25th June 2008, 23:39 | #1801 | Link |
And about my question?
Did it will be possible to have 2 audio tracks when convert blu-ray structures? Because now we can have two tracks, but the program choose only one language.
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. |
25th June 2008, 23:48 | #1802 | Link |
Later..... Now I have to fix DTS size calcuation for just one audio stream
26th June 2008, 00:02 | #1803 | Link |
I dont care so should you
Use CLSID version and it will be read correctly
My Installer's || |
26th June 2008, 03:40 | #1804 | Link |
I can't stress enough how having other programs installed might effect Ripbot264. (Staxrip, MeGUI, AutoMKV,etc)
If you're having script errors, I suggest uninstalling EVERYTHING and starting from scratch. Just my $.02. |
26th June 2008, 06:32 | #1805 | Link |
??? I have had no such errors I have all of those and ripbot still works. I dont know what you got wrong but its not any fault of ripbot...
My Installer's || |
26th June 2008, 12:59 | #1806 | Link |
ffmpeg source error
Hello All,
Hopefully this isn't a n00b question but I am trying to convert an m2ts in ripbot (which I love by the way), and I get the following error: FFmpegSource: Couldn't open C:\temp\Ripbot264temp\job1\Blu-Ray.mkv (C:\temp\Ripbot264\temp\job1\getinfo.avs, line 2) Am I missing something totally obvious? Thanks. |
26th June 2008, 15:43 | #1808 | Link | |
OK, I tried things out over the course of the day yesterday for Pirates 2 after downloading the latest RB264 and ffdshow and also not using TsMuxer as you suggested.
Although RB264 tooks hours to initially demux the audio tracks from the m2ts file, I do however get the full movie now. It reads the entire 2 hours and 48 minutes of Pirates 2. I kicked the job off then went to work. Came back and tested and about 12 minutes into the movie the audio crapped out on me making all kinds of squeeky sounds. Upon recalling what I had done in RB264, I think I might have selected the wrong demuxed audio file...the .flac file from the PCM track. Strange thing is the audio is fine for 12 minutes. Anyways, today, I kicked off the job again using the .ac3 file which has the English track. Hopefully this will give me better results. The only other thing I noticed is that the first pass says it will take more than 4 hours. Before it used to only take around 1.5 hours. Also, I managed to get the entire movie recognized in RB264 this way: 1) Demux desired audio track in TsMuxer. (Use demux option) 2) Remux the movie track only in TsMuxer and output as m2ts file. 3) Then open these files up in RB264. At least right now, this method is actually quicker for me since I don't have to wait for demuxing of each audio track, just the one that I want. I guess it also depends on the original disc. Thanks for the great work!!! Nick Quote:
26th June 2008, 15:47 | #1810 | Link | |
Another question, if you want. I have an MKV resolution is 1280x544, now if i crop i losse image size because it crop the video. If i want to convert to 1280x720, with the ratio 2.35:1 to keep full resolution quality without loosing resolution WITOUT cropping, to keep all full video. Did you know what i can do for that, with something? The only one way i found is to cropping, but face are stretched, image from top and bottom has been cropped. If the program can just add black bar on the botton and top for the difference (720-544= 176/2 = 88) ripbot only crop 88px but it goes like zooming the picture. I just want that the program add black bars and keep full 1280 and 544 to 720. Thanks and keeping good work of that program!
26th June 2008, 15:53 | #1811 | Link | |
I think (hope) selecting desired audio track will be enabled in the next version of Ripbot. This is very close to being a one-click conversion tool for BD & HD-DVD. Great work Atak!! Last edited by wakebrder; 26th June 2008 at 15:56. |
26th June 2008, 16:36 | #1812 | Link | |
I'll look into eac3to.
Oh yes, I agree. RipBot is one AWESOME tool! Quote:
26th June 2008, 16:46 | #1813 | Link | |
m2ts error
I tried the steps above, and I got this error importing my m2ts I attached below. The m2ts is a vc-1, any help from the experts would be most appreciated http://img364.imageshack.us/my.php?image=errorgc5.jpg Last edited by repdetect2; 26th June 2008 at 20:06. Reason: updating post |
26th June 2008, 17:35 | #1814 | Link |
Atak,
Is there any way for me to build subtitles into the movie so I can toggle them on/off? The reason I am asking this is because my why is deaf and needs subtitles but I do not always watch the movies with her and would like to have the ability to turn off the subtitles. Thanks in advance and thanks for building such an awesome program!!! Duramaximus |
26th June 2008, 17:46 | #1816 | Link | |
Having problems with iTunes in latest Ripbot 1.10.x
I am having the same problem too with iTunes now with Ripbot 1.10.1. Prior versions, eg. 1.9.10 works fine with iTunes. The -mpeg4 flag is still in there, so the problem is probably somewhere else. I have tried encoding the audio.aac manually using Quicktime prior to muxing it but that doesn't help this time. Quicktime is showing error -2010 but iTunes fails silently on import. |
26th June 2008, 18:52 | #1817 | Link | |
My Installer's || |
26th June 2008, 18:57 | #1818 | Link | |
Because you already have FFDshow installed you can just re install Itunes/Quicktime and it should fix any problems resulting from it...
My Installer's || |
26th June 2008, 19:11 | #1819 | Link |
I try to shrink Starship Troopers from Bluray !
codec is VC1 When i Start the latest Ripbot following Error comes! video=DirectShowSource("C:\Temp\RipBot264temp\job1\Blu-Ray.mkv",audio=false).ConvertToYV12() LoadPlugin("C:\Programme\bluray\ripbot\tools\AviSynth plugins\NicAudio\NicAudio.dll") audio=NicAC3Source("C:\Temp\RipBot264temp\job1\audio.1.ac3") AudioDub(video,audio) WriteFile("C:\Temp\RipBot264temp\job1\info.txt","Framecount") WriteFile("C:\Temp\RipBot264temp\job1\info.txt","Framerate") WriteFile("C:\Temp\RipBot264temp\job1\info.txt","AudioRate") WriteFile("C:\Temp\RipBot264temp\job1\info.txt","AudioChannels") WriteFile("C:\Temp\RipBot264temp\job1\info.txt","AudioLength") WriteFile("C:\Temp\RipBot264temp\job1\info.txt","Width") WriteFile("C:\Temp\RipBot264temp\job1\info.txt","Height ") Trim(0,-1) Whats wrong? |
26th June 2008, 20:53 | #1820 | Link |
You are trying to rip directly from the blu-ray media?
You need anyDVD HD for uncrypt the media, after uncrypted drive, You need to open tsmuxerGUI to select one video and audio tracks, remux in M2TS in your hard drive. After that, the media is not AACS protected and you can work with the media.
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. Last edited by 8ternity; 26th June 2008 at 20:58. |
