamma values. I would never use a brightness slider to adjust gamma values, not if I donīt have to. I consider the brightness adjustment to be some kind of last resort rather than "how it should be done". The brightness adjustment is more like a "it looks better that way" rather than a "it should look like this by definition" option. If we have content with a native gamma of 2.20 (e.x. that was recorded on a PC or a tv series or camera footage, etc.) that needs to be shown at 2.20, we would have to change the madVR settings every time and this is definately not a good solution. The issue with films, tv series and other content right now is that thereīs just too much stuff around where we need fine control over the provided options, or rather profiles where we could set our desired values taking into account the settings of our calibrated display(s). The good thing about madVR currently is that you have most of these needed options for all our content. I donīt want to go into too much detail, but the most annoying thing about Blu-Rays is that on most of my Blu-Ray collection, the provided parameters (matrix, primaries, etc.) are wrong. A typical example of watching a film that was mastered on Blu-Ray: Yesterday I watched the US Blu-Ray of Conan The Destroyer where madVR assumed BT.709 for everything (it shows best guess). About 15 minutes into the movie I was taken out of it entirely, because Arnold and other actors had sunburn-like fleshtones. After looking closely and comparing between BT.709 and SMPTE-C, the film looks entirely natural with SMPTE-C while it looks totally wrong with BT.709. And thatīs a case that is not rare, I have a lot of such Blu-Rays where BT.709 just was blindly encoded with but the actual content was mastered on SMPTE-C. Even with newer content, this seems to be the case. Itīs freaking me out. Having a brand-new Eizo CG243W with a fresh CCFL and a new panel from 2013 is a good thing (I donīt need to waste too much time for calibration anymore, along with native support of various used frame rates), but itīs painfully revealing (apart from the black levels of course, while 0,08cd/mē after calibration is still respectable for an IPS). |
8th April 2013, 14:07 | #18270 | Link | |
For me I usually see the black frame at least once every hour or so (once every few episodes) but I did not see it tonight. I will check the OSD when it occurs again. |
8th April 2013, 18:17 | #18271 | Link | |
8th April 2013, 20:33 | #18272 | Link | ||
I have never looked at ReClock's icon - I disable tray icons for any application where possible. All I can say is that I have never had to manually set the framerate for files, madVR does not report any dropped frames, and playback is smooth. (I would definitely notice if something was going wrong)
JRiver Media Center will let you tag files to override their aspect ratio. (though the tags could be more user-friendly - it's easiest to manually set one file, and then copy the tags to any others) Quote:
Gamma adjustments are a "calibration" feature, not a "source" feature. An argument could be made for [gamma+0.20] rather than [gamma=2.40] but then that introduces some ambiguity. Is [gamma+0.20] equal to 2.40 gamma always, or would it increase the gamma setting to 2.60 because I have madVR set to 2.40? [gamma=2.40] is less ambiguous, because you are setting the gamma correction in madVR to a specific value. Edit: and on the subject of tags, even more controversially: would it be possible to have a cadence tag? I have just encountered some 1080i content that is initially detected as 4:2:2:2, then after about 10s of playback changes to 2:2, and finally at 25s it properly detects a 3:2 cadence - but there are cadence breaks throughout. While I understand that there is content with mixed cadences and forcing one is potentially a recipe for disaster, I think there are some cases where it is justified. Last edited by 6233638; 8th April 2013 at 21:01. |
8th April 2013, 21:43 | #18273 | Link | ||||||||||||
------- In any case, I've just decided that I'm spending too much time discussing feature requests/suggestions here in the forum. This one post alone took about an hour to write (rewrote several replies etc). Furthermore I've also decided that my to do list is already more than long enough right now. So from now on I'll generally not accept any new feature requests, anymore (the exception proves the rule). That will be my new stance until madVR has reached v1.0. Sorry about that, but I gotta set some priorities if I want to get anywhere. So, for now, no new tags. Feel free to ask again after v1.0. |
8th April 2013, 22:18 | #18275 | Link |
6233638: missed your reply yesterday about aa. Print screen was used, that's wysiwyg right?
madshi: I don't know if this is a limitation or a bug so I'm posting it here instead of the bug tracker. There's a lot of dropped frames when moving between 2 screens with different refresh rates without restarting the player. MadVR status shows the correct display rate but the composition rate is static. A log that starts a video at 48hz, switches to 60hz single display, switch to 48hz primary and 60hz secondary, move to 60hz secondary. Also I've given up on the logging 47.952 changing to 47.952, too much hassle.
PC: FX-8320 GTS250 HTPC: G1610 GTX650 PotPlayer/MPC-BE LAVFilters MadVR-Bicubic75AR/Lanczos4AR/Lanczos4AR LumaSharpen -Strength0.9-Pattern3-Clamp0.1-OffsetBias2.0 |
8th April 2013, 22:40 | #18276 | Link | |
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 |
8th April 2013, 23:12 | #18277 | Link | |||||
BT.709 does not specify a display gamma however. CRT broadcast monitors have a native gamma of approximately 2.40, but some LCD broadcast monitors were set to 2.20 gamma. We now have a spec for display gamma (BT.1886) which uses 2.40 as the reference gamma. (but it also includes compensation for lower contrast displays) So if the content was mastered on an LCD monitor rather than a CRT, OLED, or BT.1886 calibrated display, it can look too dark when displayed at 2.40 gamma. (which this content does) So to match the original intent, you have to change your display to 2.20 gamma. Now there is nothing that specifies "this content was made for 2.20 gamma" - it's just that from working with display calibration for a long time and watching a lot of content, I can see when the content is being displayed wrongly. (rather than it being intent) The reality of the situation is that we're talking semantics. Whether you are changing the "source" gamma or the "display" gamma, as long as it is actually being changed by equal amounts, the resulting image should be the same. But when that gamma correction setting already exists inside madVR, it seems to make a lot more sense to have direct control over it, by being able to override it for certain videos. Quote:
If we assume that the display connected up to the PC has been properly calibrated (monitors should use 2.20 gamma) it is likely going to be set up this way, or using a 3DLUT. (which tries to calibrate the display to 2.20 gamma based on the values you give yCMS) This is all fine so far. But video content is typically designed to be viewed at (or around) 2.40 gamma - based on what a broadcast CRT measures, and the BT.1886 specification. So with my display calibrated to 2.20 gamma, and madVR set up accordingly, I then need to use gamma correction to achieve the correct 2.40 gamma for watching film content: So far, so good. PC content is displayed at 2.20 on the desktop, and video content is displayed at 2.40 - as intended. Note: I am not trying to recommend this setting as a default in madVR (I think someone else did recently) because it will make videos appear darker than other players, and I wouldn't recommend it if the display is not calibrated to actually measure 2.20 first. But there is some content out there which has clearly been mastered on those Broadcast LCDs that were set to 2.20 gamma, so the video looks too dark at the 2.40 setting, and you would either have to disable gamma correction, or set it to 2.20 (in this example, either should give you the same result, but I would prefer to specify 2.20) Even though there are many ways you could go about doing it, I don't think it makes sense to change gamma "at the source", or by changing the display value (the devices > display > calibration value) and it only makes sense to change the "color & gamma" processing value via tags. Anything else is potentially messing with your calibration. I would suggest setting it to an absolute value (e.g. 2.20, 2.35, or 2.40) rather than a relative value (e.g. +0.10, -0.15 etc.) to avoid any confusion. Quote:
I think so. I'm not really sure though, I haven't tried to take screenshots of things with FXAA running. I just know that when FXAA was first implemented in the drivers, there were a lot of people on gaming forums complaining that their favorite screenshot tool took the screenshot before the FXAA processing had been applied. |
8th April 2013, 23:40 | #18278 | Link |
Those who have 72hz displays what does madvr status say for 1 frame repeat/drop every?
For me, it says 1 drop every 4-6 minutes, which doesn't sound right. At 48/60/50/75hz it says 1 repeat every 2-6 days. Trying to figure out if there's anything wrong and if so is it the display or madvr.
9th April 2013, 04:15 | #18279 | Link |
Broadband Junkie
madVR repeat/drop every is a function of your refresh rate and clock deviation.
By default, my untweaked 72.05Hz refresh rate which my NVIDIA card defaulted to, had madVR reporting a repeat every 42 seconds. This is of course normal, because it was too far off the mark. I did a test just now with a 71.928Hz refresh rate tweaked for my clock deviation, and madVR now overflows the maximum of 6.07 days and reports "Repeat every 1.#J days". And this is without using Reclock. Don't underestimate that extreme floating-point accuracy you need in your refresh rate matched to your clock deviation, in order to avoid any drops/repeats without Reclock. |
9th April 2013, 05:57 | #18280 | Link |
Closest to 71.928 I can get is 71.916 or 71.955. The same sort of hole around 47.952, both give drop\repeat <5 minutes. 48.0002 works fine with reclock but there's a little flicker. 72.0001 drop <1 minute and according to reclock its 60hz. Guess I'll stay with 48hz+reclock. The native 60hz is a bit off at 59.86906 and it drops frames about every minute. Changing it to 60.0001 with CRU works great but after CRU is used madvr's display changer doesn't work anymore. Reclock runevent.vbs can change it with nircmd after CRU but then there's an issue with display and composition no longer matching in madvr, same as multiple display issue I mentioned earlier.
PC: FX-8320 GTS250 HTPC: G1610 GTX650 PotPlayer/MPC-BE LAVFilters MadVR-Bicubic75AR/Lanczos4AR/Lanczos4AR LumaSharpen -Strength0.9-Pattern3-Clamp0.1-OffsetBias2.0 Last edited by turbojet; 9th April 2013 at 06:02. |
