26th February 2008, 18:19 | #302 | Link | |
Euh... i've posted a message telling that i've remade the operation, and the wave was correct... I think... I absolutely don't know what has append the first time, and why the wave was incorrect, but unless i re-encounter the problem, you can consider the issue is gone. |
4th March 2008, 04:49 | #304 | Link |
Version 1.5.0 release candidate 3
* Demuxed MPEG audio files are now given the extension mp1/mp2/mp3 depending on the audio layer. The old behavior can be enabled via an INI file option (see users manual).
* Transport packet resync and M2TS file detection were made more robust. * Fixed a bug in the Log Timestamps function, whereby a video DTS value was incorrectly shown as a PTS value. * Fixed a bug in demuxing of DTS audio from transport streams. * The aspect ratio field of the Info dialog now shows the raw value of the field as well as the corresponding string. * The display size from a sequence_display_extension is now shown in the Info dialog. This, together with the change above, allows the sample aspect ratio (SAR) to be inferred, according to the MPEG2 specification. * A default path for saving BMPs can now be specified. * Fixed a bug whereby tracks selected for demuxing in the INI file were not actually enabled for demuxing until the track selection dialog was saved. Now they are honored on startup as they should be. * Fixed the CLI to also parse for the = sign at the end of the options to avoid false option detection. E.g., the substring '-aif' anywhere in a file name would be parsed as an option specification. * Other miscellaneous CLI parsing bugs fixed. * When doing a preview via the CLI, the playback speed is set to maximum. * When a Play/Preview/Save Project Operation begins, the focus is now left on the main window. Previously, it annoyingly moved to the Info window. http://neuron2.net/dgmpgdec/dgmpgdec150rc3.zip IMPORTANT: Either use the new INI file in the zip file, or delete your old one, start DGIndex and close it once before using it in earnest. Last edited by Guest; 4th March 2008 at 05:34. |
4th March 2008, 18:45 | #306 | Link | |
Thanks for the update, keep on rockin' ! |
7th March 2008, 19:00 | #307 | Link |
Life's clearer in 4K UHD
Hi Donald,
By chance, I discovered that DGIndex is able to parse (MPEG-2 DVD) .ISO file sources. I had a quick look thru' your manuals, but could not see this feature mentioned.... Is DGIndex supposed to be able to do this? Cheers
7th March 2008, 20:00 | #308 | Link |
An ISO is just a dump of the disk, isn't it? So the parser parses through junk like the IFO and BUP and then hits the VOBs and sees start codes, etc.
If it works it's a coincidence as it is not by design. Nor do I think you should rely on it. |
7th March 2008, 20:15 | #309 | Link |
Thanks for the confirmation...
Just to let you know. Navigation and elementary stream de-muxing of "movie only" DVD .ISO file back-up's, works very well indeed Cheers
9th March 2008, 11:51 | #310 | Link |
Ok I've searched somewhat, tried out a few things, and can't really find a solution (well kinda..you'll see).
It once again relates too Colormetry, and the lovely 'no hints'. I'll try too make this as painless as possible... DVB-T Australian HDTV Frame rate: 25fps Field order: Top Field First Picture size: 1440x1088 ... Colormetry: Unspecified video (2) From what I can gather from what has been previously said if dgindex thinks that the mpeg-2 video is HD (> SD) then it assumes a colormetry of 709, yet there is not really any assumption being made by dgindex - ie. it still throws that annoying 'no hints' error. My workaround so far has been too just remove the 'hints=true' section from within the brackets of the offending .avs, and then no error occurs. Is this the right thing too do? and the other question is - if HD is assumed too be 709, why not just have dgindex throw out 709 for colormetry and then have no 'no hints' error? btw this happens with all au HDTV no matter what channel... |
9th March 2008, 13:51 | #311 | Link |
See here:
http://forum.doom9.org/showthread.ph...ht=colormatrix Regarding your suggestion, can you float that in the ColorMatrix thread and see if anybody has any objection to it? |
9th March 2008, 20:55 | #312 | Link |
neuron, is it possible for you to add an option in the menu or in the .ini to make dgmpgdec take window priority and beep again once it has finished saving a project as i used to know when it was finished if i was surfing on the net and can go and encode it, now i keep forgetting to look, i prefered the old behaviour alot more.
i like RC3 alot btw |
10th March 2008, 14:22 | #313 | Link | |
10th March 2008, 16:47 | #314 | Link |
If I call dgindex like this
dgindex.exe -IF=[%~n2.m2t] -OF=[%~n2] -OM=1 -IA=3 -minimize -exit It doesn't honer the full path flag (ie I'm getting full paths and I don't want them), but if I open dgindex and go through the gui it works fine. |
10th March 2008, 21:50 | #315 | Link | |
10th March 2008, 22:12 | #316 | Link | ||
11th March 2008, 03:25 | #317 | Link | |
thanks for your hard work neuron |
11th March 2008, 03:40 | #318 | Link |
You mean 1.4.4 RC2?
No way it worked in 1.5.0 RC2. Just to demonstrate what a magnanimous chap I am (matching your kind words), I've added an INI file option. Notify_When_Done: 0=no notify 1=window to foreground 2=beep 3=foreground and beep 4=send email to all 50 forums at which hajj_3 has an account Last edited by Guest; 11th March 2008 at 04:20. |
11th March 2008, 11:31 | #319 | Link | |
Finally I think that there is colormetry within these streams however its just not being parsed right by dgindex, it used too work fine, now it doesn't, that implies change, and as far as I know DVB-T in au has not changed, the standards have been set for a while now (except for transport stream properties - ie. epg EIT). |
11th March 2008, 12:22 | #320 | Link | |
it certainly worked in 1.5.0 beta 13 and im almost certain 1.5.0 RC2, it took foreground and beeped. thanks for adding this /me does the david brent dance for neuron. |
