12th March 2009, 12:30 | #2861 | Link | |
If your receiver says TrueHD, you're getting TrueHD. If you were picking up the AC3 track only, it would say Dolby Digital or similar. AFAIK none of the NMTs can actually get at the interleaved AC3 track, which is a bit annoying as it turns out, so it's TrueHD or nothing. |
12th March 2009, 14:30 | #2863 | Link |
I've just received a test version (1.8.25) via email from smlabs asking me to check the .m2ts filesize in .clpi issue and I can confirm it is now fixed. I guess 1.8.25 should appear on the smlabs homepage very soon. For those not following the issue, this will fix the pauses at split points when you enable splitting in your BluRay Disc output from TSMuxer. This also means I can remove the hex pathcing from AVCHDMe and get it back it being just a simple renaming tool.
12th March 2009, 14:39 | #2864 | Link | |
12th March 2009, 14:51 | #2865 | Link |
I have no idea how to check those but they supplied the new version within a couple of hours of me mailing them so I doubt the update fixes anything else. If you can point me at a post/thread that details the exact issue i.e. what hex edits are required, I can reply to this mail I got from them asking them to take a look.
12th March 2009, 15:02 | #2866 | Link |
Programmer (or just 教务长)
It is not really 'hex edit' solution, but here is a thread you can send them a link to:
http://forum.doom9.org/showthread.php?t=145092 |
12th March 2009, 17:36 | #2871 | Link | |
Well I got a reply regarding the FINE/COURSE tables:
12th March 2009, 18:12 | #2873 | Link |
Hey Now!
What is the email that you all are using?
I would like to send them one on the LPCM 7.1 channel issue where its swapping the center channel with the right front channel. also would love to see the import lpcm function fixed (as of now have to use the pcm2tsmu.exe to fix the pcm file). Last edited by jamos; 12th March 2009 at 18:25. |
12th March 2009, 18:41 | #2874 | Link |
12th March 2009, 19:26 | #2875 | Link |
BluRay Maniac
http://www.smlabs.net/tsMuxer/tsMuxeR_1.8.26(b).zip
no changelog can somebody check what bugs fixed ? FINE/COURSE tables or PCM bug? Also ftp not work anymore? |
12th March 2009, 19:35 | #2876 | Link | |
I don't want support pcm2tsmu.exe any more, the problem, and the solutions, was reported to tsmuxer@smartlabs.tv at 2008-11-04
12th March 2009, 20:15 | #2879 | Link |
VC-1 tsmuxer and Panasonic Blu Ray Players
Does anybody know if tsmuxer people (smartlabs) are working on the VC-1 problem with Panasonic players.
For anybody that doesn’t know about this, the latest players from Panasonic the BD35 and BD55 are very strict on Blu Ray structure. If you copy a VC-1 encoded disc in its entirety just by having AnyDVDHD running and using explorer to get the files to Hard Drive and then burn them with ImgBurn all is ok. (provided it is of a length that will fit on single layer Disc) BUT If you use tsmuxer to say copy Movie only, then the resulting files will not play on these players, this is confirmed by all Panasonic users. Its not just tsmuxer, tsRemuxer also fails to play. People with access to Scenarist have been able to make compliant Movie only VC-1 discs but as you know this program is thousands of pounds/dollars. As I have said above, this only affects VC-1 original material, H264 seems to be ok. I do NOT want to re-encode to H264 for all the obvious reasons. Anybody help |
tsmuxer |
