16th September 2008, 08:02 | #961 | Link | |
- All work on avisynth is done on a volunteer basis - Most programmers have full-time jobs - Some programmers even have families (so I've heard) There's three reasons off the top of my head that I find a lot more believable (and less offensive) than your thinly veiled accusation of laziness. |
22nd September 2008, 10:49 | #964 | Link |
Didée 4 President
hi there,
I've never managed to get SetMTMode() working in ffdshow, but apparently that's because I need to use ffdshow_source() after using it....as it needs to be the first line of the script or it won't work. anyone knows why it says "invalid arguments to function LSF" please ? Code:
SetMtmode(1,4) source=ffdshow_source() LimitedSharpenFaster(ss_x=1.0,ss_y=1.0,strength=40) Distributor() this works perfectly fine : Code:
MT("LimitedSharpenFaster(ss_x=1.0,ss_y=1.0,strength=40)",4) Last edited by pitch.fr; 23rd September 2008 at 09:21. |
22nd September 2008, 11:22 | #966 | Link |
Didée 4 President
great, thanks for the fast reply!
and what should I replace it by to do benchmarks in VirtualDub ? it crashes if I remove ffdshow_source(), and If I also remove Distributor() it's single threaded. I'd like to see whether it's faster than MT() here's my test script for benchmarks in VDUB, that IanB gave me : Code:
SetMemoryMax(512) # Adjust value as required ColorBars(1280, 720, pixel_type="YV12") # Size and pixel type as appropriate # Insert Code under test here SetMtmode(2,4) LimitedSharpenFaster(ss_x=1.0,ss_y=1.0,strength=40) Distributor() # Throw away most of the image we are not testing VD's i/o Crop(0, 0, 16, 16) Last edited by pitch.fr; 23rd September 2008 at 09:21. |
24th September 2008, 01:45 | #967 | Link | ||
hi there
I have an Intel(R) Core(TM)2 Quad CPU and I am trying to apply this filter to my AVS script Quote:
and MT.dll to my AVS plugin have I done something wrong?? thanks in advance |
24th September 2008, 09:00 | #969 | Link | |
sorry if I misunderstood the 1st post, but after seeing some people's scripts, I come up with this one.
Please tell me what I am missing. |
24th September 2008, 11:08 | #970 | Link |
likes to tinker
Look a bit closer at them You're thinking of SetMTmode, not MT ... RTFM means read the forgoodnessake manual. Don't forget to "install" the modified avisynth. Take a look at the parameters for MT - you're missing the critical one.
See Wiki info at http://avisynth.org/mediawiki/MT_support_page and http://avisynth.org/mediawiki/MT_modes_explained Last edited by halsboss; 24th September 2008 at 11:16. |
25th September 2008, 00:00 | #971 | Link | |
thanks halsboss...
I don't an error with this one Quote:
but it gives me the same speed whether I use it or I don't. sorry for that guys. |
25th September 2008, 12:14 | #972 | Link |
likes to tinker
You're using a combination of MT mode 2 and MT ... if your source interlaced ? I suggest you have a look at the examples again and the text that goes with them. You should get a lot better than "the same".
27th September 2008, 11:24 | #973 | Link |
If I load my plugins and then
setmtmode(2,0) and then load my video and filters (other than builtin, the only ones i use are dfttest and shockwave, both of which are sloooow). There is no problem, cpu loading on my four cores is 95%+ and speed is 90% frames encoded in real time as long as i am not exceeding D1 resolution. If i go to double D1 resolution using EEDI2 or tdeint, the encode crashes at completion or does not load. I need to change it to setmode(5,0) to avoid that. Only about 40 to 45% of the cores are used and encoding is about 1/6th frames in real time. On a hunch, tried to use setmtmode (2,0) to start and put setmode(5,0) just before resizing(which i do at the end). success! no crash, cpu loading 95%+ and encoding speed was half the frames in real time.
A shut mouth gathers no foot Last edited by mgh; 27th September 2008 at 12:33. Reason: managed to say opposite of what i meant |
27th September 2008, 12:59 | #974 | Link |
likes to tinker
IIRC setMTmode needs to be 5 before the file open mpeg2source, and then changed after or bad things can happen. I'm sure there's posts on it somewhere. I've used TDEINT no worries although I use the "other" resizing method now.
1st October 2008, 17:48 | #975 | Link |
did more trials
setmtmode(2,0) before loading the video file works where final encoded resolution is at the most 720x480 (NTSC DVD), also works with vcds blown up to double the resolution. setmtmode(5,0) before loading the video file and setmtmode(2) afterwards works for higher encoded resolution (including PAL DVD 720x576!) with my quad 2400 Mhz 2GB RAM XP SP2
A shut mouth gathers no foot |
17th October 2008, 03:52 | #976 | Link |
tsp can be shed more light about Script Clip and in regards to MT?
Offtopic: which other known avisynth plugins use scriptclip functionality? ... ... Reason I am asking about this coz I was running into errors with SRestore when using with MT: Thanks in advance Last edited by superuser; 17th October 2008 at 06:40. |
24th October 2008, 08:51 | #977 | Link |
Robert
TSP or anyone else in the know
I tried using the following settings and I do not think Ive done it correctly. Does the below look right? I have an AMD Athlon(tm) Dual Core Processor 4200+ 2.20GHz Im peaking at about 4.73fps, I know that fftd3filter is not fast by nature. SetMTMode(2,0) DGDecode_mpeg2source("C:\VTS_08_1.d2v",info=3) ColorMatrix(hints=true) crop( 8, 64, -8, -64) MT("YToUV(fft3dfilter(sigma=3, plane=1).UToY,\ fft3dfilter(sigma=3, plane=2).VToY,\ fft3dfilter(sigma=2, plane=0)) FFT3DFilter(bt=-1, sharpen=0.8) fastlinedarkenmod(thinning=0, strength=25)") not using the MT filter I peak at about 5.15fps like this.. DGDecode_mpeg2source("C:\VTS_08_1.d2v",info=3) ColorMatrix(hints=true) crop( 8, 64, -8, -64) YToUV(fft3dfilter(sigma=3, plane=1).UToY,\ fft3dfilter(sigma=3, plane=2).VToY,\ fft3dfilter(sigma=2, plane=0)) FFT3DFilter(bt=-1, sharpen=0.8) fastlinedarkenmod(thinning=0, strength=25) not sure what im doing wrong or if Im even using the fft3filter optimally. thanks guys, your knowledge is valued. |
24th October 2008, 09:25 | #978 | Link |
Robert
SetMTMode(2,0)
DGDecode_mpeg2source("C:\Users\Baba-Nator\Desktop\Movies\Zoolander\VTS_08_1.d2v",info=3) ColorMatrix(hints=true) crop( 8, 64, -8, -64) MT("fft3dfilter(sigma=3, sigma2=5, sigma3=10, sigma4=20, plane=0, bt=3, bw=16, bh=16, ow=8, oh=8, sharpen=0.3, smin=20, smax=1000, wintype=2, kratio=1.0, measure=true, interlaced=false, degrid=1)") This way gets 5.65fps DGDecode_mpeg2source("C:\Users\Baba-Nator\Desktop\Movies\Zoolander\VTS_08_1.d2v",info=3) ColorMatrix(hints=true) crop( 8, 64, -8, -64) fft3dfilter(sigma=3, sigma2=5, sigma3=10, sigma4=20, plane=0, bt=3, bw=16, bh=16, ow=8, oh=8, sharpen=0.3, smin=20, smax=1000, wintype=2, kratio=1.0, measure=true, interlaced=false, degrid=1) This way gets 6.06 fps |
24th October 2008, 16:40 | #979 | Link |
Fighting spam with a fish
Pick one or the other here. You are using both SetMTmode and MT. My guess is that you only want to thread fft3dfilter here, especially since the other filters are already fast enough. So just us MT and see if that fixes it. Remove your "SetMTMode(2,0)" line.
