Old 15th January 2011, 00:44   #10961  |  Link
jdobbs
Originally Posted by Capsbackup View Post
The test BD-RB file did not correct the audio out of sync problem on the movie Case 39.
The audio is ahead of the video. The original 00270mpls for these 18 scenes, VID_00016 to VID_00033, reports a total time of 00:30:06, and the BD-RB backup reports 00:37:37, the same as before.
I am not sure if this helps, but if I run DGAVCIndex on the BD-RB backup 00016.m2ts file, it reports 29.970fps.
If I run DGAVCIndex on the VID_00016.AVS.264, it reports 37.462537fps.
Let me know what else I can provide that may be of help.
Can you give me some hints as to how I can make this happen? Can you post your INI file? I've run this several times with IVTC enabled -- and the runs have all been in-sync on the extras. IVTC is taking place -- and as far as I can see so far it should...
Website: www.jdobbs.net
Old 15th January 2011, 02:07   #10962  |  Link
cnote
cnote
Apparently something was changed for your decoding AVC video. Can you play the VID_00011.avs file BD-RB created in the Workfiles folder with MPC?
Usually a simple uninstall of Haali and ffdshow and then reinstall them will fix this.
I reinstalled both and it worked. I really appreciate that Caps!
cnote is offline   Reply With Quote
Old 15th January 2011, 05:06   #10963  |  Link
Capsbackup
The only extras that were out of sync were the Deleted Scenes, which are VID_00016 to VID_00033.
I have deleted the previous files, but from my previous post is below. I had selected IVTC sources with 3:2 pulldown and Use DECOMB filter on Interlaced sources.
I can run it again though if necessary.
Running it now, will post when complete.
[Options]
MIN_M2TS_SIZE=100
KEEP_MBTREE=1
MODE=0
ENCODE_QUALITY=1
ONEPASS_ENCODING=2
AUTO_QUALITY=0
QUICK_EXTRAS=0
TARGET_SIZE=4500
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=all
SD_CONVERT=0
COLOR_BOOST=0
RESIZE_1080=0
DEINTERLACE=1
DTS_REENCODE=1
AC3_REENCODE=1
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=0
AVCHD=0
REMOVE_WORKFILES=0
FULL_AVCHD=0
AUDIO_TRACK_LIMIT=1
SUBTITLE_TRACK_LIMIT=1
CUSTOM_TARGET_SIZE=8400
REMOVE_OUTPUT=0
OPEN_GOP=1
USE_FILTERS=0
MOVIE_ONLY_LOOP=1
BDMV_CERT_ONLY=1
USE_LAVF=0
IVTC_PULLDOWN=1
VERSION=0.37.0.2
ASSUME_DVD_PAL=0
SD_TO_1080=0
CONVERT_WIDE=0
[Paths]
SOURCE_PATH=G:\BD RIPS\CASE_39_AC\
WORKING_PATH=G:\CASE_39 BDRB TEST\
[07:54:07] BD Rebuilder v0.37.02 (beta)
  - Source:  CASE_39_AC
  - Input BD size: 35.49 GB
  - Approximate total content: [02:44:02.565]
  - Target BD size: 8.20 GB
  - Windows Version: 6.1 [7600]
  - SHUTDOWN at completion enabled
  - Quality: Better (Faster), ABR
  - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640
[07:54:07] PHASE ONE, Encoding
 - [07:54:07] Extracting A/V streams [VID_00000]
 - [07:54:10] Reencoding: VID_00000 (1 of 29)
 - [07:54:10] Collecting video information
   - Source Video: VC-1, 1920x1080
   - Rate/Length: 23.976fps, 357 frames
   - Bitrate: 5,375 Kbs
 - [07:54:10] Reencoding: VID_00000, Pass 1 of 1
 - [07:54:25] Video Encode complete
 - [07:54:25] Reencoding audio tracks (if req'd)
 - [07:54:26] Multiplexing M2TS
 - [07:54:26] Extracting A/V streams [VID_00001]
 - [07:54:31] Reencoding: VID_00001 (2 of 29)
 - [07:54:31] Collecting video information
   - Rate/Length: 23.976fps, 1,080 frames
   - Bitrate: 4,040 Kbs
 - [07:54:31] Reencoding: VID_00001, Pass 1 of 1
 - [07:55:05] Video Encode complete
 - [07:55:05] Reencoding audio tracks (if req'd)
 - [07:55:05] Multiplexing M2TS
 - [07:55:07] Extracting A/V streams [VID_00002]
 - [07:55:09] Reencoding: VID_00002 (3 of 29)
 - [07:55:09] Collecting video information
 - [07:55:09] Reencoding: VID_00002, Pass 1 of 1
 - [07:55:24] Video Encode complete
 - [07:55:24] Reencoding audio tracks (if req'd)
 - [07:55:25] Multiplexing M2TS
 - [07:55:25] Extracting A/V streams [VID_00003]
 - [07:55:29] Reencoding: VID_00003 (4 of 29)
 - [07:55:29] Collecting video information
 - [07:55:29] Reencoding: VID_00003, Pass 1 of 1
 - [07:55:43] Video Encode complete
 - [07:55:43] Reencoding audio tracks (if req'd)
 - [07:55:44] Multiplexing M2TS
 - [07:55:45] Extracting A/V streams [VID_00005]
 - [07:55:49] Reencoding: VID_00005 (5 of 29)
 - [07:55:49] Collecting video information
   - Rate/Length: 23.976fps, 959 frames
 - [07:55:49] Reencoding: VID_00005, Pass 1 of 1
 - [07:56:13] Video Encode complete
 - [07:56:13] Reencoding audio tracks (if req'd)
 - [07:56:13] Multiplexing M2TS
 - [07:56:15] Extracting A/V streams [VID_00006]
 - [07:56:24] Reencoding: VID_00006 (6 of 29)
 - [07:56:24] Collecting video information
   - Source Video: MPEG-2, 720x480
   - Rate/Length: 29.970fps, 7,983 frames
   - Bitrate: 902 Kbs
 - [07:56:24] Reencoding: VID_00006, Pass 1 of 1
 - [07:57:20] Video Encode complete
 - [07:57:20] Reencoding audio tracks (if req'd)
 - [07:57:21] Multiplexing M2TS
 - [07:57:22] Extracting A/V streams [VID_00015]
 - [08:17:18] Reencoding: VID_00015 (7 of 29)
 - [08:17:18] Collecting video information
   - Rate/Length: 23.976fps, 157,417 frames
   - Bitrate: 8,455 Kbs
 - [08:17:18] Reencoding: VID_00015, Pass 1 of 1
 - [10:18:51] Video Encode complete
 - [10:18:51] Reencoding audio tracks (if req'd)
 - [10:22:04] Multiplexing M2TS
 - [10:26:08] Extracting A/V streams [VID_00016]
 - [10:26:10] Reencoding: VID_00016 (8 of 29)
 - [10:26:10] Collecting video information
   - Rate/Length: 29.970fps, 1,494 frames
   - Inverse Telecining in effect (IVTC)
   - Bitrate: 889 Kbs
 - [10:26:10] Reencoding: VID_00016, Pass 1 of 1
 - [10:26:18] Video Encode complete
 - [10:26:18] Reencoding audio tracks (if req'd)
 - [10:26:18] Multiplexing M2TS
 - [10:26:19] Extracting A/V streams [VID_00017]
 - [10:26:21] Reencoding: VID_00017 (9 of 29)
 - [10:26:21] Collecting video information
   - Rate/Length: 29.970fps, 1,684 frames
   - Bitrate: 867 Kbs
 - [10:26:21] Reencoding: VID_00017, Pass 1 of 1
 - [10:26:30] Video Encode complete
 - [10:26:30] Reencoding audio tracks (if req'd)
 - [10:26:30] Multiplexing M2TS
 - [10:26:31] Extracting A/V streams [VID_00018]
 - [10:26:33] Reencoding: VID_00018 (10 of 29)
 - [10:26:33] Collecting video information
   - Rate/Length: 29.970fps, 1,844 frames
   - Bitrate: 860 Kbs
 - [10:26:33] Reencoding: VID_00018, Pass 1 of 1
 - [10:26:42] Video Encode complete
 - [10:26:42] Reencoding audio tracks (if req'd)
 - [10:26:43] Multiplexing M2TS
 - [10:26:44] Extracting A/V streams [VID_00019]
 - [10:26:45] Reencoding: VID_00019 (11 of 29)
 - [10:26:45] Collecting video information
   - Rate/Length: 29.970fps, 958 frames
   - Bitrate: 904 Kbs
 - [10:26:45] Reencoding: VID_00019, Pass 1 of 1
 - [10:26:50] Video Encode complete
 - [10:26:50] Reencoding audio tracks (if req'd)
 - [10:26:50] Multiplexing M2TS
 - [10:26:51] Extracting A/V streams [VID_00020]
 - [10:26:53] Reencoding: VID_00020 (12 of 29)
 - [10:26:53] Collecting video information
   - Bitrate: 892 Kbs
 - [10:26:53] Reencoding: VID_00020, Pass 1 of 1
 - [10:27:03] Video Encode complete
 - [10:27:03] Reencoding audio tracks (if req'd)
 - [10:27:03] Multiplexing M2TS
 - [10:27:04] Extracting A/V streams [VID_00021]
 - [10:27:10] Reencoding: VID_00021 (13 of 29)
 - [10:27:10] Collecting video information
   - Rate/Length: 29.970fps, 5,309 frames
   - Bitrate: 860 Kbs
 - [10:27:10] Reencoding: VID_00021, Pass 1 of 1
 - [10:27:35] Video Encode complete
 - [10:27:35] Reencoding audio tracks (if req'd)
 - [10:27:36] Multiplexing M2TS
 - [10:27:37] Extracting A/V streams [VID_00022]
 - [10:27:39] Reencoding: VID_00022 (14 of 29)
 - [10:27:39] Collecting video information
   - Rate/Length: 29.970fps, 1,500 frames
   - Bitrate: 894 Kbs
 - [10:27:39] Reencoding: VID_00022, Pass 1 of 1
 - [10:27:46] Video Encode complete
 - [10:27:46] Reencoding audio tracks (if req'd)
 - [10:27:47] Multiplexing M2TS
 - [10:27:47] Extracting A/V streams [VID_00023]
 - [10:27:50] Reencoding: VID_00023 (15 of 29)
 - [10:27:50] Collecting video information
   - Rate/Length: 29.970fps, 2,047 frames
   - Bitrate: 910 Kbs
 - [10:27:50] Reencoding: VID_00023, Pass 1 of 1
 - [10:28:00] Video Encode complete
 - [10:28:00] Reencoding audio tracks (if req'd)
 - [10:28:01] Multiplexing M2TS
 - [10:28:02] Extracting A/V streams [VID_00024]
 - [10:28:06] Reencoding: VID_00024 (16 of 29)
 - [10:28:06] Collecting video information
   - Rate/Length: 29.970fps, 3,585 frames
   - Bitrate: 892 Kbs
 - [10:28:06] Reencoding: VID_00024, Pass 1 of 1
 - [10:28:24] Video Encode complete
 - [10:28:24] Reencoding audio tracks (if req'd)
 - [10:28:25] Multiplexing M2TS
 - [10:28:26] Extracting A/V streams [VID_00025]
 - [10:28:30] Reencoding: VID_00025 (17 of 29)
 - [10:28:30] Collecting video information
   - Rate/Length: 29.970fps, 4,195 frames
   - Bitrate: 856 Kbs
 - [10:28:30] Reencoding: VID_00025, Pass 1 of 1
 - [10:28:51] Video Encode complete
 - [10:28:51] Reencoding audio tracks (if req'd)
 - [10:28:52] Multiplexing M2TS
 - [10:28:53] Extracting A/V streams [VID_00026]
 - [10:28:56] Reencoding: VID_00026 (18 of 29)
 - [10:28:56] Collecting video information
   - Rate/Length: 29.970fps, 1,955 frames
   - Bitrate: 896 Kbs
 - [10:28:56] Reencoding: VID_00026, Pass 1 of 1
 - [10:29:06] Video Encode complete
 - [10:29:06] Reencoding audio tracks (if req'd)
 - [10:29:06] Multiplexing M2TS
 - [10:29:07] Extracting A/V streams [VID_00027]
 - [10:29:13] Reencoding: VID_00027 (19 of 29)
 - [10:29:13] Collecting video information
   - Rate/Length: 29.970fps, 5,239 frames
   - Bitrate: 906 Kbs
 - [10:29:13] Reencoding: VID_00027, Pass 1 of 1
 - [10:29:38] Video Encode complete
 - [10:29:38] Reencoding audio tracks (if req'd)
 - [10:29:39] Multiplexing M2TS
 - [10:29:40] Extracting A/V streams [VID_00028]
 - [10:29:44] Reencoding: VID_00028 (20 of 29)
 - [10:29:44] Collecting video information
   - Rate/Length: 29.970fps, 2,856 frames
   - Bitrate: 942 Kbs
 - [10:29:44] Reencoding: VID_00028, Pass 1 of 1
 - [10:29:58] Video Encode complete
 - [10:29:58] Reencoding audio tracks (if req'd)
 - [10:29:59] Multiplexing M2TS
 - [10:29:59] Extracting A/V streams [VID_00029]
 - [10:30:02] Reencoding: VID_00029 (21 of 29)
 - [10:30:02] Collecting video information
   - Rate/Length: 29.970fps, 2,267 frames
   - Bitrate: 875 Kbs
 - [10:30:02] Reencoding: VID_00029, Pass 1 of 1
 - [10:30:13] Video Encode complete
 - [10:30:13] Reencoding audio tracks (if req'd)
 - [10:30:14] Multiplexing M2TS
 - [10:30:14] Extracting A/V streams [VID_00030]
 - [10:30:18] Reencoding: VID_00030 (22 of 29)
 - [10:30:18] Collecting video information
   - Rate/Length: 29.970fps, 2,591 frames
   - Bitrate: 947 Kbs
 - [10:30:18] Reencoding: VID_00030, Pass 1 of 1
 - [10:30:30] Video Encode complete
 - [10:30:30] Reencoding audio tracks (if req'd)
 - [10:30:31] Multiplexing M2TS
 - [10:30:32] Extracting A/V streams [VID_00031]
 - [10:30:38] Reencoding: VID_00031 (23 of 29)
 - [10:30:38] Collecting video information
   - Rate/Length: 29.970fps, 6,136 frames
   - Bitrate: 904 Kbs
 - [10:30:39] Reencoding: VID_00031, Pass 1 of 1
 - [10:31:09] Video Encode complete
 - [10:31:09] Reencoding audio tracks (if req'd)
 - [10:31:10] Multiplexing M2TS
 - [10:31:11] Extracting A/V streams [VID_00032]
 - [10:31:13] Reencoding: VID_00032 (24 of 29)
 - [10:31:13] Collecting video information
   - Rate/Length: 29.970fps, 1,426 frames
   - Bitrate: 921 Kbs
 - [10:31:13] Reencoding: VID_00032, Pass 1 of 1
 - [10:31:21] Video Encode complete
 - [10:31:21] Reencoding audio tracks (if req'd)
 - [10:31:21] Multiplexing M2TS
 - [10:31:22] Extracting A/V streams [VID_00033]
 - [10:31:30] Reencoding: VID_00033 (25 of 29)
 - [10:31:30] Collecting video information
   - Rate/Length: 29.970fps, 7,214 frames
   - Bitrate: 920 Kbs
 - [10:31:30] Reencoding: VID_00033, Pass 1 of 1
 - [10:32:05] Video Encode complete
 - [10:32:05] Reencoding audio tracks (if req'd)
 - [10:32:07] Multiplexing M2TS
 - [10:32:08] Extracting A/V streams [VID_00034]
 - [10:32:24] Reencoding: VID_00034 (26 of 29)
 - [10:32:24] Collecting video information
   - Rate/Length: 29.970fps, 14,600 frames
   - Bitrate: 874 Kbs
 - [10:32:25] Reencoding: VID_00034, Pass 1 of 1
 - [10:34:01] Video Encode complete
 - [10:34:01] Reencoding audio tracks (if req'd)
 - [10:34:03] Multiplexing M2TS
 - [10:34:05] Extracting A/V streams [VID_00035]
 - [10:34:13] Reencoding: VID_00035 (27 of 29)
 - [10:34:13] Collecting video information
   - Rate/Length: 29.970fps, 7,929 frames
   - Bitrate: 857 Kbs
 - [10:34:14] Reencoding: VID_00035, Pass 1 of 1
 - [10:35:07] Video Encode complete
 - [10:35:07] Reencoding audio tracks (if req'd)
 - [10:35:08] Multiplexing M2TS
 - [10:35:10] Extracting A/V streams [VID_00036]
 - [10:35:16] Reencoding: VID_00036 (28 of 29)
 - [10:35:16] Collecting video information
   - Rate/Length: 29.970fps, 5,456 frames
   - Bitrate: 855 Kbs
 - [10:35:16] Reencoding: VID_00036, Pass 1 of 1
 - [10:35:52] Video Encode complete
 - [10:35:52] Reencoding audio tracks (if req'd)
 - [10:35:53] Multiplexing M2TS
 - [10:35:54] Extracting A/V streams [VID_01001]
 - [10:35:59] Reencoding: VID_01001 (29 of 29)
 - [10:35:59] Collecting video information
 - [10:35:59] Reencoding: VID_01001, Pass 1 of 1
 - [10:36:33] Video Encode complete
 - [10:36:33] Reencoding audio tracks (if req'd)
 - [10:36:33] Multiplexing M2TS
[10:36:35]PHASE ONE complete
[10:36:35]PHASE TWO - Rebuild Started
 - [10:36:35] Rebuilding BD file Structure
[10:36:40] - Encode and Rebuild complete
 - Computer SHUTDOWN initiated
Capsbackup is offline   Reply With Quote
Old 15th January 2011, 05:23   #10964  |  Link
jdobbs
@Capsbackup
Did it have the issue when played individually or as a group from the MPLS? I've looked at all of them individually and they are in-sync. I did notice, though, that they are all part of a multipart MPLS.
I'm starting to doubt the use of DirectShowSource() with MPEG-2... there have been a couple of oddities for which I've had to build workarounds. It may just be smarter to use DGINDEX and DGMPEGDEC (although it might add a little more complexity to the current code).
Old 15th January 2011, 05:36   #10965  |  Link
Capsbackup
@Capsbackup
I was using the Playall button, and starting from the first clip, Let Her Sleep, the audio was out.
I am running a fast backup now, and will post the files again.
I usually know better than to delete them until things are resolved, but I guess I had a senior moment again.
When I unselected IVTC sources with 3:2 pulldown, these same deleted scenes were in sync.
Old 15th January 2011, 14:39   #10966  |  Link
mask0rz
Ahhh.. good to know. If you still have it, can you post the MUX_MOVIE_ONLY.meta contents?
Here ya go
MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr --custom-chapters=00:00:00.000;00:08:08.750;00:15:56.583;00:22:51.791;00:32:31.916;00:39:07.708;00:45:58.583;00:54:27.333;01:04:07.000;01:12:46.458;01:20:11.750;01:28:14.041;01:33:26.541 --vbv-len=500
V_MPEG4/ISO/AVC, "*Removed*\00009.track_4113.264", fps=29.97, track=1, insertSEI, contSPS
A_DTS, "*Removed*\00009.track_4353.DTS", lang=eng
S_HDMV/PGS, "*Removed*00009.track_4608.SUP",fps=29.97,lang=nld
S_HDMV/PGS, "*Removed*\00009.track_4609.SUP",fps=29.97,lang=nld
mask0rz is offline   Reply With Quote
Old 15th January 2011, 14:47   #10967  |  Link
Capsbackup
Well I ran it again, and I get the same results. The audio is out regardless of playing each individual scene or the playall button.
As I mentioned before, the total time of 00270.mpls of the backup is reported as 00:37:37, 480P where the original is 00:30:06, 480i.
From BDInfo:
Disc Title:     CASE_39_AC BD9 TEST
Disc Size:      8,448,351,842 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.6
Notes:
PLAYLIST: 00270.MPLS
        Total   Video
Title                                                           Codec   Length  Movie Size      Disc Size       Bitrate Bitrate Main Audio Track                          Secondary Audio Track
00270.MPLS                                                      AVC     0:37:37 0               8,448,351,842   0.00    0.00    DD AC3 2.0 224Kbps
DISC INFO:
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.6
PLAYLIST REPORT:
Length:                 0:37:37 (h:m:s)
Total Bitrate:          0.00 Mbps
VIDEO:
Codec                   Bitrate             Description
MPEG-4 AVC Video        0 kbps              480p / 29.970 fps / 16:9 / High Profile 4.1
Old 15th January 2011, 14:56   #10968  |  Link
Capsbackup
From BD-RB:
[Options]
MIN_M2TS_SIZE=100
KEEP_MBTREE=1
MODE=0
ENCODE_QUALITY=0
ONEPASS_ENCODING=2
AUTO_QUALITY=0
QUICK_EXTRAS=0
TARGET_SIZE=4500
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=all
SD_CONVERT=0
COLOR_BOOST=0
RESIZE_1080=0
DEINTERLACE=1
DTS_REENCODE=1
AC3_REENCODE=1
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=0
AVCHD=0
REMOVE_WORKFILES=0
FULL_AVCHD=0
AUDIO_TRACK_LIMIT=1
REMOVE_OUTPUT=0
OPEN_GOP=1
USE_FILTERS=0
MOVIE_ONLY_LOOP=1
BDMV_CERT_ONLY=1
USE_LAVF=0
IVTC_PULLDOWN=1
VERSION=0.37.0.2
ASSUME_DVD_PAL=0
SD_TO_1080=0
CONVERT_WIDE=0
[Paths]
[Status]
LABEL=CASE_39_AC
VERSION=v0.37.02 (beta)
SOURCE_SIZE=38107400570
SOURCE_VIDEO_SIZE=38073772032
TARGET_SIZE=8808038400
REDUCTION=.230458118376749
RESIZE_1080=0
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=all
BACKUP_MODE=0
MOVIEONLY_TYPE=0
USE_LAVF=0
QUICK=0
ENCODE_STEP=0
COMPLETED=29
REBUILD_COMPLETE=1
[00000]
AUDIO=1
PGS=
M2TS_TARGET=12188366
RATE=5375
NSTART=27000000
NEND=27671040
NSIZE=10530816
FLINK=0
MLINK=0
[00001]
AUDIO=
PGS=
M2TS_TARGET=24467351
RATE=4040
NSIZE=24109056
FLINK=-1
MLINK=-1
[00002]
AUDIO=1
PGS=
RATE=5375
NSTART=27000000
NEND=27671040
NSIZE=10524672
FLINK=0
MLINK=0
[00003]
AUDIO=1
PGS=
RATE=5375
NSTART=27000000
NEND=27671040
NSIZE=10524672
FLINK=0
MLINK=0
[00005]
AUDIO=
PGS=
M2TS_TARGET=21727518
RATE=4040
NSIZE=24256512
FLINK=-1
MLINK=-1
[00006]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=43796276
RATE=902
NSTART=27000000
NEND=38986560
NSIZE=43431936
FLINK=0
MLINK=0
[00015]
AUDIO=10000
PGS=10111000
M2TS_TARGET=8185063866
RATE=8455
NSTART=27000000
NEND=322452000
NSIZE=7822632960
FLINK=0
MLINK=0
[00016]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=7974544
RATE=889
NSTART=27000000
NEND=29801048
NSIZE=8318976
FLINK=0
MLINK=0
[00017]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=8974194
RATE=867
NSTART=27000000
NEND=30158405
NSIZE=9314304
FLINK=0
MLINK=0
[00018]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=9938446
RATE=860
NSTART=27000000
NEND=30457954
NSIZE=10125312
FLINK=0
MLINK=0
[00019]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=5189401
RATE=904
NSTART=27000000
NEND=28795043
NSIZE=5541888
FLINK=0
MLINK=0
[00020]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=9762870
RATE=892
NSTART=27000000
NEND=30458705
NSIZE=10039296
FLINK=0
MLINK=0
[00021]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=27838692
RATE=860
NSTART=27000000
NEND=36962452
NSIZE=28207104
FLINK=0
MLINK=0
[00022]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=7967464
RATE=894
NSTART=27000000
NEND=29812309
NSIZE=8355840
FLINK=0
MLINK=0
[00023]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=10804998
RATE=910
NSTART=27000000
NEND=30840086
NSIZE=11120640
FLINK=0
MLINK=0
[00024]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=18714409
RATE=892
NSTART=27000000
NEND=33726720
NSIZE=19740672
FLINK=0
MLINK=0
[00025]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=22099908
RATE=856
NSTART=27000000
NEND=34870863
NSIZE=23089152
FLINK=0
MLINK=0
[00026]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=10364642
RATE=896
NSTART=27000000
NEND=30667413
NSIZE=10665984
FLINK=0
MLINK=0
[00027]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=27238335
RATE=906
NSTART=27000000
NEND=36830320
NSIZE=27660288
FLINK=0
MLINK=0
[00028]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=15333157
RATE=942
NSTART=27000000
NEND=32358102
NSIZE=15691776
FLINK=0
MLINK=0
[00029]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=11865533
RATE=875
NSTART=27000000
NEND=31252998
NSIZE=12244992
FLINK=0
MLINK=0
[00030]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=14258462
RATE=947
NSTART=27000000
NEND=31860355
NSIZE=14555136
FLINK=0
MLINK=0
[00031]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=31851451
RATE=904
NSTART=27000000
NEND=38513502
NSIZE=32354304
FLINK=0
MLINK=0
[00032]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=7667286
RATE=921
NSTART=27000000
NEND=29674171
NSIZE=7962624
FLINK=0
MLINK=0
[00033]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=38708822
RATE=920
NSTART=27000000
NEND=40538274
NSIZE=38860800
FLINK=0
MLINK=0
[00034]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=80188629
RATE=874
NSTART=27000000
NEND=48922560
NSIZE=79853568
FLINK=0
MLINK=0
[00035]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=42394500
RATE=857
NSTART=27000000
NEND=38905920
NSIZE=41883648
FLINK=0
MLINK=0
[00036]
AUDIO=1
PGS=1111
HYBRID=0
M2TS_TARGET=29186662
RATE=855
NSTART=27000000
NEND=35193600
NSIZE=29048832
FLINK=0
MLINK=0
[01001]
AUDIO=
PGS=
RATE=4040
NSIZE=24109056
FLINK=-1
MLINK=-1
Old 15th January 2011, 16:01   #10969  |  Link
jdobbs
Originally Posted by mask0rz View Post
Here ya go
You're saying the original is 24fps? I don't understand, then, why this is remuxing at 29.97? Can you post the contents of your BDREBUILDER.INI and LOG files?
Old 15th January 2011, 16:11   #10970  |  Link
mask0rz
BD-rebuilder.ini
[Options]
VERSION=0.37.0.2
MODE=0
ENCODE_QUALITY=0
ONEPASS_ENCODING=2
AUTO_QUALITY=1
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=dut;eng;nld;
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
DEINTERLACE=0
SD_TO_1080=0
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=0
AVCHD=0
REMOVE_WORKFILES=1
MOVIE_ONLY_LOOP=1
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
USE_LAVF=0
IVTC_PULLDOWN=1
ASSUME_DVD_PAL=0
AUDIO_TRACK_LIMIT=1
SUBTITLE_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=23450
QUICK_EXTRAS=0
TARGET_SIZE=23500
LOG
[13:53:54] BD Rebuilder v0.37.02 (beta)
- Source: TAKEN
- Input BD size: 25,06 GB
- Approximate total content: [01:33:32.541]
- Target BD size: 22,95 GB
- MOVIE-ONLY mode enabled
- Auto Quality: Good (Very Fast), ABR
- Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640
[13:53:54] PHASE ONE, Encoding
- [13:53:54] Extracting A/V streams [VID_00009]
- [14:09:53] Reencoding: VID_00009 (1 of 1)
- [14:09:53] Collecting video information
- [14:09:53] Keeping original video (no reencode)
- [14:09:53] Reencoding audio tracks (if req'd)
- [14:09:53] Multiplexing M2TS
[14:21:03]PHASE ONE complete
[14:21:03]PHASE TWO - Rebuild Started
- [14:21:03] Rebuilding BD file Structure
[14:31:01] - Encode and Rebuild complete
[14:31:01]JOB: TAKEN finished.
Old 15th January 2011, 16:17   #10971  |  Link
jdobbs
No that's even more confusing... It wasn't even reencoded????
Is this an original disc with no proprocessing? It almost sounds like the CLPI file isn't matching the actual stream in the source....
Is the source MPEG, AVC, or VC-1? I can't tell because the verbose status reporting has been turned off.
Old 15th January 2011, 16:21   #10972  |  Link
mask0rz
yep...... and thats why it goes wrong i think... when i do full backup it has 2 reencode and then it works fine.
to prove it has 24 FPS source.
Old 15th January 2011, 16:27   #10973  |  Link
jdobbs
I obviously need to do more testing with 24fps sources...
Old 15th January 2011, 16:31   #10974  |  Link
mask0rz
Well it is not a big deal because i can remux myself with TSmuxer and that does work fine. But i thought it was kinda weird
Old 15th January 2011, 16:32   #10975  |  Link
jdobbs
Ok, I found it. Apparently 24fps is rare -- because based on the code it looks like it has never worked in movie-only mode. It always get set to either 23.976 or 29.97.
I'll have it fixed for the next release.
Old 15th January 2011, 17:00   #10976  |  Link
mask0rz
A great, Thanks for the good work. Programs usually works like a charm.
Old 15th January 2011, 18:11   #10977  |  Link
Voyeurism
Is this likely to fix the problem I was having with "The Curious Case of Benjamin Button" as well, or do you think that is caused by something else?
Voyeurism is offline   Reply With Quote
Old 15th January 2011, 18:22   #10978  |  Link
jdobbs
If it is 24fps and movie-only, then yes it probably will.
Old 15th January 2011, 18:44   #10979  |  Link
Voyeurism
Also, strangely, the frame rate for the video stream is shown in VLC as 23.976023 for the stream on the disk, and 47.952047 for the BD5 - although that can't possibly be correct, as it's definitely not running at double speed.
I don't think it is 24fps, given the above. I guess I will await the next build and see whether it makes any difference. I've attached the .INF and .LOG files in case you want to take a look.
EDIT: I've also just noticed that the audio is out of sync on my backup of "New Moon" (2nd movie in the Twighlight tilogy). The frame rate for the video stream on the original disk is shown as 23.976023fps in both VLC and BD Rebuilder, but VLC shows the stream in the rebuilt BD5 as 47.952047fps.
Old 15th January 2011, 19:05   #10980  |  Link
Sharc
24fps is probably not as rare as you think. I have a couple of these ....
http://forum.doom9.org/showthread.ph...75#post1469375
