19th September 2018, 17:32 | #52501 | Link |
there is no such thing as max settings, there are too many variables, it will be the best performer, thats all that can be said,
LG OLED EF950-YAM RX-V685-RYZEN 3600 - 16GBRAM - WIN10 RX 5700 - https://www.videohelp.com/software/madVR/old-versions |
19th September 2018, 17:33 | #52502 | Link |
@Siso & @madhi
Nvidia control panel > display > change resolution : My TV has desktop color depth, output color depth, output color format, output dynamic range connected with HDMI and OSD shows the information as stated in the changelog, but my other monitor which is connected with DVI and only shows desktop color depth shows refresh rate only on the OSD like the screenshot from Siso. |
19th September 2018, 17:34 | #52503 | Link |
Yes, DVDFab Media Player. I use it flawlessly for when I desire menus and it looks pretty good but prefer MPC players with madVR for main movie playback.
HOW TO-Kodi 2D-3D-UHD (4k) HDR Guide Internal & External Players W11 Pro 24H2 GTX960-4GB RGB 4:4:4 @Matched Refresh Rates 8,10,12bit KODI 22 MPC-HC/BE 82" Q90R Denon S720W |
19th September 2018, 17:35 | #52504 | Link | |
Soul Seeker
19th September 2018, 18:08 | #52507 | Link |
I've been using madVR v0.92.14 with no problems. I just installed the new madVR v0.92.15 released today carrying over settings from v0.92.14. MPC-HC starts with a black screen and no OSD. I assume it is paused which it is and I press play even though there is no OSD. My display flashes into HDR mode. Audio begins and the picture is frozen on a single frame. If I navigate forward or reverse, the movie begins to play normally. So I start with MPC-BE instead and none of this funny business occurs. It just starts and plays like it should. Both MPC players use identical settings. I'm using the latest current nightly builds of each. Both players performed as expected before upgrading to v.0.92.15 fwiw.
HOW TO-Kodi 2D-3D-UHD (4k) HDR Guide Internal & External Players W11 Pro 24H2 GTX960-4GB RGB 4:4:4 @Matched Refresh Rates 8,10,12bit KODI 22 MPC-HC/BE 82" Q90R Denon S720W Last edited by brazen1; 19th September 2018 at 18:12. |
19th September 2018, 19:29 | #52509 | Link | |
cosmic entity
i guess i have the same problem... i see just the normal OSD stuff nothing new.. made a clean madvr install. tested on 2 monitors, one with DVI - and one with VGA..(yes one monitor still has VGA) and this is what i see: dont mind my shaders down there..haha Is there a screenshot somewhere to see how its supposed to look? greetz |
19th September 2018, 19:33 | #52510 | Link |
Good blind shot reco. Changed D3D11/automatic native to DXVA 2 copy back/my nvidia GPU. With MPC-HC video starts paused and pressing play it begins and all is well. Still, shouldn't start paused.
Will there be anything detrimental going from D3D11 to copyback considering my collection uses just about every various format and container offered SDR, HDR, 3D, 8 & 10bit, FSE for 3D and FS windowed for all others. Btw, thanks for the suggestion.
19th September 2018, 19:39 | #52511 | Link |
I have reported this already a while ago but you said back then that you had not the time to look more into it.
Setup: MPC-BE + LAV + MadVR playing a SD-file. Problem: With SD activated in LAV Video the image is displayed only for a few seconds then the image turns completely green. The video keeps playing and I can hear the sound. (I first mentioned that to Nev but he said that is most likely a MadVR issue). Thanks for the new version !! |
19th September 2018, 19:48 | #52512 | Link |
whats the reason for an option to use NGU with some added grain for taking screenshots? or why is this the default choice?
Laptop Lenovo Legion 5 17IMH05: i5-10300H, 16 GB Ram, NVIDIA GTX 1650 Ti (+ Intel UHD 630), Windows 10 x64, madVR (x64), MPC-HC (x64), LAV Filter (x64), XySubfilter (x64) (K-lite codec pack) Last edited by Thunderbolt8; 19th September 2018 at 19:51. |
19th September 2018, 19:52 | #52513 | Link |
new version of MADVR has fixed the 23,076 playback issue with MPC-HC, no longer hangs with black screen, wierd but great !
unfortunately I was hoping that maybe a combination of new AMD drivers and new MADVR would fix the blown out reds issue with AMD 23hz SDR playback, this really needs fixing, had this for months now with 3 different AMD cards and muliple sets of drivers and LAV / MADVR versions. https://1drv.ms/u/s!AgvFafeelEBigP8JoUs9wKjRu8Ajjw Just a reminder of the issue. all 23,976 playback of any SDR material has blown out reds as shown in picture, but only with MADVR renderer. • If If I turn off refresh rate switching and play in 60hz the problem goes away • if I put my TV in PC mode the problem goes away (bluray mode used for access to TV processing) • if I turn off use DIRECT3D for presentation in MADVR the problem goes • if If set calibration to BT2020 in MADVR the problem goes away • HDR material plays fine. surely the way this problem manifests itself must ring a bell for someone?
19th September 2018, 19:58 | #52514 | Link | |
i was getting this on the old version as well though, must be a bug with HC on a windows update or something, had this for a while now.
19th September 2018, 19:59 | #52515 | Link | |
Intel i5 6600, 16 GB DDR4, AMD Vega RX56 8 GB, Windows 10 x64, Kodi DS Player 17.6, MadVR (x64), LAV Filters (x64), XySubfilter .746 (x64) LG 4K OLED (65C8D), Denon X-4200 AVR, Dali Zensor 5.1 Set |
19th September 2018, 20:05 | #52516 | Link |
all movies mate, its pretty obvious when you play the movie, phantom menace about 33 mins, it may only happen with setups very similar to mine though, see my SIG.
19th September 2018, 20:12 | #52517 | Link | |
19th September 2018, 21:37 | #52520 | Link |
madshi, ever since updating to Windows 10 version 1803 I've been having an issue with madVR where my render queues seem "capped" in some way, maybe by GPU memory usage, and trying to use the more expensive algorithms leads to queues not filling up at all even though the render time is very low. I have a GeForce GTX 1080 and I never had problems before updating to Windows 10 version 1803, so I think Microsoft added some sort of new limitation.
I was briefly able to work around it by using FSE mode, but then that stopped working too, so I've fallen back to using extremely simple algorithms that don't hit the cap (even super-xbr is affected). I was hoping that new drivers or windows updates would fix the problem, but no luck so far. Unfortunately the new build of madvr doesn't fix it either. Let me know if there's anything I can do to help debug the issue.
Test patterns: Grayscale yuv444p16le perceptually spaced gradient v2.1 (8-bit version), Multicolor yuv444p16le perceptually spaced gradient v2.1 (8-bit version) |
