Old 13th February 2010, 20:14   #221  |  Link
Tiberiust
@martin53
Several AvsP users finding it unuseable in Win7. Would be great if yu could sort it out....don't stop bcos of lack of encouragement
T
Tiberiust is offline   Reply With Quote
Old 2nd March 2010, 23:32   #222  |  Link
Gannjunior
Gannjunior's Avatar
i'm using it under Windows 7 x64 and it works great!
ciao!
P6T| 12Gb DDR3| i7-920 D0@3.8Ghz@1.168v+NOCTUA NH-U12P| Liberty 620| Stacker|2xRAID0 (4x500gb) Seag.72k.11| Seag. 500gb 72k.12| Seag. 1.5Tb 72k.11| GTX470@668/1843| U2410 24"| Se7en x64 on VRapt 300gb
Gannjunior is offline   Reply With Quote
Old 3rd March 2010, 11:57   #223  |  Link
GibsonXXI
Only thing about AvsP that I don't like is it's usage of the clipboard. In that it doesn't actually save changes to the clipboard like other apps. Close the program and try pasting a selection in a new instance to see what I mean.
That and it doesn't always automatically save changed files if you close the program without saving. In such instances it doesn't prompt you either. Only happened a few times, annoying nonetheless.
Otherwise, an indispensable tool.
GibsonXXI is offline   Reply With Quote
Old 22nd March 2010, 16:11   #224  |  Link
doc_dvxm
HD Encod3r
Hii There... I am using AvsP on Win 7 32 Bit platform and everything is fine..
I have to ask to develloppers: Can you add a shortcut for "Save image as..." - for example Shift + anything or Ctrl + anything?
Thanx in advance
doc_dvxm is offline   Reply With Quote
Old 22nd March 2010, 19:34   #225  |  Link
tengo6dedos
green apple eater
You will have better luck asking that in avspmod.
tengo6dedos is offline   Reply With Quote
Old 22nd March 2010, 21:04   #226  |  Link
doc_dvxm
HD Encod3r
Ok Thanx ...
Old 6th January 2011, 16:22   #227  |  Link
bidmead
Nothing here since March of last year?
Gosh. This either means that AVsP has achieved perfection, or that a better Avisynth front end has turned up and everyone's migrated to it.
Or is this related to qwerpoi's disappearance? I lost contact with him in mid-2007. Does anyone know what's happened to him?
For me the AVsP/Avisynth combo remains absolutely the best movie editor of all time at any price. I'd love to get back in contact with qwerpoi.
Chris
bidmead is offline   Reply With Quote
Old 19th December 2011, 17:38   #228  |  Link
szabi
Hi
How is it possible to insert more than one avi file in an avisource?
bye
szabi
szabi is offline   Reply With Quote
Old 20th December 2011, 03:55   #229  |  Link
Zarxrax
doc_dvxm: you can do this in avspmod, you just need to set up the shortcut under Options>Keyboard Shortcuts
bidmead: it seems qwerpoi is gone, but there is still a little bit of development going on, mostly thanks to Angel_Su.
szabi: you can join files together with ++
for example
AviSource("file1.avi")++AviSource("file2.avi")
Zarxrax is offline   Reply With Quote
Old 20th December 2011, 09:37   #230  |  Link
bidmead
Yup, no sign of qwerpoi, alas. But the whole thing is now coming along nicely as AvsPMod over here: http://forum.doom9.org/showthread.ph...hlight=avspmod
Chris
Old 20th December 2011, 10:51   #231  |  Link
Gavino
Avisynth language lover
for example
Since AviSource accepts multiple file names, you can also do
AviSource("file1.avi", "file2.avi", ...)
which seems more in line with the original question.
Old 22nd December 2011, 19:20   #232  |  Link
szabi
Hi
Yeah i know it, my problem is this from menu: right click -> insert -> insert source only one file can be selected.
bye szabi
