21st August 2007, 12:42 | #641 | Link |
Has the "File size of the raw file doesn't fit" problem been solved yet? I get that problem on 3 different pcs and other than running on Windows XP they dont have anything in common. One has Nero 7.10 installed, the other 7.8.5 so i doubt they both suffer from a bad Nero install. And one doesnt have the mention dtsac3source filter installed so that cant be it either.
21st August 2007, 13:47 | #643 | Link | |
21st August 2007, 14:36 | #645 | Link | |
I'm not sure, but probably you need the Blu-Ray/HD DVD plugin? Originally I thought you don't need it for E-AC3 decoding. But right now I guess you do. |
21st August 2007, 17:19 | #646 | Link | |
21st August 2007, 18:49 | #647 | Link | |
@madshi From what I know, TrueHD in Blu-ray contains DD 5.1 640K core. And, just like DTS-HD, you have to handle sync word emulation very carefully to avoid the incorrect length of extracted AC3. I wrote a tool to extract the DD 5.1 core from Blu-ray TrueHD, and tested on 3 BDs without any problem. I'll send the source code to you so you can merge into eac3to. |
21st August 2007, 19:09 | #649 | Link | |
I think I was careful about the sync word stuff etc. I'm checking for the signature and I'm only accepting frames with a valid CRC. Every AC3 frame should have a valid CRC. Because of that valid AC3 frames should be easy to identify. I think it's more difficult with DTS. There CRC is optional and rarely used, as far as I know. Anyway, I'll compare your source code to mine and check if I can find significant differences... |
21st August 2007, 20:48 | #650 | Link | |
Thanks! |
22nd August 2007, 04:02 | #651 | Link |
Here is my DDCore executable.
http://www.sendspace.com/file/h1thbq Usage: DDCore source.thd dest.ac3 It ONLY works on TrueHD from Blu-ray! |
22nd August 2007, 05:17 | #652 | Link | |
22nd August 2007, 08:38 | #653 | Link | |
22nd August 2007, 10:46 | #655 | Link |
i just tried ddcore on a thd track out of Vacancy BR disc and it works very well and fast
seemed to got the same result from eac3to aswell, if not faster heh, and correct times on both. Last edited by woah!; 22nd August 2007 at 10:50. |
26th August 2007, 17:58 | #659 | Link | |
27th August 2007, 21:41 | #660 | Link |
eac3to v1.14 released
http://madshi.net/eac3to.zip Code:
(1) DTS dialog normalization can be removed now (2) DTS core can be extracted from DTS-HD track now Usage: eac3to source.dts dest.dts I've tested the new DTS core extraction on all my HD DVD and Blu-Ray movies with such tracks. The tracks were demuxed by EvoDemux (for HD DVDs) and xport (for Blu-Rays). eac3to reported all tracks to be clean - except the "Perfume" tracks. This problem has been reported before. For whatever reason the "Perfume" DTS-HD tracks demuxed by EvoDemux are corrupt. Well, eac3to detects that, which is good. So, if eac3to doesn't complain you can feel safe that everything is fine. One important thing to note: The current version of the "DTS/AC3/DD+" filter plays all DTS(-HD) streams from Blu-Ray and HD DVD incorrectly. Basically as soon as you seek, audio sync is lost. I've fixed the problem in the filter and uploaded a new version here: http://madshi.net/dtsac3source.zip This is not a unicode build, though, so it might not work with DTS/AC3/DD+ files in folders with "strange" file names. I hope we'll get a unicode build from orbitlee or Casimir later. Another way to work around the DTS/AC3/DD+ filter problem is to mux the HD DVD and Blu-Ray DTS (core) tracks into a container, e.g. MKV or TS. That way the sync problems with seeking should also disappear. |
eac3to |
